Question about Caterpillar C15 Acert Engine Wdisplay Standdiecast
Knocking noise around pullys/damper - Caterpillar C15 Acert Engine Wdisplay Standdiecast
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
MAY BE THE BEARING INSIDE YOUR HARMONIC BALACER, CRANKSHAFT DAMPER THEY DO WEAR OUT AROUND 500,000 MILES. OR YOU HAVE BEARINGS OUT ON A PULLEY. AND IT COULD BE MORE THAN ONE PULLEY. I HAVE HAD TO REPLACE PULLEY SPINDLES ON MY C15 ACERT BEFORE. IT HAD COMPLETELY CHEWED UP THE BEARINGS.
Posted on Aug 24, 2013
What is the cause of a knocking noise around the gearbox area in chevrolet AVeo 2008
if you have just replaced the clutch and pressure plate in the vehicle and the noise has just started, I suspect that you have the clutch plate in back to front and the hub and damper springs and knocking on the flywheel bolt heads.
It would be a good idea to check the gearbox oil level as you may have lost more that realised when pulling the box
Aug 22, 2015 | 2008 Chevrolet Aveo
Crank shaft pully makes noise
Cranshaft pulley is bad,probably has rubber damper which is damaged or worn loose.Don't run it this way.Get the pulley replaced now. don-ohio
Oct 31, 2011 | 2001 Chevrolet Corvette
Hi, i have a knocking noise coming from the front end when i go over slight bumps in the road or just up car ramp or manhole in the road
Sounds like you have a malfunctioning front dampers( shock absorber ). That was cause by the lack fluid inside the dampers, the fluid may leaked out already and your damper seal have leaks.
Bring your motorbike to the nearest repair shop to fill those dampers with new fluid and you won't hear anymore knocking sound.
Hope that helps you out!
Aug 09, 2011 | Suzuki GSX-R 600 Motorcycles
Noise at main pully on crank,looks out of round at low rpm
rubber damper sandwiched in the pully may have crumbled. Remove belt and check pulley for play. If there is any play, replace the damper. Let me know if you need instructions--this requires a crankshaft damper puller.
Dec 12, 2010 | 1997 Nissan Maxima
JUST CHANGED WATER PUMP, POWER STEERING PUMP, BELT TENSION ASSEMBLY. EVERYTHING OK FOR ABOUT 2 WEEKS AND NOW THERE IS A KNOCK OR RATTLE COMING FROM THE FRONT OF ENGINE. WHEN BELT IS REMOVED THE NOISE GOES...
the damper could be bad if it's the type with the rubber inbetween the pully and the the rest of the damper. check that and see if it is separated. if not looks like your crankshaft bearings could be bad
Nov 18, 2009 | 1995 Oldsmobile Silhouette
Knocking noise
you will need ro replace the crank shaft pully
the reason for this is that the inner part of the pully is rubber mounted and the rubber fails ovet time
Oct 27, 2009 | 1987 Peugeot Liberte
1996 bmw 323i m52b25 slight knocking noise from engine between
take rubber hose and place near ear use as stethoscope, pin point noise, and pull apart, till problem is located. buy manual
Sep 12, 2009 | 1994 BMW 3 Series
Knocking noise from AC compressor
I would replace the compressor, if it seizes up, the belt will keep turning over the pully and burn then snap
Jan 31, 2009 | 1991 Toyota MR2
Bottomend knocking
on that model you have a damper poulie when you start it it sound like the motor nocking but its the rubber on the pullie itself that broken its the poulie the big on on the crank itself look at it you gonna see the crack rubber poullie loose and noisy
pierre
Jun 24, 2008 | 1994 Chevrolet Lumina APV
Caterpillar C15 Acert Engine Wdisplay Standdiecast Logo
197 people viewed this question
Top Caterpillar Toys Experts
fordexpert
DROPNDEAL
DROPNDEAL
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
