My Visionquest TV has the picture upside down. Tried factory reset and it doesn't fix this.
SOURCE: my sceptre television picture is upside down, can
If you select "source" on your remote then enter 7343 it will bring up a factory menu. Go down to 'Other setting' , the setting 'scaler output' should be set to "Normal". This setting flips the display.
Posted on Mar 21, 2010
SOURCE: visionquest rembrant 42" tv....less than
I had a simular problem.I loaded it up in my truck and took it to
the free estimate tv guys. when we unloaded it and plugeed it
in it worked fine.
try unpluging it for an hour or so.sometimes this allows
the reset to do it's thing..??
good luck, james
Posted on May 04, 2011
  • 8457 Answers
SOURCE: We have a Sony Bravia
The board that call the T-CON board it is dying and dead soon.That why it is causing horizontal or vertical lines and distoted pictures.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel and it only job are to decoded pictures pixels before it go onto the tv LCD screen panel.Tries websites Shopjimmmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
Posted on Jul 20, 2011
jdvillanueva
  • 2098 Answers
SOURCE: My sharp LC-26SH12U, purchased a bit over a year
I don't think reset can cure this kind of problem because the fault is between the inverter board or the power supply board inside the set. You have to check the output voltage of the power supply at CP406 (pin 1,2,3,4,5), if 24Vdc is present, replace the inverter board. If the voltage is not present, replaced the power supply board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Aug 25, 2011
  • 693 Answers
SOURCE: I have a Visionquest Rembrandt.
If you have Parental Controls turned on, but cannot remember your PIN, you will be prompted to select and answer a secret question that will allow you to change your PIN in the "Game Settings and PIN" menu If you no longer remember your PIN, nor the answer to your secret question, then you will need to contact Nintendo Consumer Service for assistance. Click the button below to get started
Posted on Sep 12, 2011
Magnavox tv screen upside down
Turn the TV upside down...lol....
You can do a factory reset to fix this
Nov 27, 2017 | Magnavox Televison & Video
I have fussion led 32 inch tv i pressed reset it turned picture upside down how can i fix it
Go to service mode and there should be an option to flip the picture, not sure why this should happen when selecting reset as its more common when replacing the main board
Nov 08, 2017 | Televison & Video
How to fix tv picture upside down and fuzzy rainbow color.
Factory reset will make it right. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 24, 2015 | Emerson Televison & Video
Picture is upside down
Although obvious, things happen: make sure the unit is not installed upside down.
Recommend going to the Picture section of you manual, and follow the instructions to reset you unit to factory specifications.
Mar 17, 2015 | LG 47 47LV5500 47 LCD TV
How to fix upside down screen on led tv
Time control board or lcd panel itself. Some times you cannot get the t con board. it may only come with the LCD panel. Check Shop Jimmy website.
May 29, 2013 | Vizio E390-A1 39" 1080p 60Hz LED 2.95"...
Visionquest tv needs to be reset without a remote
You don't say what model it is but usually there are power, volume, channel, etc, buttons on the side or the top of the tv. Look well. They try to hide them. This link might help.....
http://www.nokia.com/us-en/support/product/c6-00/userguide/?action=onlineuserguidepagechange&pFile=GUID-7774D2C2-534C-4EAB-9970-BC847B9DB674_FILE001.html
Sep 11, 2012 | Televison & Video
I have a sony bravi xbr ;the picture is sooo big i can't read the subtitles . i tried ti fix it ( from the instruction manual ) but nothing work . thank you !
Hi: Check you screens format button to change screen sizes, this button may also be labeled Aspect. Seems you are in ZOOM Mode, these buttons can also be found on cable boxes remote as well try pushing them to see if screen size change. If this does'nt help then do this with the TV in off posistion. Press the Display key on your remote, Then the Five key, then the Vol up key, then press power key. This will turn set on in service mode, you will see service options do not do anything but press the number 8 on remote and hit enter. This will rest tv to factory settings. All video setups and parameters you have set in user menu will result back to factory and will need to be redone. TV should shut down on its own and come back on on channel 3.
Dec 10, 2011 | Sony BRAVIA KDL-52XBR3 Television
I have a Visionquest Rembrandt. We recently had a power outage in our area. I can still play dvd's from my blue ray, no problem. But when I turn on my Wii the tv asks for a security code. I know...
Sep 12, 2011 | Televison & Video
Visionquest rembrant 42" tv....less than
in it worked fine.
good luck, james
May 04, 2011 | Vision Televison & Video
My bulb was replaced. We reset the bulb hours and somehow flipped the screen upside down. The projector is mounted upside down. What do I do? In trying to fix it, the remote quit working. I may have...
I guess you used factory reset, then picture flips back to table/ front mode.
In setting menu choose for ceiling ( R upside down icon) and set this to ON.
Jan 08, 2011 | Eiki LC XNB4 LCD Projector
Televison & Video Logo
235 people viewed this question
Top Televison & Video Experts
