Question about Kenmore Elite 45986 Front Load Washer
F 28 CODE
JUST GOT THIS MACHINE AND F 28 CODE IS COMING ON
    President:
  • Kenmore Master
  • 2,651 Answers
Well if you jkujst got as in brand ne wfrom factory, you do have a 1 yr warrr, and they should remedy for you, as far as my experience with the f28, its been a communication error from the main board to the motor control board, in which case ive removed and reinstalled all wiring to ensure proper seating of the wires
Posted on Jan 11, 2009
Ir 3300 error code - E000002- 0000
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well. if it's a canon.
May 03, 2015 | Office Equipment & Supplies
P-9, P-21, P-28 error code
P-9 Replace the black developer and drum unit.
P-28 Have tech clean the IDC sensor located under the transfer belt forward section (right side of the copier) the rear one towards back of the machine right side There are two clean both
Above two codes should then fix P-21 which is the fault that registration is not right. And Since the Black Image unit is the reference for the other three color in regards to Registration that is why P-9 and P-28 need fix first.
Apr 17, 2014 | Konica Minolta Bizhub C364 Color Copier /...
Code 28
Code 28 Error Message
The Code 28 error is one of several Device Manager error codes. The Code 28 error will almost always display exactly like this:
"The drivers for this device are not installed. (Code 28)"
Details on Device Manager error codes like Code 28 are available in the Device Status area in the device's properties: How to View a Device's Status in Device Manager.
Aug 23, 2011 | HP Computers & Internet
Code 28 driver is not installed in my laptop, please tell me how i can install code 28 dricer and i have nothing any cd.
The Code 28 driver means that there is a piece of hardware installed on your computer, but the driver wasn't installed correctly. If you have recently installed a piece of hardware, then you may need to find the correct driver for it. These are often found on the manufacturers websites.
If this doesn't work, then remove any hardware you have recently added, and reboot the machine. If the code 28 error goes, then at least you know exactly what's causing it, and can re-troubleshoot from there.
Jul 23, 2011 | Microsoft Windows XP Professional
Sir i have a canon imagerunner 6570 model machine .it was coming an error code .that was e00004-103 . how to clear the error? pls give me a solution as early aspossible thank u srinivas
goto the service mode by pressing (additional function 28 additional function) .in there got to function then to clear and then clear the error by pressing ok and restart the machine
May 22, 2011 | Canon IMAGERUNNER 6570 Copier
28-276 Delta bandsaw blade keeps coming off?
Unplug the machine, gain access to the two wheels. On the back of the machine you should have a tilt adjustment knob. Manually turn the wheels in the direction of the cut and at the same turn adjust the tilt knob on the back of the machine. This should solve the problem.
Sep 27, 2010 | Delta 28 168 Bench Band Saw Blade 56 1/8...
Audio code 28
Audio code 28 means your audio drivers are not installed. If your machine is a branded machine (ie DELL, HP/COMPAQ, etc) then go to their website for the latest drivers. If you built the machine up, go to the manufacturer site of the motherboard, or if you have the CD for it, use that.
Nov 29, 2009 | Microsoft Windows XP Professional
Kenmore F-28 error - door locked can't get in
Unplug the machine.
Wait 15 seconds.
Plug machine back in.
Press and hold the Power button until the lights come on.
Press and hold Start.
When you hear a click, press Stop.
Open door.
You still have an F-28 issue but you can at least get your clothes now.
Hope this helps.
Jun 09, 2009 | Kenmore HE2 Plus Front Load Washer
Code 28 error for matshita dvd-ram uj-852 ata device
hi,
Please go to the device manager by typing and entering devmgmt.msc in run option.
click the plus sign given before dvd cr rom drive and uninstall the drive coming.
then clisck the plus sign of ide ATA/ATAPI controllers and the uninstall the secondary IDE channels.
Retart the machine twice.
If the also the issue is not resoved then you will have to reload the OS again.
Jan 31, 2009 | Computers & Internet
I have duet it says code f 28
f28 indicates a communication problem between top machine control bd (under top rear rail) and motor control bd on bottom ..check all wiring between the 2 first ..but top control most likely suspect but remember guessing can be expensive
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
241 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
