Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Ford 4000 three point linkage hydraulics are slow
2 Suggested Answers
  • 40 Answers
SOURCE: ford 4000 hydraulic problems
First, make sure there is plenty of hydraulic oil in the reservoir
2nd, no leaks that are dumping the pressure
3rd, no blockage in tubes, located inside pump housing.
4th, make sure operating handle is engaging
try these and if nothing works let me know.
Posted on Mar 23, 2011
Ford 7810 series 2 hydraulics have gone very slow have pressure tested tractor and it is OK until you rev it up the pressure goes oil sound like it is sergin in back end of tractor oil level OK ?
Best advice is for you to list this in Lawn and Garden or Construction equipment section for Tractors. There is a valve knob on a 4000 series that proportions hydraulic flow from more in back than front depending on the setting. If you have a front loader or if you have rear attachments you can get more action on the end you want. On a 4000 the knob is by the right heel of the driver. Could work like this for 7810.
Jul 20, 2017 | Ford Cars & Trucks
1966 ford 4000 tractor leaking milky white hydraulic fluid out of where the gear shift is. looks like foam
The "milky foam look" is a CLASSIC sign that there is water (or maybe antifreeze) mixed in with something that has a petroleum base ... such a oil or hydraulic fluid!
May 08, 2017 | Ford Cars & Trucks
Where is the hydraulic filter on a 1964 Ford 4000 tractor
It has a filter inside the hydraulic pump canister in pump on engine.
Nov 13, 2016 | Ford Garden
190xt 3 point won't lift or very slow when hot
Series IV D17 3 point problems - AllisChalmers Forum - Page 1 ...
www.allischalmers.com > ... > Allis Chalmers > Farm Equipment
Apr 15, 2013 - 30 posts - ‎11 authors
I have a few issues with the three point on my D17. ... As soon as I close it, the armsraise back up (not ever touching the spool valve lever). ..... for 50 HP and a hydraulic pump with great volume at slow engine speeds. ... Or the oil is just cold and they won'tgo all the way down normally unless the oil is hot?
Nov 26, 2015 | Cars & Trucks
Three point hitch on John Deere 4005 not working right
I have 5310 this happened to me The control linkage pin broke by the valve. I'm sure you have checked fluid.Mine also has hydraulic filter that I serviced. good luck
Jun 15, 2014 | Garden
Hi I have a ford 8210 and the three point hitch won't go up I put new hydraulic filters on and made sure it it is full of hydraulic oil what could it be
there is an oil pump inside the gear box . There may be a second clutch that drivers the PTO separate to the gear box but the problem will be the pump or the valve assembly that controls the linkage
Dec 21, 2013 | Cars & Trucks
The 3 point linkage on a ford 4000 tractor is only lifting half way and stopping with weight on it. what would be the problem?
I am not an expert nor have much experience - just a guess - low on hydraulic fluid? Check hydraulic fluid reservoir, if any, for correct level of fluid. Add correct fluid if necessary. If really low - suggests a possible leak somewhere. Should check for that as well.
Dec 06, 2011 | Garden
I have a ford tractor and hydraulics are slow
not so fast,, yes thick hydraulic oil can cause slow hydraulics and if the hydraulics speed up when warm then this may be your problem. if they dont then you need to look at possible problems with the pump, the spool, or linkage to spool. remember that speed is flow, a pump can have good pressure but lousy flow. also there should be some kind of pressure relief valve in system if this stuck open then it will let oil go back to tank causing your problem. there is no quick answer to your problem but there are a lot of possibilities. need to do some diagnosing!
Feb 08, 2010 | Parat 1:32 Scale Diecast Replica: 1920...
Ford 4000 hydraulic problems
Jan 23, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
John Deere 4410 three point hitch will not raise. All linkage is intact, no I believe that there may not be hydraulic pressure, although the front loader does work. Recently changed hydraulic oil and...
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Sep 25, 2009 | John Deere 3-point Hitch Kit A,b,g,50,60...
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
63 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
