My centrex air con shoes e6 and e7 and does not work why
HELLO,
I HAVE A CENTREX AIR CON UNIT AS WELL.. I HAVE NOT TURNED IT ON SINCE LAST SUMMER.. THE REMOTE IS WORKING BUT I'M NOT ABLE TO TURN THE UNIT ON.. I ASSUME IF IT'S ON A SMALL LIGHT SHOULD COME ON.
WHERE IS THE POWER SWITCH AND IS THERE A MANUAL WAY TO TURN IT ON FROM THE UNIT?
THANKS,
B
Posted on Dec 20, 2012
3 Suggested Answers
ranger25
  • 72 Answers
SOURCE: Air con
Could be the thermostat or the low voltage line to the outside. Usually a dog chews through it or the weedeater hits it and breaks connection. Turn on cool, go outside and see if it gets 24 volts to the two wires going to contactor (have to take off cover to get to it) DO NOT TOUCH THE CONTACTOR IT HAS 240 V AT ALL TIMES, unless disconnect is thrown, so turn it off. If you aren't getting anything, then it's either the low voltage wire broken somewhere or the thermostat malfunctioning. Make sure you turn off the inside unit before messing with thermostat or you will pop the transformer. If it pulls the contactor in, and you still aren't getting anything, then check for voltage on the load side of contactor (opposite from the inlet or lead side). If you are and you hear a hum from the compressor and the condensing fan motor is running, then it's your compressor. You'll have to remove the top cover to do the next step. Check to see if it when to ground by using a meter set on resistance and with the connector to the compressor removed, put one lead on one of the copper pipes going up to it and touch the other lead against any or all of the pinouts on the compressor. If you get a reading, it went to ground and you will need a new compressor or whole new condensing unit, depending on the age of the one you have now.
Posted on Jan 27, 2008
hvac1960
  • 2133 Answers
SOURCE: i have a centrex air con.. and i dont know what to
In your remote, there is mode button, the symbols for each option will display. The symbols are:
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.To get proper cold air set temp 23 degree and mode"cool". To get heat set temp minimum 3 degree more than room temp and mode in "Heat"
Posted on Feb 02, 2011
Voltas verticool showing e6 unit not working !! What happend?
From search I found that on a Mitsubishi it said e6 and e7 that is an indoor/outdoor communication error. I had that happen once when I installed one of these split units, got e6 and realized I forgot to connect the wire on the indoor part, that triggers the outside to go on when thermostat inside starts the cooling cycle. Maybe a wire pulled loose. There was terminal blocks on each unit on one I hooked up, check breakers too.
May 03, 2016 | Heating & Cooling
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
Centrex CTAR60GW not working
maybe you don-t respect the polarity(+ - )on the remote control or a imperfect contact on battery
Dec 04, 2013 | Haier hwr10xc6 Air Conditioner
E7
short cycleing is sounds like, could be a bad cap, or alot of diffrent things...its not easy to diagnose on line, your gonna have to call a tech, sorry i couldnt do more 8(
Jun 18, 2013 | Heating & Cooling
My lifespan treadmill has error code e6, what does this mean?
hello,kindly download the below file... it explains ur error and how to rectify it
http://www.body-solid.co.uk/body-solidUK_download/pdf_docs/tr-20(1)E6+E7(XT-27_33_56_57_7600).PDF
thank you for using FixYa,Thanks,Reymond
Oct 19, 2011 | Exercise & Fitness
Getting a part
yes and i would buy direct to save money. try centrex.com and look for repair parts. have your model and serial number handy.
Dec 15, 2009 | Heating & Cooling
Error E6
thank you have a nice day
May 04, 2009 | Exercise & Fitness
Centrex CTAR65GW reverse cycle air con. missing remote control -
Thanks for your response, but we finally found a universal remote through Andca Airconditioning in Rosebud, Victoria. It cost us $90 and worked a treat.
Thanks and regards
Wendy
Jan 07, 2009 | Heating & Cooling
Eurovox codes
new codes for 5a 01 north east
e7 d3 69 2e 6f 38 ea 78
a1 38 06 29 24 29 8d 2b
recoded mine @1800 29/01/09
happy viewing.
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Centrex split system air conditioner
I have a centrex split system which the inside unit is working but the outside one the motor is not working does anyone know why and where can i get parts from sice centrex no longer exists..
Nov 18, 2007 | Heating & Cooling
Heating & Cooling Logo
151 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
