Logitech touchpad t650 sensitivity settings
How to change how hard I have to tap the touchpad to select a option.
5 Suggested Answers
Kimi
  • 277 Answers
SOURCE: Changing Sensitivity
1. Open the SetPointTM software and assign a keystroke to the button you want to use. For further details about this procedure, launch the Help Center within SetPoint and view the mouse topic To change the task assigned to a button. 2. Click the Windows® Start button, locate the function or application you want to launch and right-click it to display a menu. (If the function or application you want to launch is not available from the Windows Start menu, use Windows Explorer to locate it and then right-click it.) 3. Select Properties. 4. In the Shortcut tab, enter a Shortcut key that is the same as the keystroke you chose at step 1. 5. Click OK.
Posted on Oct 09, 2005
SOURCE: dell xps M140 laptop touchpad
Hmm I don't have this problem... but i do need some new touchpad buttons and can't find any :|
Posted on May 17, 2008
SOURCE: Can't "tap" on my Dell touchpad
I had the same problem after purchasing an HP laptop with a Synaptics TouchPad. After using a wireless mouse for awhile, the TouchPad stopped working. The TouchPad light was white, indicating it was enabled. No TouchPad devices was listed anymore in the Mouse Properties in the Control Panel. I tried reloading the driver but nothing changed.
After shutting down the laptop and removing the battery (according to owner’s manual) it worked again. After turning on the laptop, make sure the TouchPad works. Then go to Control Panel, Mouse, Device Settings tab, and make sure a Synaptics TouchPad is listed in the Devices list and that the Enable button is grayed out.
Posted on May 29, 2009
  • 145 Answers
SOURCE: My touchpad will scroll around the screen but when
Go to the Dell support website and enter your serve tag or express service code, This will bring you to the software for your specific machine. Download fresh drivers for the touchpad, see if this resets it.
Also check the touchpad under Control Panel or Dell Utilities, and see if somehow those features or buttons were disabled.
If neither of these options work you will need to bring it to a local PC shop and they will reconnect or replace the touchpad and/or keyboard if they are attached in your model.
If they have to replace the parts they will probably get them from Ebay so if you are so inclined and they tell you they need the parts, you can get them yourself and possibly save a buck or two.
Hope this helps, I also do this type of work the CT area so if you are around there and need the service, let me know I am reasonably priced, industry certified, have passed all the Dell factory tests, and I am happy to help.
Good Luck !!
Jim
Posted on Aug 05, 2009
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
Cursor jumps around
Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Click on the Start menu and open the Control Panel. Choose an "Icon View" option from the "View by" dropdown menu, then click the "Mouse" icon. Navigate to the "Device Settings" tab and click on the Synaptics device in the list. If you have installed and use custom software other than a Synaptics application for controlling the touchpad, select it instead. Click the "Settings" button. Click the "+" symbol to expand the "Pointing" section in the left frame, and then the "Sensitivity" section. Click on "PalmCheck." If you have replaced the Synaptics drivers, the menu may use a different set of options. Click and drag the bar to the right, closer to the "Maximum" setting. An increased PalmCheck setting will help decrease cursor jumping due to accidental palm activations, a common occurrence when typing. Click on "Touch Sensitivity." Click and drag the bar to the right, closer to the "Heavy Touch" end. This will ensure light brushes by fingers or accidental activations by other objects will not cause the cursor to jump. Click "Apply" to test the settings, and "OK" when satisfied to save the changes and close the window.
Jan 28, 2013 | Dell Inspiron dncwix12 Notebook
Cursor jumps into a previously-typed word or line and emails won't open
which email account ??
Acer laptop computers come with built-in touchpads to control cursor movement onscreen. Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that Acer includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Try right clicking on email select open
Jan 28, 2013 | Acer Aspire One PC Notebook
Sencitivity of touch pad how to adjust
Nearly every modern laptop computer comes with a touchpad for on-screen interaction. Depending on your operating system and touchpad driver versions, you can update the speed, sensitivity, tap speed and clicking functions of your computer's touch pad. Accessing these settings and updating them to meet your needs is a quick and easy process with both the Microsoft Windows and Apple OS X operating systems.
Change Touchpad Settings in Windows1. Open the Control Panel by clicking the Windows Start button and selecting "Control Panel." Depending on your Windows configuration, this option may be located within the Start Menu's "Settings" sub-folder.
2. Double-click the Control Panel's "Mouse" icon.
  • 3. Click the Touchpad tab. This tab can have one of several names, depending on your computer manufacturer, your operating system version and your device drivers. However, the most common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see any option resembling these, you may not be able adjust your laptop's touchpad settings. Refer to the "Warnings" section if this applies to your computer.
  • 4. Locate the "Scrolling Settings" area within the touchpad properties tab. Adjust the settings to meet your needs and then click "OK" to close the dialog boxes and confirm your changes.
  • for MAC OS
  • Click the Apple menu and then select "Preferences."
  • 2
    Click the "Keyboard & Mouse" icon.
  • 3
    Select the "Trackpad" option from the top of the Keyboard & Mouse dialog box.
  • 4
    Adjust the trackpad settings to meet your needs, and then close the dialog box to confirm your changes.
  • Dec 01, 2011 | Computers & Internet
    Hey i do not know how this will play out since it is sooo difficult to use my touch pad. I have a Dell Inspiron w/Vista Basic since yesterday my touchpad will not function very well. I lick my finger...
    1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound."
    2. Select the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
    3. Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity.
    4. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes.
    I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
    Feb 18, 2011 | Dell F3534 Touchpad
    I have a TOSHIBA NB100.The mouse pad is too sensitive .I can even move the cursor hovering my finger above it without touching the pad .I thinlk it causes words and letters to come out as a jumble. Is...
    control panel----Mouse----Should bring you to a screen with several tabs at the top-----pointer options tab---Select a pointer speed this should slow down the mouse movement----then go to the first tab (touchpad) and you can change the touchpad sensitivity. Hope this helps
    Jan 07, 2011 | Computers & Internet
    My cursor moves as i type what can i do
    You seem to be brushing against the touch pad while you're typing. You need to adjust the sensitivity of that touch pad:
    Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers." Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply." Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings." Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes. Do some work on your computer for a while. If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
    Jan 01, 2011 | Computers & Internet
    I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
    1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
    2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
    3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
    4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
    5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
    Jul 12, 2010 | Dell Vostro 1000 Notebook
    Touchpad Sensitivity
    Click on the start menu and select "Control Panel". Once in the control panel, select "Hardware and Sound". Once in the hardware and sound menu, click on "Mouse". Once the mouse menu comes up, there should be a tab labeled "Dell Touchpad". Click on that tab and then click on the large touchpad icon to take you to the touchpad options. Once in the touchpad options menu, click on "Device Select". Once you click on deivce select you should see the option to "enable" or "disable" the touchpad.
    Mar 28, 2009 | Dell Inspiron 6400 Notebook
    Toshiba touch pad not working to tap of finger
    First got to Start/Settings/Control Panel/Mouse(or there may be a separate Touch Pad setup) and check were options for touchpad Settings Options are tabbed or listed.
    All touchpads allow on/off settings for Tap or NoTap. Also, check Sensitivity Settings. If very low, then Tap would have to be very hard to be recognized.
    Next, reboot your computer.
    Feb 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
    Computers & Internet Logo
    590 people viewed this question
    David Payne
    David Payne
