Question about Singer Sewing Machines
Singer 630 repair manual/foot pedal foot pedal sticking
JeremySew
  • 65 Answers
SOURCE: foot pedal not working
You can purchase that singer sewing machine foot control here:
http://www.sewingpartsdirect.com/foot-control-w-cord-singer-979314-031.aspx
Posted on Apr 21, 2009
  • 5 Answers
SOURCE: singer 2010 doesn't want to stop
I have a Singer Merritt 4530.  I don't know if the foot pedal works the same way on your model, but on mine it is held together not by screws or latches, but simply by white plastic rods that serve as hinges.  These rods have a hole drilled in their center, presumably so some special tool can be used to pull them out.  Lacking a special tool, I glued a nail into the hole, and once the glue dries you can pull the nail and pull the rod out with it.  The rod is about an inch long and held in place merely by friction - no glue or screw threads.  Once one rod is removed, you should be able to slide the pedal off of the rod on the other side, though that might have only worked because some of the plastic housing was cracked on mine.  If you don't want to take the time to test that, just glue a nail into both rods and pull them both out.
Once you get the pedal open, mine had a giant white cylinder that looks kind of like a battery or a fuse.  This thing was getting very hot the longer the pedal was left plugged in.  I read on many web sites that this object can cause overheating or short circuit the pedal so it's always sewing.  It's called a suppressor and can be safely thrown away.  I haven't found an explanation for precisely what it does or why it can be safely thrown away, but I theorize it's a surge suppressor and that most modern wiring isn't going to surge too much.  I got rid of it and the pedal still works and doesn't overheat.  It may be safest to plug the machine into a surge-protected power strip once the suppressor is gone - just my theory.
Posted on Jun 16, 2009
SOURCE: just bought a used model singer 6233 need to know
The Singer 6233 was one of the models that briefly were made using air-powered foot controls. So you aren't looking for a traditional electrical connection. Instead, your pedal cord's female end will connect onto a black male nipple, that sticks out on the right side of the machine (the side with the handwheel). Just push it on until it feels snug.
Posted on Jun 01, 2010
  • 109 Answers
SOURCE: Singer 2259 - The machine has stopped moving, the
Check to see if you have your bobbin winder on. That's usually the problem. Just push it to the left and you should be ok.
Posted on Sep 11, 2010
  • 111 Answers
SOURCE: trouble shooting a Singer Athena
Yes it's true, most parts are not available for this machine anymore. You might try to push the red reset button on the bottom of the machine. Also make sure that the reset button is not being depressed by anything that the machine is sitting on, and that the reset button pushes in and out freelyl.
Posted on Apr 30, 2011
When the machine is on doesn't stop.
Soraia, sewing machine pedal may be sticking, inspect it while unplugged to see if the spring loaded action and the button under pedal is moving freely, if not try a few drops of oil on pedal hinge and button. If all appears to be good, have pedal repaired/replaced as it is probably an internal transformer issue inside the pedal.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.thesewingforum.co.uk/showthread.php?t=29533
Old Singer foot pedal problem
How to Repair the Foot Control on Your Sewing Machine
Apr 26, 2016 | Sewing Machines
Foot pedal does not operate needle
[PDF]INSTRUCTION MANUAL - Singer
www.singerco.com/uploads/download/445_4830_4832.pdf
around the sewing machine needle. ... ings of the machine and foot controller ... The spool does not turn. 7. ... Note: Do not operate machine without fabric.
Oct 29, 2015 | Singer 3116 Simple
Singer electric sewing machine 2 01-2 know it didn't work no electricity going in to sewing machine.Is there away I check the power cord and how do you put together the foot pedal
for workshop manuals go google and type in --workshop manual for singer sewing machine 2 01-2-- and download the pdf version page
take the power lead and foot control to a sewing machine repair shop ( anyone) and have it tested
Oct 07, 2015 | Singer Sewing Machines
Where can I find a power cord for singer simple 3116 sewing machine?
It looks like your power cord and foot pedal are incorporated into one unit, and you'll have to replace the foot pedal to get it. You can get it for $30 at sewing parts online, http://www.sewingpartsonline.com/singer-3116-simple-sewing-machine-parts.aspx?gclid=CLTXmrLC18ECFeHm7AodBioADg, and you can also get them from eBay by doing a search on Singer Simple 3116.
Oct 16, 2014 | Singer 3116 Simple
Wiring diagram model 7466 i am trying to reconnect a foot pedal on my singer sewing machineu
The foot pedal is generally plugged in on the right side of your machine. There should be a hole that matches the end of the plug. The user's manual is available as a free download on Singer's site.
Sep 22, 2014 | Singer Sewing Machines
Need foot pedal control for singer 766
try calling or email these sites and ask them about the part
sewvacdoctor.com
a1sewingmachines.com
Feb 10, 2013 | Singer Sewing Machines
How to repair a non-working foot peddle on a Singer 6215C
There are a few things you can do. If you are even a little technically savvy, UNPLUG the sewing machine then take a detailed look at the pedal cord from the pedal all the way to the machine and check for any damage, pinch points, etc. If it all looks good, you should be able to open the foot pedal to see inside. There should be a small limit switch that actuates when the foot pedal is depressed. Manually cycle the pedal to ensure that the pedal mechanism is making contact with the limit switch. Listen to the limit switch as it should click when you first engage the pedal. I cannot tell you exactly what you would have to do to replace the pedal but after you have exhausted what I have suggested, I would take it to a sew & vac shop and they can replace it for you. It should not be that expensive. You can call one or two shops and get quotes for replacing the pedal.
Nov 16, 2017 | Sewing Machines
Just bought a used model singer 6233 need to know where foot pedal plugs in
May 10, 2010 | Sewing Machines
My singer touch & sew suddenly didn't stop
There might be something jamming the petal open so it won't slow or stop when you put your foot on it.. I would try that, get some canned air and blow it out and see if it helps.
Apr 28, 2009 | Singer 1120 Mechanical Sewing Machine
Sewing Machines Logo
54 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
