Question about Belkin (F5D7231-4) Wireless Router
I am not getting a wireless signal from a belkin wireless router.
I can connect through a wire but the wireless light is not on and I am not getting any signal that the router is there from my laptop. It was there fine 2 days ago. I have reset the router to the factory settings and set it up again and there still is no signal. Help?
  • 2 more comments
  • deniseheiss Jan 15, 2009
    Can't connect to internet. I have a new Dell. Works everywhere else but with this Belkin Wireless Router.
  • Anonymous Feb 14, 2009
    i have the same ******* problem Belkin is **** I RECOMMEND DO NOT BUY
  • Anonymous Feb 17, 2009
    same
  • Lamar Ryan
    Lamar Ryan May 11, 2010
    When you reset the router did you find the wireless signal with the defualt wireless name?
    Romeo677
  • 556 Answers
SOURCE: belkin router
A couple of items to check -- these will not fix the issue but may isolate the problem.
Turn all machines on before the test and do not turn off until after
On at least one wired computer that is working and maybe all wireless computers I want you to do the following
Click Start then All Programs then Accessories then Command Prompt
In the window that opens type
ipconfig /all
press enter then record all of the following for each adapter
  • adapter
  • IP address
  • Subnet Mask
  • Default Gateway
  • one or more DNS addresses
The back in the window enter the following command using the default gateway from the wired connection (your router address)
ping (default gateway)
you will either get 4 timeouts -- the connection fails or 4 messages with elapsed times generally measured in ms or milliseconds.
What you are looking for in the above
Good entries base
x.y.x match each other if subnet mask is right
u should be unique for the network
Wired IP address x.y.z.u not 0.0.0.0 may be 192.168.0.u
SubNet Mask ?.?.?.? assuming 255.255.255.0
Default Gateway x.y.z.? not 0.0.0.0 may be 192.168.0.1
DNS addresses ?.?.?.? not 0.0.0.0
where at least one is not zero.
Then wireless entries should be
SubNet Mask same as wired
Default Gateway same as wired
DNS addresses same as wired
If these are wrong there is a configuration error either in the router or wireless adapters depending on how you want your network setup.
each connected adapter wired and each wireless should also
successfully ping the default gateway or router address
If the ipconfig is right and the wired config has successful pings, then every wireless adapter that fails has a wireless config issue.
If you are willing to work through this let me know and reply with information in a comment to this issue.
You may also want to address wireless security
See this response and let me know what you want to do.
Wireless security
Posted on Dec 16, 2007
YourTech
  • 63 Answers
SOURCE: belkin n1 router - wireless light not on - laptop has limited connectivity
If could be that you were unable to reset the router properly. You have to make sure that the router is on while pressing and holding the reset button using a paper clip. the reset button is usually found at the back of the router, then you may have to reconfigure the settings again.
you can also manually access the router page for you to change the settings.
Posted on Oct 06, 2008
  • 82 Answers
SOURCE: Belkin G Wireless Router Not funciontoning: Power Light is Off
Its dead Jim.
I had one of those. Dead.
You can try hitting the reset button. Looking at the back there should be a small hole with a tiny button. Use a staightened paper clip or other object to hold it in for at least 30 seconds. That should set it back to factory defaults.
Doing that brought mine back to life momentarily , but it kept going out after a couple of hours and I had to repeat the process until it finally gave up the ghost for good.
Posted on Mar 05, 2009
  • 67 Answers
SOURCE: Belkin 54G won't connect to the internet
Are you sure your modem is giving a WAN IP from your ISP? Try power-cycling your modem with your router unplugged then bring up your router next, if you havent tried that already... After that try connecting your modem directly to a PC and set your NIC card to DHCP and see if you get an IP address thats routable to the internet (i.e not a private IP)
Posted on Mar 28, 2009
ciscoroute
  • 87 Answers
SOURCE: Belkin router stopped working properly thereis no wireless outpu
have you restarted the router? if so, then see if Belkin offers a firmware update. You will need to connect with a cable to do the update.
Posted on Jun 16, 2009
Why wont the belkin wireless router connect to my wireless mini notebook
Hi i got your issue
Yes, it will not connect in your wireless notebook as this particular model of belkin router is a "wired router" it does not transmit any wirelless signal ......
If you want wireless connection you can look for the new model of routers from BELKIN
Thank you.....
With regards.....
Priya
Oct 03, 2010 | Belkin (F5D5231-4) Router
What is a belkin n wireless usb adapter model # fsd8053v4 used for and can u connect to the internet with it and where do i get the driver?
The wireless adapter is used to connect wireless to the internet, You can use it to make your desktop wireless and laptop.
You can connect to the internet as long as you have a wireless router in your place that will supply the wireless signal.
The driver can be download on this website
http://www.belkin.com/
cheers,
KA
Jun 15, 2010 | Linksys Wireless-G WRT54G Router
Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
Nov 12, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Wireless connection
On your computer, click "view available networks".
Click to select the SSID that you created for your router.
Click CONNECT.
Nov 06, 2009 | Belkin (F5D7231-4) Wireless Router
Belkin router signal not showing up for Wii or Laptop.
If no signal, check router config. Use your
internet browser to look at router's settings.
By default the password on most Belkin routers is left blank, and the default IP address is 192.168.2.1 Check all you router's wireless settings in case disabled or incorrect. Make sure the laptop's wifi button has been toggled to OFF. Routers do die - esp the lowend ones. New wireless G router = $20 on sale.
Jul 07, 2009 | Belkin (F5D5231-4) Router
Belkin Wireless Router F5D8633-4 does not connect to the internet
Try first to connect to the internet using wired connection. If it connects, try to connect on wireless make sure the router is broadcasting signal.
Mar 16, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
My belkin modem/wireless router model number F5D6833-4 will not always connect to the internet by wireless but operates ok from hard wired lead direct form a port ?
belkins antenna are not very good, put the router on a cupboard where the signal is not blocked surrounding it's area, and remember, doors, walls, floors, windows etc all reduce the signal strength.
If the signal gets below 24 MBPS it may not be able to connect you to the net
Aug 18, 2008 | Belkin Computers & Internet
Belkin router54g 75d7230-4
As long as the computer you are connecting has the capability to connect in some form, wireless or wired, you will not have to run the web utility again. However, if you are currently connecting your laptop wirelessly, and you are connecting your other computer with a wired connection, you must make sure that the wired network is not disabled.
May 01, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless router loses light display
I would call Belkin, sounds like a faulty router.
How long have you had it? And what made and model is the router?
Oct 19, 2007 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D7231-4) Wireless Router Logo
161 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
