Question about Steamaster Steamist TC-135 Timer & Programmable Digital Temperature Control
TC-135 Steamist control not working, when turned on, the display shows temperature of 161 degree
How do you turn the temperature up and down on a steamist tc 130 thermostat?
Google (steamist)(tc 130)(manual) without parens to get instructions.
Nov 13, 2016 | Heating & Cooling
No power to TC-135 temp control
The power supply to the control board may be bad.
Jan 30, 2015 | Steamist SM-46 Residential Steam Generator...
Is it possible for a Steamist sauna to turn itself on?
If there is fault in chipset, or possible electrical short.
Contact Steamist
http://www.steamist.com/contact-us/
I suspect electrical short would trip the GFCI.
Absolutely make sure you have GFCI protection
http://waterheatertimer.org/How-to-wire-GFCI.html
Sep 10, 2012 | Steamist TC-135 Digital Temp 3/4" -...
CAN NOT GET TO TURN ON THERMOSTAT IS NOT WORKING
Contact Steamist directly:
http://steamist.com/contact.htm
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 24, 2011 | Steamist TC-135 Digital Temp 3/4" -...
Hello, I no longer have a copy of use directions for the Steamist TC-135 and I need to adjust the time. Help, please. Jim
http://www.steamist.com/contact.htm
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Apr 25, 2011 | Steamist TC-135 Digital Temp 3/4" -...
E6 Display on the control unit
You posted question under Steamist:
Sample Steamist manual says:
"Error messages E4, E5 and E6 indicate a communication problem with the steam generator. If this error occurs, check both ends of the control cable for clean, dry and secure connections.
Dirty contacts can be cleaned with alcohol and a cotton swab or a toothbrush. This can also happen if the control is not sealed and the cable connections get wet."
Error codes change as technology changes, and sample manual may not include your model:
Contact company directly for product manual and troubleshoot help from manufacturer
Add a comment for more free help.
For a price, expert works with you via e-mail or phone while you work on Steamist or any do-it-yourself project.
Feb 22, 2011 | Steamist 11 KW Steam Unit SM11IM
I have a Kenmore Electric Dryer #76974150. It only works right the higher heat setting. Will not heat at all on the low heat settings? Any ideas?
If the dryer is running then the thermal fuse is okay.
The temperature is controlled by three parts. There is the operating thermostat which is on the blower housing and is rated at 150 degrees. This is high heat.
The operating thermostat sits in a thermostat heater which is controlled by the temperature switch. The temperature switch controls how much voltage passes it to the thermostat heater. This is how we achieve lower temperatures. There is about a 15/20 degree difference between high heat and low heat.
The restricted vent may have caused the appearance of the dryer running hot.
I would suggest you check the temperature coming out of the exhaust. It can be checked with the vent hose pulled off. Any thermostat with a range between 120 degrees and 160 can be used. With the vent removed check the temperature of the air in the exhaust. At high temperature it should cycle between 135 degrees to approximately 155 degrees. This is high heat.
If you turn the temperature switch to a lower setting such as delicate you should see a lower temperature in the exhaust. It may only be 15 degrees lower but it should show a lower temperature.
I hope this information helps to resolve this problem.
Jan 08, 2011 | Kenmore Dryers
Steamaster Steamist TC-135 Timer & Programmable Digital Temperature Control Logo
156 people viewed this question
Top Steamaster Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Steamaster Hardware and Accessory Expert? Answer questions, earn points and help others
