Question about Anchor Audio/PA Systems: Liberty Sound System Package Microphone
Replace battery in an Anchor Liberty 4500 speaker
2 Suggested Answers
  • 1138 Answers
SOURCE: How do you replace a battery in an Anchor Liberty
Here is the link to the manual if you don't have one:http://www.google.com/search?hl=en&q=Anchor+Liberty+4500+PA+system+battery+power+replacement&btnG=Search&aq=f&oq=&aqi= It appears as if you have to remove the entire control panel to replace the two batteries. You probably have to use exact replacements. THe link to the company is in the manual and they can probably give you more information. Hope this helps.
Posted on Nov 26, 2009
Everything works fine in my mps4500 system except if I speak to the microphone too loud, it will result the speak power off. How to fix it?
I don't have a fix for this mine does the same thing I turn on and speak and it turns off then I have to turn back on.does battery need replaced or will it play with just the ac plug.
Dec 08, 2013 | Anchor Audio/PA Systems: Liberty Sound...
How to open anchor audio liberty speaker system
As I remember the Anchor has a removable metal back plate that is used to mount the volume control and 1/4" or XLR connectors. Before you start disassembling the unit....are you a qualified repair person? Other than a bad speaker, broken wire or connector there's not much "user servicable" parts inside.
Feb 16, 2013 | Anchor Audio/PA Systems: Liberty Sound...
I need schematics for an anchor audio liberty 4600
http://www.hollywoodstudiorentals.com/uploads/031810_anchor_lliberty-mpa-man.pdf
Hi please find above your manual, it maybe of some help? to obtain the schematic you would need the service manual, I have been unable to locate one? perhaps a direct approach to the manufacturer will allow you to obtain one?
Aug 21, 2011 | Anchor Audio/PA Systems: Liberty Sound...
I have a Liberty MPB 4500, and every time i increase the sound it get disconnected Why?
I would suspect that the internal battery may need replacing as it cannot produce enough output to sustain the system at high power.
There is a lot of support available on this website (including video of how to replace the battery)
http://www.anchoraudio.com/faq.cfm
download the manual here http://www.mmvideosystems.com/video_equipment_rental/pdf_files/anchor_lliberty-mpa-man.pdf
Feb 10, 2011 | Anchor Audio/PA Systems: Liberty Sound...
Cant get signal or sound on wireless speakers. Which Audio Socket on TV do I use Audio/visual input or RGB DVI or Audio outlets on AV TV recorder Humax 9300T TV is LG model26LB75
you should be looking for the audio out socket from the tv as the signal is going out from the set to your speakers the other sockets are for input when connecting dvd or video into the tv. hope this helps ..A
Jul 21, 2010 | Anchor Audio/PA Systems: Liberty Sound...
I have a Liberty 4500. Hum Noise when cable is pluged in
You don't say what's at the other end of that cable. It's a player in this scenario, too.
Feb 08, 2010 | Anchor Audio/PA Systems: Liberty Sound...
My keyless entry stopped working on my 2005 Jeep Liberty. Replaced the battery on the key and tried my backup key nothing happens.
YOU WILL PROBABLY NEED TO HAVE THE REMOTES REPROGRAMED TO YOUR JEEP IT SOUNDS LIKE THEY LOST THEIR PROGRAM,LOTS OF THINGS CAN CAUSR THAT TO HAPPEN ,LIKE HAVING THEM TO CLOSE TO A MAGNET LIKE LAYING YOUR KEYS ON THE HOME STEREO SPEAKER,OR CLOCK RADIO,DROPPING THEM SEVERAL TIMES, ETC,& ITS POSSIBLE THEY WILL NEED TO BE REDONE AFTER THE BATTERY REPLACEMENT.
Dec 05, 2009 | 2005 Jeep Liberty
How do you replace a battery in an Anchor Liberty 4500 PA system?
Nov 26, 2009 | Anchor Audio/PA Systems: Liberty Sound...
I have an Anchor, Liberty PA speaker that shuts off when I speak on the mic or as sson as I raise the volume. What is the problem?
Hi and welcome to FixYa,
Initially, your concern would be indicating two (2) possibilities:
  • speaker impedance mismatch. For some reason, the output thinks that the speakers connected to it are too low. This could be brought about if several speakers are connected to a single output without proper matching;
  • electronic/circuitry problem. the amplifier has partial short or cold solder connections of faulty components.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 26, 2008 | Audio Players & Recorders
Anchor Audio/PA Systems: Liberty Sound System Package Microphone Logo
212 people viewed this question
Top Anchor Audio Players & Recorders Experts
Michial Gueffroy
old marine
old marine
Tom Chichester
Are you an Anchor Audio Player and Recorder Expert? Answer questions, earn points and help others
