Question about DXG Technology DVC-202V Digital Camera
My camera not coming on
What shall i do next my battery is full charge?
    Problem Solver:
  • 16 Answers
I understand that not all batteries will drive all cameras. Ensure that you are using the exact type as stated in the camera manual..... this could resolve your problem.
Hope this helps
G
Posted on Jan 11, 2009
My one camera wont work anymore
Check camera charger output voltage with multimeter. If there is no problem with charger; charge camera battery to full charge. As a next step; check your camera battery voltage with multimeter. If battery is dead, replace battery with new one.
Nov 17, 2014 | Uniden Wireless Video Security Camera...
CAMERA M425 HP PHOTOSMART
use AA duracell batteries with high amps.
that would help you
Sep 16, 2008 | HP Photosmart M425 Digital Camera
Panasonic 102b
FOLLOW this steps and fix it. God bless you
Fully charge the Sony digital Handycam. If the camera is not powering on or shutting down during the middle of a shoot, it is due to the battery. If the battery is unable to hold a charge (this occurs after a few years of use) you must replace the lithium-ion batter.
· 2
Press the "Menu" button if no audio is recording on the video camera. Choose the "Record" feature, then select "Audio." Oftentimes the audio comes (or is accidentally turned) off. Select the "On" option and exit out of the menu. Now all future recordings capture audio in addition to video.
· 3 Delete unwanted video files if your hard drive is full. When the internal hard drive is full you receive an error message stating the camcorder is unable to capture more footage. Bring up the "View" option on the camera, then select a video file you no longer want and choose "Delete."
· 4
Turn off the video camera and remove the battery. Wait a few minutes before inserting the battery back into the camera. If the menu or any other internal hardware on the computer is malfunctioning performing this reset corrects the problem.
· 5
Upload the video content from your camera to a computer via FireWire cable instead of USB. When using USB the quality is downgraded as it is unable to support the higher data stream required to upload videos. If you don't have a FireWire port on the computer (it is similar in size to a USB connection, but one size is curved and a "Y" icon is printed next to it) you will have to use the USB connection.
Nov 07, 2013 | Video Cameras
Very low battery life
I have the same camera. It sounds to me that there is a fault with the camera itself and not the battery. You might be better sending Canon an email and asking them. My battery lasts forever so I would think if you already purchased another battery you've eliminated that problem. It might be the contacts inside the camera that are not accepting the full charge. Does the camera battery on screen show that it's full after you've charged it? Maybe trying charging it overnight and then trying it out the next day.
Dec 27, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
Recording images and camera seemed to freeze
Sounds like it failed to write and then your battery ran out. Have you tried charging the battery back up?
Mar 06, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
My camera often a time switch off, i change the battery. but continuously switch off what shall i do?
Assuming that your new battery is the correct type for the camera and that it is fresh/fully charged, your problem may be due tocorrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 12, 2009 | Largan Chameleon XP Digital Camera
I also have Casio Exilim EXZ75 I didn't charged it for almost 3 weeks and once I charged it, the red light flashes on and off... Then I inserted it in the camera... it still doesn't work... how can I solve...
kindly leave the battery for long duration in charging position let the red light blink and then see after like 16 hours or 24 hours if it works and charge otherwise change the battery with the same specs , and next time when u leave battery for long duration likea month or weeks charge it to full or half so it can hold some power to re charge again , ur battery is in Coma state nearly dead so it might come back or not
pls rate me well
Regards
Zohail
Aug 11, 2009 | Casio Cameras
DMC Tz3 will not power up. Battery is fully charged. sometimes when it does come on it will not read card and will have to reset date and time.
First remove the SD card in case it is defective itself causing the camera to act funny. Next, your symptoms are indicative of a bad, not fully charged, or intermittent battery contact with camera's contacts.
Clean batt contacts using a clean pencil erasure.
If this doesn't work, measure a fully charged battery's voltage on the battery pos(+) and neg(-) terminals. It should be 4VDC. If less than 3.8, I would be suspicious it is not taking a full charge.
New batteries on ebay are cheap, and would not be a loss since you can always use backup batteries if you get another TZ camera. Or, you could just sell your camera to a repairman in an ebay auction, keeping your batteries and accessories, and buying a used working one with accessories cheap.
Feb 24, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
False low battery warning
Same thing happened to me when I used alkaline batteries. Have you tried fully charged NiMH? If not you may have a "leak". Your next option is the service center.
Jun 27, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Battery charging
I was charging newly purchase camera for hours, then I realized my battery was in upside-down. It took approx 2 hours to fully charge once I fixed the battery install!
Dec 03, 2007 | Jazz DV-179 Digital Camera
DXG Technology DVC-202V Digital Camera Logo
51 people viewed this question
Top DXG Technology Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a DXG Technology Camera Expert? Answer questions, earn points and help others
