Question about Home Security
My gas fire receiver sky-3243p has burned out , where can I get a new one
THIS PRODUCT CAME INSTALLED IN A GAS FIRE BUT UNDERSTAND THAT THE EUROPEAN SUPPLIER IS NO LONGER TRADING, THE CURCUIT BOARD INSIDE THE RECEIVER APPEARS TO HAVE BURNED OUT, MAYBE DUE TO A CURRENT SURGE FOLLOWING A POWER FAILURE
aborcass
  • 2651 Answers
SOURCE: Maytag Nepture MAH5500BWW burned control board
ummmm, honestly ive never replaced just the board(im an authorized maytag servicer) so our replacements have always been new, and in this case the repair kit containing both board and motor. that being said, i cant see a reason as to why you couldnt relace just the board itself, ,Ireally never found the reason why the board would burn out, but, as far as repair kit im certain that they were trying to get all circuit boards and motors back to only one model, instead of having 5 or six different boards andmotors, this will bring them all to the most recent board and motor, never was an issue with themotor, jusat that you couldnt wire in the new board without the neew wiring. As long as its the same board i cant see why that wont work. as far as the "wax motor" that was a seperate issue burning out the Top control board, total seperate then your problem,., dont really see an issue with installing your "used board"
Posted on Apr 08, 2008
  • 189 Answers
SOURCE: Furnace blower blows cold air
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
Posted on Mar 08, 2009
deathraider
  • 64 Answers
SOURCE: gateway 505GR desktop...failure to start
when the power supply goes bad , that is the sign that it needs to be replaced . I would replace it first .
Posted on Mar 12, 2009
SOURCE: My Creative I-Trigue L3800 speakers have stopped
don't know but i'm in the same boat. the white connector on the subwoofer does not receive sound. either the left or the right speaker will work when plugged into the red female connectors but neither works with the right. fuse is all i can think of. know where to get one?
Posted on Apr 10, 2010
SOURCE: LiveWire - audio & visual - Universal Remote - code
dows anyone know ther contack number or website
Posted on Jul 31, 2010
Fumes from flavel regent gas fire when burning
This is normal .It should definitely burnt off in a few hours.
Normally the heat exchanger is coated with a corn oil so it wouldn't get damage while sitting in their warehouse for too long.
Normally installer should have burnt it out before it gets blown into space
May 31, 2017 | Heating & Cooling
Application error sky caddie sgx
Hello
The problem post is seems to be difficult to understand. Will you please give me a brief description about the fault with your Sky Caddie SGX?
Oct 13, 2011 | Nextar Q3 GPS Receiver
HI WE INSTALL H250FDN POOL HEATER . AFTER A DAY THE HEATER WAS INSTALLED CUSTOMER CALLED MANITOBA HYDRO BECAUSE IT WAS A STRANGE SMELL WHEN THE HEATER BURNING. GAS COMPANY CAME AND SHUT OF THE GAS FROM A...
The heater literally stinks for some time after it is installed as the fire tile burns in. Every heater we install makes my eyes burn if I get a good whiff of the fumes...Are you certain the utility actually tested the discharge air? My guess would be someone walked up and gave it a sniff and over-reacted to what is a normal odor from a new heater. You can of course double check your flames from below the burner tray. If they are nice bright blue standing 2 - 4 inches tall your heater is operating normally and the smell should subside shortly after it gets some steady use.
John
May 26, 2011 | Hayward H-series Electronic Gas Pool...
My GPS cannot detect the satellite signal.
Garmin says:
If your GPSMAP 60CSx will not acquire a satellite signal when outside with a clear view of the sky, please try the following:
  1. Click here http://garmin.com/products/webupdater/howtoinstall.jsp
  2. Follow the onscreen instructions to install and update your unit
  3. Once updated allow for the device to set free from obstructions for 20 minutes to acquire satellites
If this does not work then we suggest doing a master reset with your device - Note: A master reset will erase all waypoints or favorites and will restore your device to the default factory settings. To perform the master reset please do the following:
  1. Turn the device OFF
  2. Press and hold Quit + Menu + Out + Power
  3. The device screen will then flash and will power on
  4. Leave the device turned ON with a clear view of the sky without moving it for approximately 30 minutes so that it may acquire satellites
If still unable to acquire satellites, contact Garmin Customer Support via one of the methods below:
North America - Consumer Products (for all Garmin products except Apollo aircraft)
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
E-mail Product Support
Europe - Consumer Products (for all Garmin products except Apollo Databases)
Austria For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 17:00 PM (GMT/UTC +2)
Phone: 43 (0) 3133 3181 0
Website
Belgium For all Garmin products except Aviation.
Friday: 9:00 AM – 15:00 PM (GMT/UTC +2)
Phone: 00 32 2672 5254
Website
Denmark For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 17:00 PM Central European Time (GMT/UTC +1)
Phone: 00 45 4810 5050
Website
Finland For all Garmin products except Aviation.
Monday – Friday: 8:30 AM – 16:00 PM (GMT/UTC +3)
Phone: 00 358 19 311 001
Website
France For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 18:00 PM Central European Time (GMT/UTC +1)
Phone: 00 33 1 5517 81 89
Website
Germany For all Garmin products except Aviation.
Monday – Friday: 8:30 AM – 17:00 PM Central European Time (UTC/GMT +1)
Phone: 00 49 898 58364 880
Website
Italy For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 13:00 PM / 14:00 PM – 17:30 PM (GMT/UTC +2)
Friday: 9:00 AM – 13:00 PM / 14:00 PM – 16:30 PM (GMT/UTC +2)
Phone: 00 39 02 3669 9699
Website
Portugal For all Garmin products except Aviation.
Monday – Friday: 09:00 AM – 12:30 PM / 14:00 PM – 18:00 PM (GMT/UTC or GMT/UTC +1 depending on city)
Phone: 00 35 1214 447 460
Website
Spain For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 13:30 p.m / 14:30 PM - 18:00 PM Central European Time (GMT/UTC +1)
Phone: 00 34 934 972 373
Website
Sweden For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 17:00 PM (GMT/UTC +2)
Phone: 00 46 7744 52020
Website
United Kingdom For all of United Kingdom users and customers in unlisted countries in Europe, Africa and Middle East
Monday – Friday: 8:30 AM – 17:30 PM Western European Time (GMT/UTC)
Phone: 00 44 808 238 0000
Website
Oct 08, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Compatability issue between Garmin 760 & LG87
This could a problem with bluetooth radio or firmware on the GPS or in the other device. Support for your phone may not be included in your installed firmware version. Check for any updates for the LG87 and update the GPS by running the Garmin WebUpdater application available below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
If problems persist, check with Garmin Customer Support below for further assistance.
US: 913-397-8200
Website
Website
Website
Website
Website
Website
Website
Website
Website
Website
Website
Sep 30, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
I can hear the other person on the phone through
It appears you have successfully paired the cell to the GPS, so going forward:
The mic on the 760 is behind a very small opening on the front left bezel (if my memory serves me right) of the 760. If you are far away from the mic, the other person will have trouble understanding you. If you can get closer to the GPS during a test call, ask the other person if they can understand you any better. If they are unable to hear you at all, there is a problem with the mic or mic circuit. There is no adjustment for the mic. If the 760 is no longer under warranty, it may be cheaper to buy an external mic. Garmin sells one - but you may find one at radio Shack, etc. An external mic is connected to the cradle - not the GPS directly. If neither internal or external mic works, it's a problem within the unit and will likely have to be sent to Garmin for repair.
Garmin Customer Support can be reached below:
US: 913-397-8200
Website
Website
Website
Website
Website
Website
Website
Website
Website
Website
Website
Sep 29, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 765will not lock on to satellite.
Download & install the Garmin Web Updater for your computer from their page at:
Connect your nuvi to your computer with the USB cable and allow the computer recognize it.
Run the Web Updater program and follow the prompts to update the GPS. When completed, remove the GPS.
The first time that you connect the GPS to the traffic receiver, the GPS will update the software in it. It may take a minute or two to complete. If you have any problems, you can contact Garmin Customer Support at the numbers below:
US: 913-397-8200
Website
Website
Website
Website
Website
Website
Website
Website
Website
Website
Website
Sep 24, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
When turn on always says poor satellite reception,
Hi Carlos,
You are receiving that message because the GPS is unable to acquire satellites. Satellite reception can be limited due to one or more of the follow reasons: Poor view of the sky, GPS antenna not deployed, used indoors or other internal problems.
Try taking the device outside in full view of the sky - preferably with little or no tree cover, tall buildings, etc. and allow up to 2 minutes to acquire satellites.
If unable to acquire, it may require return to Garmin for repair. Contact Garmin based on your location and product below:
US: 913-397-8200
Website
Website
Website
Website
Website
Website
Website
Website
Website
Website
Website
Aviation Products Monday – Friday: 7 AM – 7 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-866-739-5687
E-mail Aviation Support
Apollo Aviation Monday – Friday: 8 AM – 4:30 PM Pacific Time (closed holidays)
US: 503-391-3411
US Toll Free: 1-800-525-6726
Canada: 1-800-654-3415
Garmin Europe Monday – Friday: 8:30 AM – 17:30 PM Western European Time (GMT/UTC)
+44 (0) 87 0850 1243
Fax: +44 (0) 23 8052 4004
Sep 18, 2009 | Garmin GPS
Nuvi 780 does not get past "loading maps". I have rebooted to no avail. I have let my MSN subscription expire. Does the entire GPS system depend on MSN?
The MSDN Traffic receiver does not need to be active to display maps. it is only needed for traffic reports, news, stocks, gas prices, Web Favorites, etc.
You may need to reload the maps into your GPS, unfortunately garmin stopped including the DVD in the box - BUT Garmin will send a DVD disk for free - just for asking. You will need your coupon codes however, to unlock the map.
I suggest you telephone Garmin and speak with a Customer Support Rep. to get a full explanation of what they can do for you.
US: 913-397-8200
Website
Website
Website
Website
Website
Website
Website
Website
Website
Website
Website
Sep 18, 2009 | Garmin nuvi 780 GPS
Home Security Logo
282 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
