Question about As Seen On TV Living Pure Pro Series 4-in-1 Heater
My living pure heater wont heat up after a breaker tripped
    Problem Solver:
  • 5 Answers
Contact Seasonaire to replace your unit. They now take care of the warranties for Living Pure
Posted on Nov 06, 2013
  • blalockt Oct 08, 2014
    seasonaire doesn't respond either
Dryer drum turns fine, light on, but no heat.
could be thermostat or bad heater or the door switch or the breaker has tripped one leg
Nov 01, 2015 | Dryers
My spa flips breaker at the 6 pm circulation. Why?
Does it trip on other programmed cycles? Or, do you only have the one circulation time? This one is odd, if it only trips during one of multiple cycles. It could happen this way: if you have two or more cycles programmed, and only the one 6:00 cycle has the option for the heater to come on, then you could have a bad heater element? But the situation would have to have the spa in economy mode. Because heater will work only when timed filter cycles are activated, and if a demand for heat is registered, the heater will come on,and in your case, breaker will trip. If in standard mode, the breaker will trip any time the spa comes on, when a demand for heat is registered, this is called "heat call" or call for heat. Good luck
Feb 28, 2015 | Pool & Spa
Holmes hch6150 will not produce heat
Without having the heater to tear apart to see what is not working, you may try the following. Your heater is a 1500 watt heater and pulls about 13 amps of current. If you plug it into a recepticle that is already have load turned on, most recepticle circuits are rated for 15 amps and you have probably tripped the breaker for this circuit. Check your breaker panel to see if a breaker is tripped. If it has tripped, this will tell you your pulling to much current. Try another circuit that allows the heater to operate or find the other load on the circuit that is causing the breaker to trip. By the way to reset the breaker take the breaker to full off, this resets the trip, and then turn it back to on.
Hope this helps
Feb 13, 2015 | Heating & Cooling
Eemax280t2t no hot water
see if the circuit breaker switch has tripped either partially or fully and reset it. Check for bad or loose wiring on the heater and breakers. The next thing is more likely the heating element is no good and needs repaired or the heater needs replaced.
Jan 30, 2014 | Eemax Water Heaters
Electric shower just installed cuts out at fusebox after being on for about a minute
10-20-12
Circuit breaker is tripping on electric shower?
This could be absolute danger until more information is known.
1) Breakers trip because they sense heat, because the wire size is too small, or breaker size is mismatched with wire. Or breaker is loose on busbar.
Copy following links to determine correct wiring and breaker:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
GFCI circuit breaker will trip because of same heat condition described above, and also trip if ground fault is detected.
Water leaking into element will trip GFCI.
Absolutely you need to get this problem fixed before shower is put back into service.
Call electrician, or the installer, or the manufacturer, or all.
http://waterheatertimer.org/How-to-wire-GFCI.html#spa
Oct 18, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
I have a rheem 81VP2S Electric water heater it keeps tripping the circuit breaker. If I flip the breaker back on it will run for a bit then trip again. Or the breaker will trip If I I plug it in when it is...
Hi , when a breaker trips immediately, that can indicate a problem in the circuit. But the circuit stays on for a bit , then trips, so there is a problem with the heater. Could be that a thermoastat or heating element is shorted out. You can replace these items yourself, I would check the heat element first. Or there may be some corosion residue around the heater terminals.
Apr 02, 2010 | Rheem 81VP2S Point-of-Use Electric Water...
Dryer won't heat up but tumbles. What could be
you could have a bad heating element, a tripped circuit breaker, a blown fuse in the dryer or a bad timer. you can check the element and fuses/ thermostats with an ohm meter for continuity.
Sep 17, 2009 | Dryers
Circuit breaker trips on electric hot water heater circuit
Check the voltage at the water heater. Sounds like the element is burnt out and is tripping the breaker.
If it is more then 5 years old I would check.install a new heating element.
Mar 27, 2009 | RELIANCE ELECTRIC WATER HEATER
Water heater trip circuit breaker
I would say you have a bad element in the bottom.If the water is cold and heat until the top thermostat reach it tempture,then switch the bottom element and then the breaker trip.So replace the bottom element.
Mar 09, 2009 | Rheem 81VP6S/430126 Water Heater
3 bsbrd heaters connected to one therostat(honeywell) trips main
I had this problem once in an apartment I own. it was an EXTREMELY ease fix. my problem as that the set screws in the breakers were not tightened enough, and would cause heat to build up, and trip the breakers. so..... first try to tighten the set screws on your breakers.
Jan 16, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
As Seen On TV Living Pure Pro Series 4-in-1 Heater Logo
180 people viewed this question
Top As Seen On TV Televison & Video Experts
Andrew Taylor
Andrew Taylor
Are you an As Seen On TV Televison and Video Expert? Answer questions, earn points and help others
