Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Air filter for fridgidair refrigerator, where is it located? how do I change it?
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
There is no "air filter" on that unit.
Posted on Nov 30, 2012
How do I change the water and air filters
Don't think there is an air filter. Most modern refrigerators take air in thru the bottom front. Open door(s) and pull out plastic grill from each end. Vacuum this area. Sometimes the water filter is located in upper right inside the frig (turn 1/4 turn to left. Older frigs have external or none
Jan 18, 2015 | Refrigerators
How do I change the air filter
Hello friend, thanks for your post!
In order to change the air filter in your Frigidaire refrigerator you would need to pull the filter out of its housing. Would you be able to provide me with your model number please? Normally you can locate your serial tag (which lists your model number) on the inside right hand wall of your refrigerator. With that I can verify the type of air filter and even provide you with the part number and price of a new replacement filter. I look forward to further assisting you. -Matt
Oct 06, 2014 | Frigidaire Refrigerators
Fridgidaire water dispenser is not getting water.
If you've already changed the valve and the filter we can skip the step to check those. THe next thing to look at is the resevoir for the water. This is located in the refrigeratort side in the lower portion behind the drawers. Sometimes this part freezes, or gets clogged and does not allow water to pass through.
May 26, 2012 | Frigidaire Refrigerators
Water leaking from the water filter inside top right of fridge when getting water on side by side fridgidaire gallery series. How do I correct?
If the filter itself is leaking then you will need to replace the filter, otherwise check the o-rings and lines going to the filter.
Sep 25, 2011 | Frigidaire GLHS38EES Stainless Steel Side...
I own a fridgidaire side by side. the model number is FRS26W2AW9. WE CAN NOT FIND WHERE THE WATER FILTER IS ON THIS UNIT. DO YOU KNOW.
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Sep 04, 2011 | Refrigerators
The unit is only 4 months old. bought from lowes in warsaw in.they dont have a repair or cant replace it out of stock, contaced custermer services . she gave two fridgidair repaire places ,they dont...
Sears sells fridgidair parts. Go to sears .com under there appliance parts. You should Find the part you need. You might want to check to make sure the sensing bulb for the Thermostat is in front of the cooling coil just behind your air filter. If it not located properly It can't properly sense the air temp. And may not shut down .
Aug 28, 2011 | Frigidaire FRA256ST2 WallWindow Air...
Changed my water filter on my Kenmore refrigerator. Now the water dispenser keeps dripping? The water filter is located at the bottom of the frig.
You have air in the line from the new filter . Run about 1-2 quarts of water thru the dispensor to remove the air in the line .
Jun 13, 2010 | Kenmore 57029 Side by Side Refrigerator
Ice smells, and tastes bad...no filter to change?
If you have a silver metal braided line to water source that is your problem. Replace mine with a braided vinyl line and it cured it. ps flush new line for about two minutes.
May 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fridgidaire refrigerator freezing
close the baffle that blows air onto the top shelf a bit.
Or you have a bad thermostat or thermistor- if it's a didital type temp cuicuit
Oct 25, 2007 | Refrigerators
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
77 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
