Question about Pinnacle Dazzle DVD Recorder
DVD recorder I installed the program as instructed.I installed rca jacks(red/white) to audio & installed video cord.For a brief moment I had a picture then it went black but I was still hearing the audio from the VHS next step was to pick the drive for the recording but my the Picture was still blacked out.Tried 3 other video cords with no success.
  • 27 Answers
Please try to update the driver of your dazzle device.
1. Plug in the hardware.
2. open control panel and go to system and maintenance
3. in system and maintenance, click on the system icon
4. Once the system window open kindly find the device manager and click it.
5. once the device manager is opened , go to the sound, video and game controllers category.
6. Under sound, video and category right click the pinnacle DVC device and choose properties
7. once properties window is opened go to the drivers tab
8. in the drivers tab, uninstall the driver.
9. if you have 2 entries for the pinnacle DVC device kindly uninstall both.
10. unplug the hardware.
11. restart the PC
12. If you have the PCLEUSB2x32.exe file saved on your PC kindly run it. if not kindly download it from this link:
Dazzle drivers
http://cdn.pinnaclesys.com/SupportFiles/Hardware_Installer/readmeHW10.htm
13. Once you run the PCLEUSB2x32.exe and it asked you to modify, repair or remove, kindly remove it. and restart the PC.
14. Once restarted, run again the PCLEUSB2x32.exe to install the driver. then restart the PC after installing.
15. After restarting, plug in the hardware device and it should install the driver of the device automatically.
16. after it installed automatically it should say that the device is ready for use.
17. Now try again with the software.
Posted on Mar 05, 2009
Connecting dvd player to a television need a diagram t.u
If you are going to hook up the DVD player to your TV through RCA cords, see the picture below.
Hook up the yellow RCA cord at the Video-in at the back of the TV and the other end at the Video out of the DVD player to get the video.
Hook up the red RCA cord at the Audio-in(right channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Hook up the white/black RCA cord at the Audio-in(left channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Red and white/black RCA cord is for the sound.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 07, 2011 | Televison & Video
How do you hook up this dvd player to the tv. the plugs are blue green and red instead of white yellow and red
The DVD player has component video as well as the S-video and RCA video and two RCA audio outputs.
If your player is the same as my picture, the component video jacks are in a horizontal line at the top of the back of the player. The white and red audio jacks are in a vertical line to the left. The yellow video out jack is in the second line just below the component video jacks (in a line with the coax port, the S-video port is in between the coax and the RCA video out). (The white jack is at the top left of the connections block, red below that, and yellow to the right of the red.)
I hope this helps.
May 29, 2010 | RCA DRC247N DVD Player
Elgato EyeTV (T5301LL/A) Video Capture: I have an old camcorder - with only a yellow video...
If you have just one Audio Out RCA jack then the camcorder only recorded in MONO, so all you would need to do is either plug the wire coming from your single Audio Out jack into the left or white input jack of your Capture Device which may have an option in the software program to set it to recieve audio in MONO, or you can buy a RCA Jack Splitter that goes from a single Female RCA jack on one end and 2 Male RCA Jacks on the other end. Then you take the end of the Splitter with 2 plugs and plug one of them into the White Jack and the other into the Red Jack on your Capture Device, and the other end with just one plug should plug into the cord coming from the Black Jack on your Camcorder.
May 16, 2010 | Apple Elgato EyeTV (T5301LL/A) Video...
Can't find the correct way to hook up my vcr to my dvd recorder to record vhs to dvd disc. could someone please give me some instuctions on hookup please. thanks
connect yellow, red, and white RCA jacks (video, audio rt and lt) to the "out" on the VCR. If your VCR isn't stereo it will only have one audio plug.
Connect the other end of the jacks 9yellow, red, and white) to the "in" jacks probably marked Aux in, on the DVD recorder.
Now follow the instructions on the DVD recorder to set to Aux in (some have two aux front and back). Should have a button for it on the remote.
With the dvd, tv , and vcr on, you should see the VCR on the screen. Start the tape and press record on the dvd, you are set.
Mar 02, 2010 | Televison & Video
Can you put a phillips dvdr610 onto a television with built in freeview and then record from it. If so how?
If your TV has an OUTPUT MONITOR Output Jacks, Yellow, (Video) Red (Audio) & White (Audio) FEMALE RCA Jacks.Then these will output WHATEVER is showing on the TV screen. And can be used as an Output for any Recording Viewing device. There will be other, FEMALE RCA Jacks,AV, Yellow, (Video) Red (Audio) & White (Audio) and possibly also The Composite Video, Red, Green, Blue, all Video, These are INPUTS, they will be there also. Make sure.
Feb 16, 2010 | Philips DVDR610 DVD Recorder
How do I get sounds when I use the red green blue rca hook ups?
The red, blue and green RCA hook up is just video. You must also use the red and white pair of RCA jacks for the audio. You can usually find the audio red and white jacks right below the video red, blue and green RCA jacks. Get yourself an audio RCA cord with the red and white connectors and run that from your video device audio output to the audio input of the TV that corresponds with the video input of the TV. An example would be if the red, blue and green are on the "Video 1" input of your TV you will find the red and white audio input for "Video 1" right below or right next to the video inputs.
The red, blue and green video jacks are called "component video" and they only have a video signal for high definition video, so you must also run a separate audio line for it. The same holds true for the yellow video RCA connector, that one is called "composite video" and it also has only a video signal with no audio.
I hope this helps, if so a "FixYa!" rating would be very much appreciated.
If you need more help just post your concerns right here onthis thread.
Dave
Nov 28, 2008 | Initial DTV-171 17 in. TV/DVD Combo
Can't get any sound
No, it doesn't need infrared headphones, but it does need to have all audio connection made properly. There is a controller that this was designed to use, model number CY-VM1500. That controller has speaker outputs on it, and the CX-DV1500 must have the RCA audio output jack (red and white rca jacks) connected to the RCA audio input jacks of the CX-DV1500
if you have found this to be helpful, a good rating would be appreciated. Let me know if you require any further help.
You can find the instruction manual at this url:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/Mobile-Video/DVD/model.CX-DV1500
Jun 22, 2008 | Panasonic CX-DV1500 Car Video Player
I have a older Sony TV. I want to connect my magnavox dvd and older surround sound and my DISH network together. I need a diagram or step-by-step instructions as I am NOT literate to hooking these...
I will ilustrate how you do this .. first your magnavox dvd has a cord,has three defferent color of RCA jack yellow ,red and white,yellow is for video,red is for the rigth speaker and white for the left speaker. the video or yellow cord is input to the TV in the VIDEO 1 section the red and white cord is input to your old surround sound, next is your DISH network the output cord is going to input to the VIDEO 2 section in TV.. the video cord color yellow and the red and white to the is going to input in old surround sound, and the out of your old surround is for the speakers...if happens that your sound is one input by a Y RCA jack ,Y jack HAVE ONE INPUT and two output,,,feel free for asking question for further assistance in the future rate me a fixya.....
Jun 19, 2008 | Audio Players & Recorders
No sound
The S-Video cord is for the picture only. You must connect the audio out behind the dvd player (the red and white jack) using a double male-to-male RCA cable to the" Audio In" in the TV to get sound.
Mar 18, 2008 | Panasonic DVD-RV31 DVD Player
No sound
I know everyone is going to say check you audio cable in back, but also what kind the cable jack is. there is one called an "S VIDEO" that will give a great picture but unless you are aware of what it is you would not realize you have to use the red and white "RCA" audio jacks in addition to it.
Dec 21, 2007 | Aspire Digital AD-8091 DVD Recorder
Pinnacle Dazzle DVD Recorder Logo
280 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
