Blower motor for electric furnace
It is a intertherm electric furnace from 1989 i put a new blower moter 3 speed it is only ran for one speed at the unit it does not have any kind of board on the corner its old the wires plug in to it and i looked at it is is only running on one speed med low i just wanted to see if i could hook it up to med hi instead because in the summer the central air does not blow hard anough out of the vents in the floor i think when it was built it only had heat and someone hooked up the air but did not change the fan speed for the air thanks
  • 700 Answers
Yes you can as long as the temperature rise is whithin the proper range in heating on you unit data plate there should be the information the you need to have.
Posted on Mar 21, 2009
Blower moter won't come on on furnace mod# h9mpv075f12d1 New ECM moter and module but it still won't come on?
The motor may have a separate speed control circuit board, that may be the fault.
Jul 19, 2017 | Cars & Trucks
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Oct 24, 2013 | Coleman Intertherm Nordyne Miller Furnace...
How to replace Intertherm M1 Combustion Blower Assembly on an Intertherm M1MB 070A BW Gas Furnace Series #m1D020401209? I think this is the problem. The furnace squeals when turned on and it seems to be...
The combustion blower is easy to replace. You may be able to prolong the life of the motor by applying lubrication to the shaft bearings. If the motor is too far gone then replacing it is the only option. Just remove the screws that mount the blower case to the heater, disconnect the wires and reverse the steps to install a new motor.
May 04, 2017 | Heating & Cooling
My intertherm furnace (old model) has recently getting quite loud and clunky during its heating cycles, sound like the blower maybe??
Your blower motor has several speeds to it and by the problem you are having it sounds as though the blower motor may be going out. The motor has a slower speed for the heating cycle and since you have the noise in the heating mode I suggest having the blower motor changed as soon as possible since it could cause other problems in the heating section of the furnace( possibly burning out the high limit switches). Good Luck on your repairs hope this helped
Dave
Oct 20, 2009 | Intertherm P3RA-048K Air Conditioner
I HAVE AN INTERTHERM FEB-017HAC-04 ELECTRIC FURNACE THAT IS PRODUCING HEAT,BUT THE FAN DOESN'T SEEM TO WANT TO KICK IN. THE BLOWER IS SET TO AUTO.
Probably a time delay relay fan switch not working.
Could be a bad low speed winding in the fan motor.
Set the wall T-stat for ON fan and see if it works.
Mar 02, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm furnace not getting hot after motor swap. PLEASE HELP
You already diagnosed it yourself. The motor may have been the same physical size but it operates at a higher speed and doesn't remove enough heat from the furnace. You need to have the right motor installed period.
Jan 17, 2009 | Intertherm P3RA-048K Air Conditioner
Blower speed
Yes usually the black is high speed, the blue is low and red medium speed. plug the black wire from the fan motor to where the blue wire is, then put the blue where the black wire was
Jan 10, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
106 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
