Question about Frigidaire Refrigerators
My fridsgidair fridge model #frt21il6jb2 doesnt freeze ice cream.temp gets to around 0 degrees or a little less but ice cream is too soft.frost builds up on the back bottom right side of freezer.
  • 1 more comment
  • Juan Rodriguez Nov 30, 2012
    today i have remove item from the freezer and melted the frost and ice with a hair dryer.turned it back on,has been runing for bout 6 hours but the freezer still doesnt get low enough.
    i failed to mention that this past weekend i decided to move the fridge fwd and vacuum all lint buid up from the back bottom condensor/compressor area.after doing so i plugged it back in and it did not start up again even thoufgh the lights worked .i couldnt hear the fridge start up again. i had also poured warm/hot water on the back corner of the freezer comp to remove/thaw frost/ice build up.i notice a pan on the bottom of the refridgerator was filled with water and a drain was dripping water onto it.so i think the drain is clear.i started to take apart a plastic channel about 6 inches wide and the depth of the fridge from the ceiling of the refridgerator.i saw what looked like a timer .i turned it ever so slightly and the fridge kicked on.should i have turned the timer switch a full turn ?did i do something wrong by unsyncronizing the defrost timer and the compressor?
  • Juan Rodriguez Dec 15, 2012
    correction the freezer's temp is around 30-35.i found the hanging thermometer was faulty.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
No, the defrost timer will be OK. You will need to replace the "defrost thermostat" on the unit. Here is the part to order.
Posted on Nov 30, 2012
  • 12 more comments
  • Juan Rodriguez Dec 04, 2012
    is this defrost thermostat simple to replace?
  • Richard Roth
    Richard Roth Dec 04, 2012
    It is simple. Just remove the back panel of the freezer and you will see attached to the coils.
  • Juan Rodriguez Dec 06, 2012
    i have ordered the thermostat .will install and see if does the trick once installed.
  • Richard Roth
    Richard Roth Dec 06, 2012
    Ok, keep me posted.
  • Juan Rodriguez Dec 13, 2012
    installed new thermostat.I guess I have to wait and see.
    ithas been about 9 hours since i installed th defrost timer.the back wall is starting to build up frost again.not sure what to do next.
    correction defrost thermostat.
    removed all food items from freezer.removed back plate assy,disconected heater strip and did an ohm check;it read about 33 ohms.not sure f that is aceptable.
  • Richard Roth
    Richard Roth Dec 14, 2012
    If the heater had continuity it is good. It has to be the defrost thermostat.
  • Juan Rodriguez Dec 14, 2012
    defrost thermostat was replaced.no frost build up anymore.freezer temp s 35 fridge temp is 45.
  • Juan Rodriguez Dec 16, 2012
    doyou have any other ideas i could try?
    the back of the freezer doesnt loo like it is building up frost anymore but the freezer doesnt drop to 0 degrees it staysaroud 32-35 degrees
  • Richard Roth
    Richard Roth Dec 16, 2012
    Is the fan in the freezer blowing really well?
  • Juan Rodriguez Dec 17, 2012
    yes the fan is blowing like it did when new.
4 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: Viking freezer frost build-up
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 21, 2008
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
  • 56 Answers
SOURCE: Refrigerator won't cool and freezer has ice build up on back.
its a defrst problem most likely the defrost thermister wr55x10025
Posted on Jun 30, 2009
Why won't my Fridge/freezer, freeze ice cream? But freezes popsicles and meat, model number MTB2195AE* Im GUESSING its the defrost control that needs to be replaced? NO ICE build up.
Your have a good idea re the defrost timer. But there is also a thermostat that turns the compressor back on when the temp hits a certain point during the defrost cycle and defeat the normal cycle.. Check that out.
Mar 24, 2017 | Refrigerators
Ice block
There is some cooling in the freezer which is allowing the temp to raise above freezing for a brief period. Check gaskets and or the temp setting. Is ice cream hard or soft. Ice cream freezes at around 15-18 degrees. My guess is that the door gasket is allowing air inside the box.
Feb 03, 2013 | Samsung RF265AA Bottom Freezer French Door...
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
If you need any further assistacne please feel free to comment me.
Jul 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Water leaks inside
It's due to wrong temp setting and malfunction of defrost cycling. Keep thermostat setting at 5 degree or little less. And don't keep it in minus,as defrost cycle will take longer time. And also you will get less cooling in fridge compartment and also water leaks.Check drain line hose may freezed. And also freezer tray get blocked due to over frosting around freezer. Defrost manually by unplug your fridge and after defrost all ices, plug again and keep correct temp setting. Thanks.
Feb 01, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Aug 06, 2009 | Sub-Zero Bottom Freezer Refrigerator
This is a simple question. What is the average
Not so simple actually. Depends for long lasting, deep freeze, meat ect you want 0 to -4 Farenheit. For Ice cream (non-defrosting) soft 20 to 24 degrees firm 15-19 degreees, hard same as meat. For defrosting models stick with the 0 to -4 as otherwise ice cream and other liquids will actually melt during the warmest part of the defrost cycle. I believe that is a self defrosting model so I'd stick to 0 degrees farenheit average.
May 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore Fridge (bottom freezer type) not freezing
Look for problems you can see. Check for frost on the back wall of the freezer, If you find frost on the back wall locate the defrost timer and rotate the clutch head screw clockwise SLOWLY until you hear one click. With the timer now in the defrost position you will hear sounds in the freezer compartment such as expansion, sizzling, after a few minutes. If after say 25-30 minutes the system does not return to cooling mode ( Compressor starting) rotate the timer again SLOWLY until you hear a second click. This would indicate a bad defrost timer. If you get no defrost your problem could be a defect in the heater circuit such as an open heater or defrost thermostat. Normal defrost time would be 18-22 minutes.
May 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
138 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
