Question about Maytag MZD2766GES Side by Side Refrigerator
Mzd 2766ges adc board
We are wondering if the adc board is responsible for our fridge turning itself off after several hours (8-18?) We've completely defrosted and it still happens. We had a guy come for 60$ who just cleaned the coils and checked the inside coils with the 2 screws from the freezer and said if I replaced the water filter it would be all right. We haven't replaced the filter yet but the thing worked for 8 hours and then was off when we got home. Looking at blogs it seems this is a common problem. Is there any pattern with our model?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
I have no idea what the tech was thinking! What would a water filter have to do with the unit shutting down?! From what you have described, I would say the ADC is getting stuck in the defrost model. Replace the ADC and you should be good to go. Here is the part to order.
Keep me posted and throw that techs number in the garbage!
Posted on Nov 30, 2012
  • kmatanovic
    kmatanovic Dec 01, 2012
    His card says his name is Vin and he is A/Vision Appliance Service. He does "all major appliances" along with air/duct/furnaces and it says he's certified, what a joke! Caveat Emptor! $60 is a lot to loose these days, so THANK YOU for helping us for what appears to be completely FREE! Besides ads here, this site looks fantastic and I will let you know how we do. My husband is going to look for this part locally today, as we've been out of a fridge for 4 days, trying to figure out what happened and goign through the frost/defrost cyle a couple of times. Is there any known reason why this happens, or is it a part that just wears out at a given length of usage. Will be back here when we've solved it! Thanks again!
  • Richard Roth
    Richard Roth Dec 01, 2012
    It could be about anything that would cause it to go bad. A power surge, quality control, inferior parts and so on. But anyways, keep me posted on your progress.
  • 1462 Answers
SOURCE: My daughter has a Bottom
cannot usually be done to trigger defrost. best you can do is to try to trace which edge connector goes to heater and with everything disconnected, apply mains to the edge connector
Posted on Sep 25, 2008
  • 958 Answers
SOURCE: Defrost Heater Resistance Range
21.3 ohms is just fine for a defrost heater. this heater is low wattage since it is an adaptive defrost. you could have problem with temperature sensor since you have replaced the board already.
tnx for using fixya,
drcool
Posted on Sep 30, 2008
bobicehouse
  • 1524 Answers
SOURCE: MZD2768GE Maytag S/S Refreg/Freezer freezer side coils iced up.
Yes to both questions.
Posted on May 04, 2009
  • 258 Answers
SOURCE: Refrigerator not cooling-Freezer Coils Freeze Up & Don't Defrost
check the fan assembly theres not enough air flow going over the coils
Posted on Feb 11, 2010
  • 3 Answers
SOURCE: freezer works, fridge does not. It's not cold.
Last year I had a similar problem, but with a different unit. Mine was a side-by-side. The freezer was cold, but the refrigerator was not. Since there's typically only one cold source in these systems, that told me that the problem had to be air flow from the freezer compartment to the refrigerator. In my case it turned out to be the "diffuser". This is a small "breezeway" between freezer and refrigerator that opens and closes as cold is needed by the refrigerator. Anyway, I replaced that and everything got better.
Posted on Feb 21, 2010
JVC LT-22EM72 Solid red power indicator but tv won't turn on
Customer service told me to leave the unit unplugged for 24 hours.
Feb 22, 2013 | JVC Lt22em72 22-in Led 60hz 1080p Hdtv
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
Sharp 80le632u lcd turn off randomly & suddenly
Checked Power Board is it any solder is not proper. Resolder all main point.
Jun 04, 2017 | Sharp Aquos Televison & Video
Startup takes hours, help?
The clicking suggests a power supply issue, a old trick I use in cases like this is a hairdryer, Try to heat (don't melt things) different boards carefully until you get a dramatic reaction, considering the brand which I do not like much less endorse, what is there to lose.
If you pinpoint the issue to one board try to locate that board.
Dec 11, 2012 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Garmin nuvi 40 will not charge
Sounds like a defective unit. You've tried everything their support people would walk you through.
Sorry...
Oct 31, 2012 | Garmin Nuvi 40
Fluctuation of temperature GE Profile
g.e has mother boards or computer board in them located on the back outside wall,your board is on the top left,part number wr55x10942,everything on your machine runs through that board,also look at the evaporator coil where the thermostat is,there's a sensor on the top of the coil,it looks like a white bullet,if there's a black ring around it where the wires connect to it you also have to change that too.wr55x10025.go here and look at picture,if your board doesn't have all the relays like on this board then you don't have the updated board
http://www.repairclinic.com/PartDetail/Main-Control-Board/WR55X10942/1531075the new board has all 7 relays and is the newest board.hope this helps and good luck with it.
Sep 12, 2012 | GE Refrigerators
After a power outage my LG electrocool not longer gets cold nor does the freezer work
It looks like you have had a surge through the refridgeration system, this would mean you have to replace the motor but that woul cost more than the fridge itself
Mar 27, 2012 | LG LRSC26980 Refrigerator
We have a Kenmore Elite Freezer Model #253.29082994. We had the freezer plugged in and it was working fine. We unplugged it and moved it and now when we plug it in it won't start. Is there some kind of...
You refrigerator was made by Frigidaire Adaptive Defrost Controls Frigidaire Refrigerator Trouble Shooting and Diagnosing
On the initial plugin, or when power is restored to the fridge after a power outage:
If terminating thermostat is open, the fridge enters a compressor (cooling) cycle.
If the terminating thermostat is closed, the first defrost cycle occurs 1 hour
after initial plug-in.
Maximum defrost cycle time is 24 minutes.
Minimum time between defrost cycles is 6 hours. (compressor runtime)
Maximum normal clock time between defrost cycles is 12 hours.
Maximum time between defrost cycles (in "vacation" mode) is 72 hours.
Vacation mode is not entered unless the door has not been opened in at least 24 hours.
Note that the ADC will only enter the defrost mode if the terminating thermostat is closed. If the terminating thermostat is open when defrost is initiated, the ADC board will wait for six minutes and then return to the cooling mode.
ASSUMING that the fridge has been on and running,
and the terminating thermostat is closed,
defrost is initiated by pressing the door (light) switch
at least five times within six seconds.
The defrost heater should start heating up within 8 seconds.
If the above procedure caused the heater to heat up, the ADC board is probably bad; replace it.
If the defrost heater does not heat up, test the defrost heater, terminating thermostat and cold control for continuity as follows:
Unplug the fridge from the wall. Unplug the ADC board from its connector.
Test the connector for continuity between the following leads:
Defrost Heater = DEF TERM (blue) to DEF OUT (brown).
Terminating Thermostat = DEF TERM (blue) to NEUTRAL (lt blue).
Cold Control = COLD CONTROL (orange) to L1 (black).
Replace the defective component.
dvfxnxxsllnll3xsyszyldhiovfnqznnvujbtluyw2q4uxl2ntjkcdj6njhpmxnefkntwws4bi9kdg83ay5nd0jdsnhpljetrth0supsduvxugpczlkyaszhzu1onu9xwdfjv0xta0jidtfiwg%3d%3d
Apr 26, 2011 | Kenmore Freezers
Freezer coils keep freezing up.
I had a similar problem with a Maytage Side-by-SIde Model MDZ2768GEW, (purchased in 2001). Defrost not working...poor cooling in both the freezer and fridge. We opened up the back of the Freezing side and the coils were iced. This Model is auto defrost so obviously something was not working. We called a Sears repair office and they sent a guy that told us we needed to defrost the unit. Well...I wasn't home and my father-in-law didn't question it - he defrosted it! I was busy at the time and didn't pursue it until the problem naturally resurfaced a month or so later. Not wanting to haggle with Sears over their Tech's lazy incompetence (or the $100 I was out), I decided to commence troubleshooting. I'm an ex Navy nuke electrician and electrical engineer so this didn't seem to be beyond my ability. Not having the Owners Manual, I internet searched until I found this site: www.servicematters.com/maytag_library/html/index.html. You can download your model's Service Manual and root around for other tech info their. I found the manual for mine and performed the troubleshooting for the Adaptive Defrost Control. Its fairly easy to do and you don't have to empty the entire fridge. You do have to empty the upper shelf in the fresh food (cooler) side to gain access to the controls. --This may not be in the exact order needed but you remove the light shield by pulling down on the back corners of the cover and sliding it forward (slotted attachment - no screws). Next Remove several screws holding the fascia / radiant shield on. Then remove screws that mount the control housing to top of fridge, etc. I also removed two screws that mount the ADC to the plastic housing to get access to the ADC. Basically, remove enough screws to lower the top assembly down to get to the ADC... --You may need to turn off the fridge now (or do it before you started the previous steps but the light helped me). If you are not using a Wattmeter, I don't think you need to pull the power cord. --The Service Manual next says to attach a Wattmeter to the fridge (and assumedly plug it back in). Most people don't have a Wattmeter...but what I had is a clamp-on ammeter...which you can get as part of "better" multi-meters for well under $100. An ammeter is good enough if you know how to multiply voltage and current to get VA (or approximately) Watts. Any idiot can do this...I think. P(Power) = V x I x pf. What you calculate with VxI is Apparent Power (VA). You convert to "real" power (Watts) by multiplying VA x pf. You generally have to guess at pf, but 0.8 for a motor/compressor is a good approximation and 1.0 for a heater or indandescent light bulb is roughly good. Enough electrical basics... --With Fridge plugged in, and being careful not to touch exposed connections, move the ADC control board so you can gain access to it (2 screws were removed previously to loosen it from the housing at top/back right of fresh food side). The ADC is a small printed ckt board about 3" x 3". --Use a small insulated jumper (or insulated alligator clip) and jumper Pins labeled "L1" and "Test". These are labeled on the PC board and were the two left-most pins, side by side, on my ADC. The Manual doesn't say whether to leave the jumper on or not. I tried both ways and I believe all you need to do is momentarily jumper the two pins (but my ADC wasn't working right, which I will get to later)...so I'm a bit unclear on this part. Also - DO NOT jumper between any other pins, or you may damage the ADC, if it's not toast already. The pins are close together so you need to take some care in doing this. --According to the Service Manual, you should read about 500-600 Watts of total power consumption if the unit is in Defrost mode. I found (referring to the electrical schematic), the main red power wire (ty-wrapped to a green/yellow wire that goes to the main lights). Power is red so it's process of elimination to find the "right" red wire. It's not that hard to figure out. I also confirmed this by playing with the door switch light and watching amps go up and down as I pressed & released the door switch. Ultimately, I measured about 2.2 Amps with the unit working normally (cooling) and 6 Amps in Defrost mode...and about 120 Vac supply. So...VoltsxAmps=VA, which equates to 720VA. I don't know what the power factor of the unit is...but with the compressor and freezer fan off, and only the defrost heater and lights on...the power factor would be close to 1.0. So my reading might have been a touch high but...what it did prove is that a) the heater works (I could feel heat off of it and I had the freezer panel removed and saw it melting ice), and b) the thermostat was working. --I also confirmed proper thermostat operation by measuring it "open" with an ohmmeter after the defrost cycle and measuring it "closed" once it cooled down enough (book says ~ 45F thermostat opens and ~15F it closes (to allow defrost when commanded by ADC). --What I found was that when I jumpered L1 and TEST, the Defrost didn't come on...until I manually turned the Freezer control off - and then back on again. Once I did this it started Defrosting (amps rose from about 2 to 6, compressor and freezer fan shut off and heater started heating. I repeated this twice after waiting for the unit to cool down after the defrost cycle. You can also just unplug the fridge to terminate the Defrost cycle and if the temp hasn't risen above the thermostat setpoint, you can immediately repeat jumper testing as necessary. --The defrost heater stayed on for about 5-8 minutes and after a total of 23 minutes the compressor/fan restarted - which matched what I read somewhere - though doesn't match the ADC Instruction Manual - which I show a website for further down. --So it appears the ADC is just not entering the Defrost cycle but does exit it properly. I believe that my problem is the ADC as I proved the heater works and the thermostat (as I mentioned earlier). Other than bad/intermittent open wiring, there's nothing else in the circuit and I believe I ruled out a bad connection by taking the thermostat connector apart several times and jostling wires up at the ADC to gain access. According to what I can find, the replacement ADC for my unit is Part No. 12002495. One should verify the P/N for their particular model. You can look at the Instruction Sheet here: www.servicematters.com/maytag_library/docs/16023486.pdf. It also has some info on how the ADC is supposed to work...NOTE: You should verify this P/N with someone, as I will before I order it. FYI...at Partselect.com, they show a replacement PN (their #) as PS2061226, for about $61. I've seen various prices on different sites and this was pretty reasonable. Lord knows what Maytag/Sears would charge. Maybe add a "1" to the front? ;) PartSelect also indicates different "Series" numbers for the same PS number for the ADC...not sure about which one I have so Buyer beware, make sure you resolve this before ordering -- I still have to. Anyway, hope this is helpful to someone out there in cyberspace. I will have to confirm my P/N and then buy the ADC. If anyone out there, esp pros, have any suggestions feel free to chime in. Except if you are the guy that told us to defrost our auto defrost fridge to "fix" the problem, for 100 smackers no less. You Sir, should be caned 100 times for being a slug. No economic stimulus for You!
May 16, 2009 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
277 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
