Question about Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel
Oven glass, black paint in or out?
I've replaced my glass, but the rough side is out. It is completely cool when the oven is 400 degrees. Is this correct??
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Smooth side goes to the outside.
Posted on Nov 30, 2012
  • glad2bechris
    glad2bechris Nov 30, 2012
    I was afraid of that...thanks. I was replacing an exploded glass so didn't have a guide. .
  • Richard Roth
    Richard Roth Nov 30, 2012
    You are quite welcome. Thanks for using FixYa!
Black & Decker Toaster Oven CTO650 ... Numbers around dials has worn off. Where can I get a replacement panel?
Search Results
    Black & Decker CTO650 1500 Watts Toaster Oven - Read ...
    www.epinion.com/.../Black_Decker_CTO650_Toaster_Oven.../3529132...
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints Is it really ... Cons:Numbers wear off around dials after years of wiping. ... It has a see-through glass door, 30 minute timer, variable temp up to 450 degrees F and signal bell.
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints i should'a bought this one Is it ... Cons: Numbers wear off around dials after years of wiping. .... It hasa 4-slice or 9 pizza capacity and touch button controls with LCD display.
Jan 28, 2016 | Toaster Ovens
Have a frigidaire wall oven that won't get to 400 degrees
Hello Bruce Hubley, thanks for your post!
Based off the information you have provided your Frigidaire wall oven will not heat up higher than 400 degrees. It may be a problem with your thermostat or control panel. I would recommend performing a reset on your oven and you can do that by disconnecting power from your oven for roughly ten minutes. If this does not help correct your issue I would suggest having a professional come out to provide the proper repairs on your oven. Best of luck! -Matt
Jan 25, 2015 | Frigidaire Ovens
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
Walls too damaged to paint
Use drywall mudd. Its cheap, easy to apply and sands to a smooth surface.
https://www.thisoldhouse.com/how-to/how-to-finish-drywall
Apr 20, 2017 | Microwave Ovens
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Oven temp is inconsistent. Sometimes it works but most of the time it doesn't. Yesterday we set it at 350 degrees. Two hours later it only came up to 250 degrees. I've replaced the oven sensor but...
Is this a gas oven? gas ovens rely on ignitor/glowbar ignition. The system uses amp draw to open the gas valve. If the ignitor is off a tad in amp draw then kickin or bangin on the stove sometimes makes that puppy work.
Jul 20, 2011 | Kitchen Ranges
After baking at 425 degrees, ew30mc65js2 will not shut off - fan continues to run and some heat, although lower, continues after 1.5 hours
Hi - if you still have your user manual I think you will find that oven have a time delay designed into the electronics for cool down purposes after the cycles completed. If it does shutdown after say 1.5hrs, it may seem a bit long but its actually doing what its designed to do, it should not be heating but circulating the hot air thru the oven.
We use to have a similar problem with our F & P BI600 wall oven - what we've done is have the door slightly ajar to quicken the cool down process until one day the fan ran continously - then I had it disconnected.
I hope this may help with your situation, if its running continously then its best to disconnect the cool down fan, the bake fan is normally on a separate circuit and not affected.
Jul 13, 2011 | Electrolux Ovens
I lost the instructions on how to bake my Lil' Cupcake 1st Birthday Signature Plate from Celebrate Express. All the signatures are there, I just need to know what temperature to set the oven and how to...
I found the answer for this (I was looking too and saw your post) today on the company site that made the plate. it was in the FAQ section - but choose the link under the question about using the paint pen. Here's what it said:
Once paint is dry, it is smudge proof to the touch and safe for travel, but it is not yet permanent.
To make permanent, once your personalization is complete, allow paint to dry for 24 hours.
After 24 hours, place the item in a room temperature oven and then heat oven to 300 degrees, so that the item heats slowly along with the oven.
Once oven reaches 300 degrees, bake item for 35 minutes and then turn oven off.
Allow item to cool to room temperature inside the oven, at which time it may be removed.
Paint is now permanent, food and dishwasher safe!
Hope this helps!
Jun 12, 2011 | Celebrate Express Lil Cupcake 1st Birthday...
I need to replace the seal AND the inner door glass on my Jenn-Air sve47600 range. Haven't found anything online that helps with the glass replacement. Another question: above the oven door (and...
Hello & Welcome to FixYa
The heating issue can be caused by the oven temp sensor that is bad and needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement. You can view this video for glass replacement:
Please get back to me if you have any other questions.
Kevin
May 28, 2011 | Kitchen Ranges
Kitchen aid, self cleaning
The only solution is to get a new oven, The paint in the oven burned off, and now the electic board is burning out. This oven when it hits about 400 degrees it makes this chemical plastic smell, and at selfcleaning it makes the same smell for 3 1/2 hours, and come to find out it burned the paint off
Jan 04, 2009 | KitchenAid Architect Series KEBC107KSS...
Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel Logo
290 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
