Question about GE Profile Wizard DPSE592EAWW Electric Dryer
I have a GE Profile DPSQ475ETWW. It wasn't heating so I took it appart found two breaks in the heating element so I bought a re-string kit... put it back together and now it works but I'm having a problem with the drum belt slipping. not sure if the cork or rubber side of the belt should be facing the drum.
  • mesellers Jan 11, 2009
    Thank you djz, we're good now.
HOT DO I PUT A HEATING ELEMENT IN A GE WIZARD DRYER
Posted on Apr 06, 2010
    President:
  • GE Master
  • 1,922 Answers
The rib side goes on the motor pulley which should have the same amount of grooves as the belt,the flat side(no grooves) goes on the idler pulley and from install is pretty much forward so the belt isn't twisted anyplace
Posted on Aug 22, 2009
    New Friend:
  • 88 Answers
The rubber side with the ridges should be on the drum
Posted on Jan 11, 2009
GE profile dryer,Runs fine but no heat
need to have the heat element checked with a multimeter and visually if u can and look for burns and corrosion and breaking of the wire connections. Also have the thermostats checked, Im assuming its electric and not gas? the thermal cut off may be bad and the hi-lo thermostat, these can shut heat off from the dryer. Ive replaced the element on my G.E profile and it wasn't all that hard rather simple.
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
GE profile dishwasher is not cleaning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dishwasher Residue and Film on Dishes
Jan 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
No heat in dryer, sparks coming from heater
Hi and welcome to FixYa, I am Kelly. The symptom you describe is typical of a broken heating element. The heating element on GE models comes as an assembly. Item 1215 of this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=208108&diagram_id=21357126#d21357126
Your dryer has a single element and I do not know of a single element "re-string" element kit for the single element dryers. You may be able to contact a local appliance parts & repair source to find the roughly $40.00 element only replacement part. As far as I know the "element only" has been dis-continued. Sadly this reults in a substantial cost to the consumer to purchase the whole assembly at $160 - $172.00. There may be new old stocks still on the shelf somewhere for the element only. I would at least make a few local appliance repair parts calls before ordering the assembly.
Just doing the math as to what you may expect to have the dryer repaired by a technician.
Costs:
Service call $50 - 75.00
Labor $100.00 (Average)
Part: $160.00 + shipping / tax
Your looking at nearly a $300.00 repair on the low end of costs and they only go up from there. (Just being VERY honest)
The can be additional problems that are found like a belt, idler, drum guide, or a blower fan. Often elements fail due to poor airflow that is caused by either blocked air flow or a broken blower fan.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | GE DSXH43EAWW Electric Dryer
Can't get soapy film off that is left on dishes on GE Profile, GSD4310z02aa using jet dry, liquid dishwashing soap and have cleaned dishwasher with a dishwasher cleaning product. ~Cathy
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 24, 2010 | GE Dishwashers
Location of element how do i remove it from the front or back
the element is behind the drum,you must first remove the screws holding the front panel on at the floor area,then lift forward and up like a car hood,then remove top cover screws underneath top cover and lift up like a car hood and secure in upright position as not to tear wire harness,then remove the drum belt and pull drum out of unit,the element can now be accessed and you can order an element re-string kit usually about $25 and re-string the new heating coil yourself
May 09, 2010 | GE DVLR223 Dryers
GE Profile Wall Oven Circuit Board
http://www.searspartsdirect.com/partsdirect
I HAVE QUESTIONS. THIS THERE 240 VOLTS AC TO OVEN. YOU MAY HAVE A BREAKER PROBLEM. FLIP THE BREAKER BACK AND FORTH 3-5 TIMES FAST TO GET IT TO RESET. IF THE LAST THING YOU DID WAS A SELF CLEAN THEN YOU MAY HAVE A SAFETY THERMOSTAT PROBLEM. IF YOU CANNOT FIND THE WHOLE MODEL NUMBER ON THIS SITE CALL 1-800-GECARES THEY WILL HELP YOU WITH PARTS
Apr 25, 2010 | GE Profile JTP18 Electric Single Oven
I have a ge profile and it is not cleaning the dishes this unit is 6 yr old
heatman101
k757
Feb 21, 2010 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishes and glasses on the top rack aren't getting clean. Soap left in dispenser cup after cycle GE PDW8200
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
i
May 02, 2009 | GE 24 in. Profile PDW7800 Built-in...
Hello, My GE Profile dryer model DPXR47EW0WW serial TV771164A has stopped heating. What should I be checking? Thanks, Bob
open it up - take the drum out - the heating element is there - check the wire for breaks - then there are three fuses - if the heating element does not have any breaks - take the fuses to a parts store and have them checked.
Jan 24, 2009 | GE Profile DPSB619ED Electric Dryer
GE Profile Wizard DPSE592EAWW Electric Dryer Logo
167 people viewed this question
Top GE Dryers Experts
Richard Roth
Richard Roth
Melissa Martin
Melissa Martin
ancel1961
Level 1 Expert
Are you a GE Dryer Expert? Answer questions, earn points and help others
