Find aspen filter pad
I need four aspen wood filter pads for my Convair coolers. Who can supply new ones? Does the baby bottle cleaning tablet work? Do I put it in the cooler, or must I remove the pad first?
SOURCE: AC pad not fully getting saturated with water
1. Make sure the pump is getting plenty of water.
2. Make sure the pump is working.
3. Check the pvc pipe with drip holes are not plug. (above the pads )
4. Check the pads directional arrow that should be facing up. When pads are initially installed you can see arrows on the pads. The arrows should be in the up direction. That will allow the pads to get saturated more efficiently.
I hope these steps help you.
Jerry,
Posted on May 08, 2009
Ed Phillips
  • 11 Answers
SOURCE: New Mastercool pads smell bad
The cellulose pads in a mastercool are glued together and usually the adhesive is what you smell. It may take a while for it to go away. Strange as it may seem, as the pads get more mineralization and you use it more the smell will go away. Do not use a cooler for your whole house without plenty of exhaust through a window or an updux. Coolers work best when there is plenty of freely moving air.
Posted on May 31, 2009
  • 7 Answers
SOURCE: We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Posted on Aug 07, 2009
  • 6 Answers
SOURCE: I NEED PADS FOR MY ADOBE AIR MW5500?
Cooler pads for Mastercool MW5500.
Posted on Feb 15, 2010
SOURCE: how do you add water to the convair 600 personal
were to put the water model m3000ul
Posted on May 30, 2011
How to descale an water cooler pad?
Hello, Here is website for the recommendations for cleaning water cooler pad. How do you clean swamp cooler pad Ask com
Nov 06, 2014 | Windex Multi Task with Vinegar, 32 oz....
Where can I get a new aspen pad for a convair polar pride cooler?
This Aspen pad is avalable from a couple of sites, including Amazon which ships from hardwarehabitat.com, also from onlinehardwarestore. I used the following argument to search: "CONVAIR" ASPEN PAD COOLER REPLACEMENT PAD It is getting more difficult to find, mine is 7 years old. best of luck!
Jul 01, 2012 | Heating & Cooling
New pads smell like urine. What can be done to eliminate this horrible odor?
Try some Downy fabric softener. Or replace them with Aspen pads.Thank you for choosing FixYa.com
May 18, 2011 | Mastercool 67471 Evaporative Cooler Air...
I have a mastercool cooler and i need to clean the pads. in the past i have tried soaking in a clr solution but it dont help. any tricks to do this would be great. the calcium and other deposits just stay...
CLEANING PADS
My pads are 3 years old. (1) I tried soaking them in Vinegar & water which helped. (2) I then sprayed them with a hose nozzle, that helped also. We live in AZ so the dust storms can be horrendous and I still had build up. (3) So I took a variable speed drill and a wire brush and removed more. (4) Then ,as these filters are made of a wood by product, I took a belt sander ...they look good now. (5) Now when I reinstall them I am going to change the pads so pads facing outside will be facing inside, keeping the 45 degree forward and down. This last step I haven't tried, but it should work.
Mar 18, 2011 | Mastercool 67471 Evaporative Cooler Air...
How do you clean the baby pro bottle warmer?
Ice container, measuring containers, and baskets: Dishwasher-safe (top rack only).
Measuring containers should be placed in a dishwasher basket. Or wash in warm water
using mild liquid soap. Rinse with clear water.
Bottle Warmer unit and removable cooler: Always turn OFF and unplug before cleaning.
Wipe surface of unit as well as inside of cooler and cooler lid, and inside of warming
chamber with a damp cloth or sponge using mild liquid soap. Wipe with clear water. Air dry.
Do not immerse in water. Do not use scouring pads, solvents, or abrasive cleaners, as
these could damage the unit.
Warming chamber (optional): Mineral deposits (usually white in color) may form on the
inner surfaces of the warming chamber and can cause damage to the unit. To remove them:
1. Unplug the unit.
2. Remove the basket, and wash separately as indicated above.
3. Pour 2 oz. vinegar into the warming chamber and let it stand for an hour or two (longer if
necessary).
4. Pour out the vinegar and rinse the chamber two or three times by pouring in, then
emptying out, 3 or 4 oz. of plain tap water. Do not immerse the Bottle Warmer in water.
Wipe dry or air dry.
Aug 21, 2010 | Avent Philips iQ Bottle Warmer without...
What do i need to do for a convair classic portable cooler, to care for/service it? (as it is smelling at the moment!) Convair Classic M800CAUS; Product no. 007410
we always used 1 baby bottle steralising tablet to sterlise them , best to do this outside to avoid the chlorine /swimming pool smell in the house
then flush all the solution away and replace with fresh water ( the solution is quite corrosive and cause rust ) , also check your pads for dust/limescale , you may well need to replace these
Nov 13, 2009 | Heating & Cooling
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Apr 21, 2009 | Mastercool 67471 Evaporative Cooler Air...
My convair millenia is not working well
we drained the water and fill it up again and started to worf fine. we think that maybe we filled it up too much. thank you
Jun 29, 2008 | Dryers
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
