Question about Sport & Outdoor - Others
How to open crosman pellet containers
I have tried everything so help
5 Suggested Answers
jaballou
  • 63 Answers
SOURCE: my crosman 2100 classic .177 caliber pellet/ bb repeater
http://www.crosman.com/airguns/service/manuals/crosman-rifles
Good Luck!
Posted on Dec 06, 2008
taran_2005
  • 10515 Answers
SOURCE: crosman pellet gun, powermaster 66
Kindly mention the problem in detail?
Thanks!!
Posted on Oct 01, 2010
micromatikal
  • 2777 Answers
SOURCE: Trying to load .177 cal.
Hello there, I can definitely help you with this. With .117 cal pellets you just need to load them one at a time into the slide. Pull back the slide, it should lock open, then place the pellet in the slide's receiver.... the little "trough" where the slide comes back through.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks,
Tim
Posted on Oct 13, 2010
Testimonial: "thanks!"
  • 3 Answers
SOURCE: how to sight in crosman
You would sight in an air rifle scope in the same manner as any other standard scope that you might find on a rifle:
You want to secure the rifle as best you can with the sights pointed towards a target, which should be set at the desired distance.
Reduce the error of your sight adjustments either by mounting the rifle in a gun mount or simply resting the stock (not the barrel!) on a solid surface such as a table.
Make sure that the weight of the rifle is carefully supported and the **** is firmly pressed into your shoulder. Looking through the sights, aim at the very center of the target (which for your purposes can be as simple as a piece of paper with a dot drawn in the middle).
Take time to ensure a careful shot, and be sure to avoid any shaking, utilizing the support of the mount/table (try resting the fore-grip of the stock on a roll of paper towels if you're having trouble keeping the rifle steady).
Once you are confident with the placement of the cross-hairs over the center of the target, gently squeeze (don't pull) the trigger.
Determine where the pellet struck the target, and adjust the scope accordingly; while every scope is a little different, the same basic principles for adjustment apply. Unscrew the caps on the top and side of the scope, and carefully read the markings on the adjustment dials.
If the pellet struck low, twist the dial on the top of the scope 'up' (the markings should specify clockwise/counter), and if the pellet struck high, twist in the opposite direction. If the pellet struck to the left or right, follow the same procedure for the dial on the side of the scope.
If the pellet struck low and to the side, make the vertical (up/down) adjustments first, repeat the shot, and only move on to make adjustments left/right once the pellet strikes in vertical alignment with the center of the target.
Take your time, and adjust in increments of only 2-3 clicks to start. Repeat the procedure until the pellets are striking consistently in the center of the target (if you're having a hard time remembering which shot went where, replace the target and continue.
Once you are satisfied with placement of your shot groupings on the targets, replace the dial covers on the scope.
Tips and Notes:
- In order to maintain the accuracy of your rifle, try to avoid resting the rifle on its scope and try to prevent the barrel from contact.
- Take note of your rifle's range, and be aware that the further away you place the target, the less consistent your results will be.
- Be realistic; don't attempt to sight in an air rifle at 50 yards. Remember that even with a rifle that has been professionally sighted, good results still come down to the accuracy of the shooter.
-Sight in your rifle at a range where you are confident in your own abilities; start with a closer target and only move back (i.e. sight in at a greater distance) if necessary.
Further Instruction:
http://www.chuckhawks.com/sight-in_rifle.htm
http://www.youtube.com/watch?v=lLirsAFpsfE
Posted on May 05, 2011
Instructions to mount scope
PDF]OWNER'S MANUAL - Crosman
www.crosman.com/pdf/manuals/M4-177-515.pdf
Translate this page There are two different rear sight options for the M4-177 depending on which model you purchase.) Option 1- ... the airgun in any way inconsistent with this manual may make your ... Adjust the rings on your scope to match the measurements of the top rail. ... Toattach the sling at both ends push the sewn webbing loop end.
Crosman M4-177 Multi-pump .177 Pellet Air Rifle Table Top ...
? 24:29
https://www.youtube.com/watch?v=s_0grKCOmX0
May 18, 2012 - Uploaded by Replica Airguns
ReplicaAirguns.com - Crosman M4-177 Pellet-BB Multi-pump Air Rifle ... -Single shot - bolt action with manual advance magazine.... I particularly like the removable iron sights and full rail formounting a scope or red dot sight.
Crosman M4-177: Installing and Adjusting the Sights ...
? 8:38
https://www.youtube.com/watch?v=x8XKOmb41QA
Aug 28, 2012 - Uploaded by Crosman
A detailed look at installing and adjusting the sights for the M4-177 and sighting ... Crosman MK-177 Pellet-BB Multi-pump Air Rifle Table Top ...
Crosman M4-177 shooting rev
Dec 20, 2015 | Crosman M4-177 Air Rifle
My Crosman 1008 Repeat Air pistol leaks all CO2 out
The crosman 1008 does indeed fire pellets! NOT BBs. ONLY pellets.
Feb 03, 2014 | Crosman (4032)
Crosman 1377 single shot pellet air pistol-how do i remove pellet from barrell?
if you dont have a cleaning rod for it you can go to your local bass pro/cabelas/outdoors store and get a cleaning rod for a .17 caliber for fairly cheap. you should be able to push the pellet out or clean it if there is dirt or grime in it. and make sure you use the right caliber pellet! (:
Dec 24, 2011 | Crosman 1377 177 Single Shot Air Pistol
How to get parts for crosman model 766 serial 979102568\ .177 pellet/bb repeater A Coleman division
You can get parts on amazon, click here and take a look Amazon com crosman parts. I hope this was helpful. Have a nice day
Feb 25, 2011 | Crosman Optics
Require an owners manual for crossman pellet rifle model 1077.
Here is the link to all the user manuals for Crossman pellet rifles
by your description you want the manual for the CS1K77
Please let me know if this is the correct manual?
Dec 27, 2010 | Crosman Optics
Will not chamber a pellet for Crossman 357 .177 cal pellet gun
http://www.pyramydair.com/site/manuals/Crosman-2100.pdf ,
Read this and make a decision based on the information contained within.
Feb 06, 2010 | Crosman Phantom .177 Caliber Break Barrel...
This is a new pellet rifle, but it is not getting sufficient compression. DH would like to know what to do to fix it. Thank you, daht
Lubricate everything generously with Marvel Mystery oil.Your new pellet gun is probably leaking around the seals.Oil improves the seals.Be sure to wipe off excell oil before shooting.
Mar 10, 2009 | Crosman Optics
Sport & Outdoor - Others Logo
48 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
