Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
E2 error code singer 7258 - Singer CE-200 Quantum Futura Computerized Sewing Machine
2 Suggested Answers
  • 1788 Answers
SOURCE: My new Singer Stylist 7258 keeps getting a message
I looked in my manual, it says that C4 means that the thread is tangled or there bobbin was interrupted forcibly. Turn off and totally rethread your machine with presser foot up, insert a new needle and try again. Do this test, with the presser foot up, pull top thread, it should move easily, now lower presser foot, pull thread, it should barely move. This should seat the thread in the tension discs properly. I have this same machine, and love it.
Posted on Mar 14, 2011
Getting E5 error on my Singer 7258. do not see what this error is in the manual ?? thanks
Search for:
Make Model error code
https://www.amazon.com/ask/questions/Tx3GAGCLDSNETC8?_encoding=UTF8&sort=helpful
Aug 29, 2017 | Singer Sewing Machines
I have E7 and machine won't work????
E7 sounds like an error code. First step is to look it up in your owner's manual.
Aug 26, 2014 | Singer Sewing Machines
Singer 7258 bobbin filling issues
If it is new, it is defective, return it for service or replacement.
Mar 23, 2014 | Singer 7462 Mechanical Sewing Machine
Singer stylist E2 error code bobbin winding
I have just repaired a 7258 with a frozen bearing unrelated to the E2 code except that I thought I would lube the entire machine while it was apart, and through my ignorance, I greased the clutch that releases the mainshaft when winding the bobbin, and then when the clutch wasn't working correctly, caused the E2 error. I can say the E2 error is not caused by a plug not seated correctly, too much tension in the bobbin thread, or God having a bad day. The E2 error code is thrown when the bobbin holder is in the wind position, and the mainshaft rotates. There is a clutch just behind the hand knob on the right side of the machine, and if it has too much lubrication with a stiff grease, or on an older machine, if the lube has dried out, the clutch will not release properly. I took the clutch apart, cleaned the grease I put in it, and then lubed it with bicycle silicone oil. It now works as designed. The hardest part of the repair was figuring out how the plastic cases split apart! If anyone in the SF Bay Area has a 7256, or 7258 that gives the E2 code, I can fix it - it's actually kind 'a fun...
Feb 08, 2013 | Singer Sewing Machines
Singer 7258 error e2 when winding bobbin
I had this problem too. What I did was turn the post the bobbin sits on to the left (lefty-loosy) and kept re-booting the sewing machine until the bobbin started to spin correctly and the needle disengaged! I was so happy I figured it out, I did not want to return the sewing machine.
Nov 09, 2012 | Singer 7258 Sewing Machine
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
169 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
