Question about LG LRE30451 Electric Kitchen Range
LG LRE30451 won't maintain temperature
Our LG range is 4-5 years old. For the past year or so I've noticed things were taking longer and longer to cook. I shut the oven off once and reset it and the temperature had dropped almost 100 degrees. Now I have to re-start the overn every 15-20 mins to 'force' it to return to temp. Anyone else had this problem or know how to fix it?
    Top Expert:
  • LG Master
  • 9,472 Answers
Check the oven temperature probe (thermister) to see if it is good. To check it, use a multi-meter and Ohm it out. It should be between 1100 and 1600 Ohms. If it is out of tolerance, you will need to replace it. Here is the part to order.
Posted on Nov 30, 2012
  • actoy
    actoy Nov 30, 2012
    That would be awesome if that's all it is! Thanks for the suggestion, we'll test it... Have a great weekend!! :)
  • Richard Roth
    Richard Roth Dec 01, 2012
    Please keep me posted and you have a great weekend also!
5 Suggested Answers
SOURCE: LG Range Element Will Not Heat
on my 30755 top left element will turn on but not adjust top right turns on to high only will not adjust . 3months out of warenty
Posted on Dec 14, 2008
  • 161 Answers
SOURCE: LG Range Touchpad Not Working
The touch mebrane is faulty and needs to be replaced.
Posted on Jan 22, 2010
SOURCE: Hi, My LG Dual Convection oven is taking over one
mine too. it took 2 hrs to get to 300. Self cleaning does not get hot enough to clean. it seemed to work for a day after that, but is not working again. i got the error F-7 but can't locate my book to see what that means. the stove is only 1 year old....have you found an answer to your problem??
Posted on Apr 12, 2010
SOURCE: range top front burner will not shut off, stays on
I have the same problem with the LG LSB5682SW Electric Range - Font Left Burner will not go off / stays on high. This is very dangerous. LG customer service is horrendous. I think it is time for a recall before someone's house burns down!
Posted on Dec 21, 2010
Maytag MIR8890AS0 6.2 cu.ft. induction range w/true convection. Takes an hour or more for oven to pre heat, doesn't maintain heat. 4 yrs old. Induction top OK.
I don't know, but it sounds like one of the heating elements are burnt out/no longer working. I had a similiar problem 5 years ago.. they're pretty easy to replace yourself if you are handy and have a screw driver. I think the one for my stove cost $18 to replace (5 years ago) here's the trouble shooting guide online for you model:
Maytag Range Stove Oven MIR8890AS0Troubleshooting Repair Help
Dec 07, 2016 | Maytag Kitchen Ranges
Our LG tv has started making a vibrating whistling sound when you first cut it on, you can hear it get faster and faster then slowly goes away.. Also over the past few months I've notices the picture
the picture getting darker means the lamp has aged and u need to replace it another thing u need ti replace the mirrors in the light tunnel of the light engine they have faded secondly the noise means the colour wheel has aged you need to replace it u will have to replace the whole light engine cos the color wheel comes inbuilt the light engine and u will be ok ontact lg dealer in your area
Jul 19, 2013 | Televison & Video
Screen won't light up
If your phone screen won't light up then you will need to take the phone into to a repair store unless your phone is less than a year old. All cellphones have a manufacturer's warranty or if you have insurance on the phone. If its less than a year old then take it to your provider in the store because it falls under lg to fix/replace your phone.
Oct 10, 2011 | LG Shine KE970 Cellular Phone
I have a Kenmore 54701 70 pint dehumidifier about 4/5 years. It has worked well until recently. It is hooked up to a garden hose into a drain. I noticed water was dripping from the housing. The drain is...
Marco, There are 4 things than can cause the problem. All are solvable.
1. The air intake filter is dirty or clogged. Remove and clean the filter if necessary.
2. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
3. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
4. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 19, 2011 | Kenmore 54701 Dehumidifier
Deumidifier is running but the bucket won't collect any water. I've set the desired humidity level to 35% (ambient humdity is 75%) as well as cleaned the filter
There are 5 basic, yet solvable reason for what you described. The first 2, you have already covered. If our unit is operating in a basement, pay close attention to # 5.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
5. Ambient air temperature at floor level is between 40 - 60 degrees.
level
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this was of help to you. Thanks for choosing FixYa.
Jul 24, 2011 | LG LHD45EL Dehumidifier
We've only had our dehumidifier for 3 years. It runs but does not collect water.... LG model #LH45E-LT8
Usually there are 5 basic causes for what you have described. They are all solvable. Pay particular attention to numbers 1 & 2.
2. Air intake filter is dirty or clogged. Turn unit OFF, remove and clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean
5. Ambient air temperature at floor level is between 40 - 60 degrees F. Dehumidifiers do not work
well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to
basement applications, where the air temperature at floor level is colder than at shoulder level.
Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks
Jun 20, 2011 | Dehumidifiers
One-year old LG humidifier (LD450EAL) runs but no water is being extracted from the air - the hose outlet is dry. The hose is connected properly, and the compressor sounds like it's running, not just...
Alan, it may simply be a case of several things, that can easily corrected at home.
1. The Humidity Extraction Level is set to High. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Remove, inspect the filter and clean if necessary. It it's a
Washable Filter, allow it to thoroughly dry before reinstalling it.
3. Obstructed Air Flow. A minimum of 12" to 18" clear air around the entire unit, must be
maintained.
4. The ambient air temperature at floor level is between 40 - 60 degrees F. This is particularly true in
basement applications. The air temp at floor level is colder than the air temp at shoulder level.
Dehumidifiers don't work well in that temperature range (Unless, it's a Low Temp model). Raise
the unit up off the floor on to a sturdy table, counter top, etc, that can handle the weight of the
unit, plus a full tank of water.
If you troubleshoot the 4 things listed above, it may quickly solve the problem. Please let me know. Thanks.
Jun 18, 2011 | LG Dehumidifiers
I have a Fedders dehumidifer model # A70145D2A-A-R. It is a few years old and it's worked pretty great but now it just runs continuously and no moisture is gathered. What can I do to fix it? I was...
You'd be hard pressed to find a Fedders like yours. They've been out of business for several years.
There are several basic things that can cause what you described.
1. The humidity extraction level is improperly set. Lower the level to 32-35%
2. A dirty of clogged air intake filter. Turn the unit OFF unplug it and remove the filter for cleaning.
3. Obstructed air space. A dehumidifier requires a minimum of 12" clear air space around the entire
unit.
4. The ambient air temperature at floor level is between 40 & 60 Degrees F. Dehumidifiers do not work well in that temperature (Except low temp models). This especially true in a basement application, because the air temperature at floor level is colder than say, chest level. Raising the unit up off the floor onto a sturdy table, cabinet top, etc, that can handle the weight of the unit, plus a full tank of water, will normally resolve that problem.
5. The cooling coils are dirty and need to be cleaned.
Critical problems:
1 The humidity sensor has failed an needs to be replaced.
2.The compressor is low on refrigerant gas and needs to be recharged.
Sometimes the repairs (Time spent finding, the Parts & labor), if necessary, can cost almost as much or as much as a new unit, which would have a full warranty.
Hope this helped you troubleshoot the basic and solvable problems and you won't need to make any critical repairs. Please let me know. Thanks.
Jun 16, 2011 | Fedders R6DH45X Dehumidifier
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
Sep 03, 2009 | LG LRE30451 Electric Kitchen Range
LG LRE30451 Electric Kitchen Range Logo
252 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
