Question about Garden
Replacing recoil spring for mcculloch mt700 trimmer
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
  • 8 Answers
SOURCE: Broken recoil starter spring
try your local mower shop tell what type it is the modle number and make the should be able to cross refrenesss it and get the right one
Posted on Aug 16, 2009
  • 120 Answers
SOURCE: Pull cord on TB25CS trimmer came out all the way, won't recoil
http://www.m-and-d.com/pdfs/MTD/TB25CS-41BDT25C063PL.pdf
Probably the recoil spring is broken.
Posted on Aug 24, 2009
SOURCE: Gentlemen, I have a Mighty lite Trimmer of which
I have the same problem....the cord remains out...so I pulled it apart and discovered that the recoil wheel that the cord rewinds onto does not stay where it is supposed to and rides upward catching on the fixings that hold it in place. When i pressed it down the cord retratcts immediatley. Only problem is it does not stay there. It was only used three times.
It has everything to do with being a cheap product. I should have paid a little more and bought a better product. Will not buy homelite again.
Posted on Aug 24, 2010
rycgl
  • 1545 Answers
SOURCE: I am looking for a
Go to www.searspartsdirect.com and put in your model info and they will provide you with a download or this will take you directly to the model with diagrams that you need:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358.796121/0247/1503820?pathTaken=
They sell parts on this site or you can probably order them online and/or go to their outlet and pick them up.
Please vote on this solution.
Posted on Sep 06, 2010
Looking for recoil spring mcculloch trimmer at3a62e1
Contact your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Mar 02, 2017 | McCulloch Garden
Chainsaw recoil spring
I recommend contacting your local service center for assistance.
Contact us
User manuals
McCulloch Service
Nov 04, 2013 | McCulloch Garden
Recoil assembly for mcculloch mb290
These may be ordered online. Just perform a Google search. If you don't know part numbers, then refer to your service manual.
I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
Aug 30, 2013 | McCulloch 26cc Gas Blower Mcb3208
Recoil assemby
I recommend contacting your local authorized service center for assistance with replacement.
Contact us
User manuals
McCulloch Service
Replacing pull start on 223l trimmer
Its pawl has either come off the recoil spring or the recoil spring has broken. There are videos on youtube showng you how to repair this fault.
Sep 20, 2012 | Husqvarna 223L
Replace starter rope on McCulloch MT700
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,thank you.
Feb 11, 2012 | Garden
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
Pull cord will not recoil
It can be as easy as a stuck pully or as serious as a seized engine I have one question is the rope in or out if its out it could be a broken spring
Nov 03, 2009 | McCulloch Garden
Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
134 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
