Question about Gateway NV55C03u Laptop
No bootable device
First i removed hard driv becuz it said frozen password so i followed that advic it cleared but still wont reboot says no bootable device
How do i clear all forgotten passwords ,including dell security manager authentication password (bios)
with the power off and unplugged disconnect the hard drive for the computer. now reboot and go into the bios and try to clear the password. If it is stall asking for a password with the hard drive disconnected then clear the bios password by the jumper on the motherboard. for the cmos reset. If that does not clear it. remove the button battery and wait 5 minutes and reinsert battery and try again.
you also may have a hdd password if you do then re-post for directions on how to remove hdd passwords. Good Luck.
Nov 01, 2015 | Dell OptiPlex 3020 Desktop Computer -...
My pc wont boot. All i get is " reboot and select proper boot device or insert boot media in selected boot device and press a key"
This can happen if you have non-bootable media in the default boot device (i.e., you have a CD in the CD/DVD drive and that drive is listed as the default boot device in your system's BIOS). More often (on newer systems), a failed hard drive will also produce this message.
If you have bootable media (the Windows install CD is one example), you should try to boot to it and see if you can read your hard drive.
Jan 20, 2014 | Computers & Internet
Cannot login to computer due to forgotten windows password no cd drive
That' nothing.
The easiest way to reset a forgotten Windows password I ever use is to use Windows Password Reset ,just a few steps:
Step 1: Download and install Windows Password Deluxe
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove windows password.
Have a try.
May 24, 2012 | Acer Aspire One Netbook 8.9" Notebook
Forgot user password
I met the same difficulty for the previous period,and I know the easy
and effive method that you can use Windows Password Reset to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset from windowspasswordreset.net and install it on your computer.
Tip2:Burn Windows Password Reset to CD/DVD or USB.
Tip3:Insert newly created CD/DVD or USB to your computer which you forgot its password and reboot it,and follow the instruction that follows.
I hope you can reset windows password soon.
May 21, 2012 | Advent Computers & Internet
Reset password
You can reset laptop password by the following steps,
Step 1: Download the above Windows Password Reset Tool setup file and install it.
Step 2: Launch Windows Password Recovery Enterprise and create a windows password reset bootable USB pen drive to make the application Bootable. All this steps should be done on any computer you have access to.
Step 3: Now go to the locked computer and insert the Bootable Windows password reset pen drive you just created.
Step 4: Reboot the locked computer and follow the instructions to reset forgotten windows administrator password.
May 20, 2012 | Acer Computers & Internet
My hp pavilion a1110n is frozen on the blue screen and it won't reboot. I've tried to use the command keys but it does not respond.
To solve a frozen screen error, please run a bootable windows XP and repair "c/windows" on the hard drive. Follow the instructions carefully and let the system restart and proceed. Use the key written on the XP CD. After repairing, please an Anti virus (Kaspersky 7 or 2010).
Good Luck!
Jun 17, 2010 | HP Pavilion a1110n (PX743AA) PC Desktop
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
Mar 02, 2010 | Computers & Internet
Hp Pavillion dv2000 Bios Password
Hello Kanzki.
I understand that you cannot remove the password from the BIOS of your notebook.
Please go through this link and follow the steps to reset your bios..
http://www.tech-faq.com/reset-bios-password.shtml
Feb 14, 2009 | HP Pavilion dv2000t Notebook
Hdd password frozen on laptop
Remove your hard drive.Reboot computer.
While its rebooting press F2 to enter the BIOS
Press Alt-F to restore BIOS defaults
Replace the hard drive
Sometimes your computer vendor ( Dell, HP. etc)
maybe able to reset HDD pwd depending on model
Jan 04, 2009 | Computers & Internet
Our office assitant just left and her password to get into windows vista doesn't work anymore. How can we get around this?
inside the case, on the motherboard is a password jumper. Remove the jumper, reboot the computer. That should erase all O/S passwords. The jumper should be labeled in tiny letters PWD or something similar.
Nov 19, 2008 | Computers & Internet
Gateway NV55C03u Laptop Logo
44 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
