Clothes have oil spots on them like something is leaking into tub. possible causes? solutions?
    President:
  • Washing Mach... Master
  • 2,651 Answers
Generally oil spots are from leaking transmission fluid, and depending on age ofg machine may or may not be worth repairing
Posted on Jan 11, 2009
MY Estate TGDX640JQ Gas Dryer PROBLEM IS AS FOLLOWS ALL THE CLOTHING GOT BLACK SPOTS ALL OVER (DOESNT COME OUT ) SOMEONE SAID ITS FROM THE DRUM! ANY ADVICE?
It could be your washer leaking oil into the tub
Check paddles inside dryer drum for looseness if something oily got under
the paddles it will leak onto the clothes
Check felt strip at the back (and front) of the tub if it came off it could transmit junk into your dryer
if this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | Estate TGDX640JQ Gas Dryer
Oily spots on clothes after washing, no oil or grease before washing, no hard water...where are the spots comming from. Did not happen with old washing machine
sounds like the seal at the base of the tub is allowing oil to leak from the bearing (that is allowing the tub to spin on the motor shaft.
Not much to do unless you are good with tools and can remove the tub and replace the seal. (This is sorta like the seal between the transmission and engine on a car, or around the main motor bearing)
Feb 03, 2010 | LG WM0642H
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Leaving dirty marks on clothing
Try removing the water hoses and find the screens in each end.. If clogged with gunk - that could be the culpret..
Jul 23, 2009 | Washing Machines
Washing machine is dispersing oil on the clothing. We have taken it apart and cleaned it and have used the special cleaning solution because we thought it was dirty water being dispersed on the clothes...
Number 1 Cause .... using fabric softner in washer it accumilates around the top of the tub and it gets nasty! it depends on what type of machine you have if it is even possible to leak oil into the wash basket
Jul 05, 2009 | Kenmore Washing Machines
I notice when I iron my shirts that there are oil spots on my clothing. It's a clear oil which can't seemed to be removed. Is something like the transmission leaking in the washer? I don't see where...
if it is a ge,maytage ,the oil in the transmission will leak only in the spin cycle and it come out like spots on cloth and u need a new transmission
Jun 18, 2009 | Frigidaire Washing Machines
Oil in the Tub getting on clthes
the oil will be coming from the bearings it usually comes onto clothes as brown rusty colour spots if so change bearings
Dec 20, 2008 | Washing Machines
Spots on clothes
By spots I'm guessing that this is a permanent mark on the cloth. If that's the case, you are possibly putting concentrated liquid bleach into the machine...it is being added and causing the spots. Solution is to dilute the bleach or other concentrated cleaner. If you're adding it manually through a hopper...add it later in the cycle.
If the spots are black...you may have a bearing leak into the machine. Repair is a big job.
Dec 02, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
291 people viewed this question
Top Washing Machines Experts
