Question about Sherwood RX-5502 Receiver
I have a Sherwood RX-5502. When I turn the power on it goes to standby as usual but when I turn on the unit from standby nothing happens. No display, no sound, no register that anything is working. I have had the unit working perfectly for 6 months.
sree-here
  • 61 Answers
SOURCE: Sherwood rv 6030r does not turn on.
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the remote is OK, then the problem with the Remote Sensor or related components of the receiver.
Posted on Mar 11, 2009
  • 7 Answers
SOURCE: sherwood rx-4109 power shuts off
The output transformers may-be gone
looking at +$50 AUS
for just the parts
or a licensed service
for about $150 AUS
Posted on Apr 16, 2009
SOURCE: does a Sherwood rx-4103 have a circuit breaker?
i have the same problem with mine and i cant seem to figure it out... it clicks off around 4 seconds
Posted on Aug 30, 2009
  • 532 Answers
SOURCE: Sherwood RX-5502 receiver - get
After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
There may aIso incorrect selection of the input source. Select the correct input source.
If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
Thanks for using Fixya.
Posted on Jul 11, 2010
SOURCE: Sherwood RX-4105 Receiver will not stay on
you denon guys go into your manuel and look-up protection mode and how to reset your recievers oh did you use the adussey microphone to set it up it will make a world of difference in sound oh i own a home theatyer store in michigan called theaterxtreme 1-248-456-1800 my name is terry
Posted on Mar 05, 2012
Why does it turn on sporadically, stay on briefly, then turn off?
Sounds like a defect to me return it for a working model.
Jun 01, 2015 | Sherwood RX-4105 2-CHANNEL...
I do not know how to hook up the speakers to the back of a sherwood RX-5502
You untighten those connections, i mean really untighten them then you will see that there is a whole that you can feed your wires into once you have unscrewed those inputs far enough.
May 26, 2012 | Sherwood RX-5502 Receiver
I cant get my speaker wires into the back of the receiver
Have you tried makeing sure that the latches, if any, are released or checking if there is something blocking the place where you insert them?
Apr 03, 2012 | Sherwood RX-5502 Receiver
When power is turned on, standby light comes on normally, but in any playing mode, the receiver switches off and the standby light flashes.
It looks like this is a common problem with a lot of the Sherwood Receivers. I've had the same problem with my R-125RDS for a while now. Finally hit on solution today by replacing a power transistor. The transistor in question is not on the power amp board but instead screwed to the chassis and wired to the mainboard. I believe it is part of the output short protection circuit. In my case the component was a 2SD2059 (silicon NPN 100V,5A) replaced by equivalent 2SD1407. The transistor seems to run pretty warm so I guess this is why they ultimately fail after a few years.
Sep 17, 2011 | Sherwood RX-5502 Receiver
Unable to connect speaker wires to back of Sherwood 5502 receiver (no way to get them toi stay in)
If you unscrew the red and black knobs a few turns you will expose a small hole that is drilled through each post. Insert the twisted bare wire end into the appropriate hole and tighten the black or red knob to secure it.
Or get connectors as in this article...
http://www.crutchfield.com/S-gtpAzL9W1OZ/learn/learningcenter/home/speakers_wire.html
Jun 07, 2011 | Sherwood RX-5502 Receiver
Hello, I have a Sherwood RX-5502 and currently have a pair of 8Ohm speakers hooked up to the SPEAKER A terminals. Can I hook up a pair of 4Ohm speakers to the SPEAKER B terminals without issue from...
The statement on page 7 might allow enough wiggle room for a single pair of 4-ohm speakers used alone. Procede with caution and don't try to blow the walls down with them. Monitor for excessive heat or strain and if it clips or self-protects back off.
http://www.sherwoodusa.com/pdf/RX-5502(A).pdf
May 30, 2011 | Sherwood RX-5502 Receiver
I would like to connect my powered subwoofer (Atlantic Technology model 212 SB) to my Sherwood RX5502 receiver. Unfortunately, the receiver has no subwoofer outputs, only speaker outputs, and the...
Cables between sources and compatible units rarely need to be physically modified.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RX-5502-Receivers-manual/id/3124dj384/t/2/
http://www.retrevo.com/support/Atlantic-Technology-212-SB-Subwoofers-manual/id/866dj197/t/2/
Splicing headphone outputs designed for nominal 8-ohm impedance speakers to a 47K-ohm (typical) RCA load is not a good idea but it might work on the Sherwood because this receiver does not automatically silence your other speakers when the headphone jack is installed.
There is NO other volume-controlled output to choose. Try it.
Mar 25, 2011 | Sherwood RX-5502 Receiver
Sherwood RX-5502 receiver - get no sound.. checked polarity - OK... replaced speaker wire - OK... checked speakers on another device - OK.... tried phono and tuner and cd player - no sound with any........
Jul 11, 2010 | Sherwood RX-5502 Receiver
Sorry to be the bearer of bad news but your unit has either a bad power supply or bad transistors and need serviced. Under 200 for the repair however, I'm not sure what the unit sells for new but weight the costs vs replacement. Hope this helps
Jun 06, 2009 | Sherwood RX-4105 Receiver
Sherwood rx4103
i have the same problem with mine... its anoying is there like a reset on this item?
Apr 03, 2006 | Sherwood RX-4103 Receiver
Sherwood RX-5502 Receiver Logo
162 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
