Question about Compaq 5188-3722 Hp 92mm/3pin/fan Cooling Fan System 92mm 3-pin Gobi
Computer saids need to replace cooling fan
Compaq presario sr1834nx desktop
  • 2,878 Answers
Replace, but try reconnecting in case of a false warning.
Posted on Nov 30, 2012
The bottom part of the cooling fan has broke and i cant keep the fan in place how do i solve this problem
Once a fan blade is broken the unit will no longer be in balance. The cost is only five dollars, so replace it.
Apr 06, 2014 | Compaq Presario SR1503WM Case Fan |...
Cooling fan for a presario cq5621wm dont work
Central Processing Unit chips have a tendency to overheat when used for long periods of time. This is why virtually all desktop processors come installed with cooling systems that include a cooling fan. However, cooling fans are not invincible. They can burn out if they are not cleaned often and properly. To clean the fan in a Compaq Presario desktop, there is some light disassembling involved to gain access to your computer's CPU fan.
Turn off your Presario desktop and disconnect the power cord from its socket. Wait 10 to 15 minutes before you begin disassembling your computer. Attach an electro-static discharge wrist strap to your wrist and attach the wire clip to the outer casing of the desktop. This helps prevent damage to your computer caused by static electricity. Rotate the desktop so the back panel is facing you. Place the desktop on its left side. Remove the two Phillips-head thumb screws from the right side of the computer's back panel. Grasp the molded grip on the side access panel and slide the panel away from the desktop. This will reveal the interior components of your computer. Locate the cooling fan assembly attached to the back panel of your computer. Grasp the power cable extending from the fan, follow the cable to its connector on the motherboard and disconnect it from the motherboard. Locate the locking tabs on either side of the air duct assembly. Insert a small flat-head screwdriver into the notches on each tab and disengage each tab. Remove the air duct once the air duct assembly comes loose. Repeat this procedure in reverse to install the new cooling fan assembly.
This might not be your specific desktop computer it might give some insight into repair or removal
How to Properly Clean Your Desktop Cooling System & Fan http://www.youtube.com/watch?v=GgOaIJ82gFM&playnext=1&list=PLu_9NJ3Eiy2XGhZxa5wlnkxdPbrJG5hjw&feature=results_main
Feb 22, 2013 | Compaq Computers & Internet
How to replace the integrated ATI Radeon Xpress 200 in Compaq Presario SR1834nx
If the video card is in a pci slot: Just turn off the computer, remove the power card, remove the case. Turn the computer on it's side and there will either be a screw that holds the card in place or a latch with a screw on the back of the computer that hold it. Once you remove what is holding it in the slot simply lift the video card out of the slot.
If the video card is on board then you can still insert another one in the pci slot.
Jun 07, 2012 | Compaq Presario 7470 (163881-004) PC...
The cause of compaq presario fan not spinning and solultion
Most likely the fan has a seized bearing. The fan will need to be replaced.
Sep 07, 2011 | Compaq Presario Fan
I have a Presario S4220NY. Does it have a cooling fan?
Yes it does. it needs a fan to cool the electronic parts. the fact that it makes some sort of noise means its got fan cooling the system thanks
Aug 01, 2011 | Compaq Presario S4220NX (Refurbished)...
Compaq presario cpu cooling fan will not start spinning unless "helped" with tip of pen to spin over.If I dont start it manually,I get No cpu fan message,and shut down.I just replaced fan,as old had broken...
If the CPU fan speed is too slow or not working at all, the computer will shut itself off automatically to prevent damage to CPU from overheating. You may end up having to throw more money at the problem and get a new fan. I went to Compaq's web site, looked up your particualr computer, found out what type of fan you needed, and I did some research. I recommend getting the fan in the following link. It's very cheap, and has good reviews. The other fans on the site all have bad reviews. Hope this helps.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114011
Jan 12, 2010 | Compaq Presario Cooling Fan CPU Heatsink &...
1247 compaq presario
Here is a link to the 14.8v rechargeable replacement here Compaq presario laptop battery , this is for the presario 1200 range of batteries including the 1247
Oct 10, 2008 | HP (158800-001) for Compaq Presario 1246,...
Compaq presario dessktop 5000 series 5330US model#470019-713,Intel Pentium 4
Here is a link which supplys all needed internal parts for you specific computer...
http://www.impactcomputers.com/compaq-presario-5500-desktop-parts-internal-parts-and-assemblies.html
Feb 25, 2008 | Compaq Presario 5000 PC Desktop
Compaq case fan
more than likely 80mm ... measure its diameter with a ruler that has mm on it.
Oct 22, 2007 | Compaq Presario 1626 Cooling Fan Case...
Compaq 5188-3722 Hp 92mm/3pin/fan Cooling Fan System 92mm 3-pin Gobi Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
