Question about Royal Alpha 600sc Cash Management System W/ Barcode Scanner
My royal 601sc cash register operates sales but has error when trying to run reports or program, I had previously programmed it with no issues. Any ideas?
I had no issues programming it after purchasing it used, and the normal function works fine. I had noticed my time on receipts was 1 hour off after day light savings time ended and tried to reset it. I just got an error so I left it alone. Now I am trying to run a month end report and once again getting an error, both in X and Z mode.
  • 172 Answers
SOURCE: Teach me how to use a royal alpha 585cx cash
Please click on below link
http://www.royalsupplies.com/cashreg/Instruction%20Manual%20Alpha583cx%20ENGLISH.pdf
OR
Browse royal site & find catalouge or manaul by choosing appropriate model...
http://www.royalsupplies.com/drivers-manuals.html
Thanks for choosing Fixya
Regards
San
Posted on Mar 16, 2011
SOURCE: I have a royal alpha 9500 ml cash register and
the scanner comes with a programming card, just scan the barcode to start programming, then scan the barcode that says usb and then scan the barcode that says end programming, and it will start working again
Posted on Apr 23, 2011
  • 263 Answers
SOURCE: I just received a royal
I researdhed the scanner and found it is not compatable 9500ML I will give you a link and you can see for yourself youwill have to scroll down about half way on the page until you get to your scanner then click on more info
https://www.royalsupplies.com/templates/searchnf.cfm?rowstart=1&globaldesc=na&wherefrom=SHOPFRAME&whichord=8302345&subclass=ALL&subname=na&department=REG&special=R&class=N&nextprev=0&nextrow=!&prevrow=ZZZZZZ&uas=N&zq=80406586&tokns=passed&pagename=Online%20Store%20%3E%20Cash%20Registers
Posted on Aug 26, 2011
SOURCE: Royal 482cx cash register constantly running the reciept motor.
ERror code says Printer overheat! Even when just plugged in. Wont clear. Any solutions?
Posted on Apr 20, 2012
SOURCE: how to program a bar code scanner Model PS700-usb
what if you dont have the program card?
Posted on Sep 07, 2012
How do I put the name of a shop on a receipt?
Hello, Busisiwe -
It seems you need the instruction manual for the Royal Alpha 601sc cash register.
You can find and download one (PDF version - free) here:
https://www.manualslib.com/manual/315391/Royal-601sc.html#manual
Note: You will need Adobe Acrobat Reader software (free).
Be sure to read through the full document first. Then, follow the instructions for setting up the cash register, starting on page 22 (Image 28 in the PDF version.) The instructions for having your business name print at the top of the receipt are "Programming a Header Message" (Page 28 / Image 34.) Your shop name will be "the header message."
Best wishes.
Apr 12, 2018 | Royal Alpha Retail Supplies
How do I get a grand total for just a department from a Royal 210dx cash register.
Are your departments set up properly?
This is how to check:
Running the Department Confirmation Report
You can print a report that shows the programmed information for a range of departments or for all departments. The range report is helpful if you want to see the programmed names of some of the departments, but do not need to see all the departments and other cash register programming.
You can also print a report that shows department information and sales.
For more information, see Running Management Reports on page 85.
Note:
Unless you specify a department range, all departments print in the
Department Range Report. This will take a few minutes.
To run a department confirmation report:
Programming > Department Set Up > Depart Conf Report
1 Press the Main menu (on) key.
2 Press the Arrow Down key to select Programming. Press the Amount Tend Total <Enter> key.
3 If you are prompted for a Manager Passcode, type the passcode number and then press the Check key. If you did not program a Manager Passcode, go to the next step.
4 Press the Arrow Down key to select Department Set up. Press the Amount Tend Total <Enter> key.
5 Press the Arrow Down key to select Depart C onf R eport. Press the Amount Tend Total <Enter> key.
6 Select how you want to see the report. If you select Display, use the arrow keys to review the report in the clerk screen.
https://www.royalsupplies.com/cashreg/1000ML_Instruction_Manual_eng.pdf
Jan 10, 2015 | Retail Supplies
How do I set the sales tax on a royal 500dx
program mode, 1 tax shift, 4 digit rate {8% =8000) amt tend
Nov 20, 2014 | Royal Cash Register 500dx
How to change the date on a royal alpha 601 sc cash register ?
Turn key to Prg mode for date punch in todays date, example June 13 2014 would be 061314 and depress the # key.
The time in Program mode would be for 9:45 Am 0945 and depress the QTY/Date Key. for PM you would use military time such as 3:00 PM would be 1500. Hope this helps.
Jun 11, 2014 | Casio Parts Cash Register PC Desktop
Program tax
Manuals (cost)
They also do casio, TEC,Casio,Sam4s,Epson,Sharp,CAS,NCI,ApexInk,ApexCovers,ApexRolls,Metrologic,Datacap
Systems,Sanyo,Royal Sovereign,Restaurant Edge,Detecto,Uniwell,Datasym,Harbortouch and Telequip.
Cash Register Store Buy Quality Cash Registers Online at Low Prices...
Manuals download
(not free)
ADS Anker,Aster,Casio,Metrologic,Olivetti,Olympia instruction manual,Omron cash register,Royal,Samsung,Sam4s cash
register,Sharp,Tec cash register,Vectron,Walther,Wincor Nixdorf,Machine setups
Not Epson, Apex,Datacap Systems Sam4,CAS,Uniwell,Sanyo,Royal Sovereign,Restaurant Edge,Detecto,Uniwell,Datasym,Harbortouch
and Telequip.
Manuals Downloads
Manuals free view
ABC Office,AMD,AVE,Casio,Delta,Ele,Epson,Goodson Imports,HP (Hewlett-
Packard),Lexmark,Mars,Olivetti,Olympia,Olympia/Luggage,America,Pelco,Philips,POSIFLEX Business Machines,Radio Shack,Royal
Consumer Information, Products,Sam4s,Samsung,Sanyo,Sharp,Sony,Toshiba,Unitech, and Weider
Free Cash Register User Manuals ManualsOnline com
Apr 15, 2014 | Royal Cash Register 500dx
Dboyatawent out of business and put royal 601sc in storage. just open a new \r\nbusiness a couple of year later and pull out my register and I have forgot what I programmed in it. want to program for new...
needs to be ram cleared if it has been sitting in storage awhile...
turn key to program while holding down journal feed button.
after all 0's appear in screen press subtotal
(note, this will clear any programming and totals in the register
Nov 06, 2010 | Casio Parts Cash Register PC Desktop
Cash register PE ondisplay and nothing will work
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall. ***************************************************************************** *****************************************************************************
All of these manuals can be downloaded at: http://the-checkout-tech.com/
royal 110cx User royal 115cx User royal 130cx User royal 425cx User royal 435dx User royal Alpha-580 User Programming royal Alpha-583cx User Programming royal Alpha-600 User Programming royal Alpha-600sc User Programming royal Alpha-601 User Programming royal Alpha-710ml User Programming royal Alpha-9155sc User Programming royal Alpha-9180sc User Programming royal TS4240 User Programming
Mar 02, 2010 | Office Equipment & Supplies
Royal Alpha 601sc cash register won't program.
Hi. I don't have a manual for that model. If you can flick me an electronic version, I'll try to help.
May 27, 2009 | Casio Parts Cash Register PC Desktop
Replacement keys
try bizrate.com or ebay.com
Apr 29, 2009 | Casio Parts Cash Register PC Desktop
Royal Alpha 600sc Cash Management System W/ Barcode Scanner Logo
77 people viewed this question
Top Royal Computers & Internet Experts
Jaime Hernandez
Phillip Whisenant
Phillip Whisenant
Vladimir Frolov
Are you a Royal Computer and Internet Expert? Answer questions, earn points and help others
