Just loaded new ram on desktop. Notice slight changes on a few programs. Should I have saved these on a USB?
  • 7,627 Answers
Adding New Memory Mods should not have any effect on Programs, that I am aware of.
Posted on Nov 30, 2012
Cannot play videogames
I'll assume that your notebook is otherwise working fine. Generally most laptops will play simple games with no problems. They do not have the hardware to run something demanding such as Call of Duty. I don't know what version of windows you have but I think the 530 should have come with Vista. Vista is a wee bit of a resource hog so that is one problem. You only have 512mb of ram and that really isn't enough to run Vista let alone something demanding such as a game. The 530 supports up to 2gb of system ram and that is important for a few reasons. First you need to have enough to let Vista run properly and that will use everything you can give it. If you could get it over 1gb you would notice a substantial increase in performance. The last and biggest problem is the video hardware. In this laptop is uses shared memory. This means it does not have dedicated fast video ram but instead relies on the using the system ram. So while you might have 512 of system ram the video card will take probably about 64 mb of that. If you update it to say 2gb then this can increase to a max of I think 225mb. That sounds like a lot but it is shared slower system ram. You do find new gamer laptops with high spec video chips and dedicated vram but even those do not perform as well as a desktop with the same or smaller amount of video ram. Unlike a desktop you cannot change out the video on a laptop so what you have your are stuck with. When it comes to gaming especially something like first person shooters the video card is the key to everything. I have a dual core laptop with 4gb of ram a very stripped down version of windows and 1gb of system ram dedicated to the video. I also have a old 2.8ghz single core pentium with 1gb of system ram but it has a new 1gb video card (important as these have a video processor and do not use the system one) and this does play call of duty at 60-100fps and anything else I can find to try on it. I tried the video card as an $75 experiment as I was about to replace the system. I didn't do that. It makes that much of a difference.
I hesitate to call these fixes as they really won't get you what you want out of any laptop with similar hardware like yours. That really isn't possible because of the slower system ram and shared ram probllems. The first thing is to max out the ram. It will cost a few dollars but then you can max out the size of the shared video ram.Nothing else will have as much effect as doing this to your laptop. Turn off anything you can in vista to speed up performance. It probably has most of it turned off now due to the low ram you have. Disable anything you don't need running. Fir instance office and adobe will load speed loaders at boot up. They are supposed to make these pop open faster. Disable them and you won;t notice the difference for those programs but you will in the system resources they consume. Also make sure anything like msn or yaho do not start with windows. msmessenger especially can at times be a real hog for resources. There are very few programs that ever need to load something at start up to run. Most are for convenience and each then steals resources. Not a big deal if you are not gaming and have plenty to spare but in your case very important. If you are dealing with simple games such as web based card games then usually the issue is with jave. You may need to download and install the java package from sun. As I mentioned you can't really make it into a hardcore gamer machine but hopefully you can see what the problems are to doing that with almost any laptop (not just yours).
Dec 27, 2011 | HP 530 Notebook PC
Tip
PC faster Trick
how do the pc faster withe the notepad?
1)open notepad and clear everything
2)type these "mystring=(80000000)"
3)save it to desktop :"ram.vbe"
4)go to desktop and double click it and there you go, you will notice your computer is alot faster and internet brows does take as long to load
on Sep 10, 2010 | Computers & Internet
My computer is an inspiron 1501 with a Mobile AMD Sempron1.58GHz 896 MB ram. It is a work computer, so I can't add RAM; mainly, I am looking for a way to cleanse and speed up what I've got. In the...
Please follow the follow steps to improve your system performance...
** Do not have too many desktop icons .. try to minimise them
** Click Start and go to run option and type msconfig and hit enter. You will get a window with the program list.. Please deselect the programs which you donot want to be loaded in the startup(ideally the ones you might use rarely). Then save the changes and reboot the machine..
** Right click on MY COMPUTER and then click on properties . Then go to the Advanced tab and click the tab that reads Settings under "Performance" . You would get a window where you will have to once again select the tab "advanced" . Click on the tab that reads Change under Virtual Memory and you would get another window where you can select the option that read " System Managed Size" and then click on "Set". Then click on apply and ok at the bottom of the windows. Restart the PC to have the changes effected.
May 31, 2011 | Dell InspironTM 1501 Notebook
845gvm motherboard dead.no beep heard after removing ddr1 ram. how to confirm problem in ram or mbd mahesh maharashtra
Install your ram in another computer,
Or install an another new ram in your pc
If you want to know details can follow the bellow step,
Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios load fail save default,and press F10>enter.If the problem is same, change the RAM if you have a spare.
http://www.youtube.com/watch?v=3B9ff9ei7hk
If the problem is same ,take another ,mark on bios chip and remove Bios chip from socket , by thin screw driver ,and install itv again.
follow the pictore
http://www.computerhope.com/help/phoenix.htm
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
If the problem is same think *********** board has been defected and you should purchased. .
Hope this helps
Jan 29, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I installed a program on my computer that required 1 gig of ram. the program has worked for a few months with no problem. its now not working properly and i havent added any games or music. i noticed that...
Meh. Run a registry cleaning program (or the free Anvir process monitor to find out what's eating memory) and see if it doesn't clear up; though I'm inclined to say you should install 2 to 4GB (even after-market stuff since it's DDR that only has to run 200MHz, (to feed one 800MHz bus)) and see if the thing's new performance level improves your life enough to cover the cost. Easy victory either way.
Jan 05, 2011 | HP Compaq dc7100 Small Form Factor PC...
Hello, my pc has a CPU with 2.00 GHz and 1.12 GB of RAM, if I add another memory card of 1 gb for a total of 2.00 gb ram, this will increase the speed ?, thanks for you help
it would not increase speed as far as cpu speed,but it would make loading of things like programs and the loading of the OS faster.you would notice a difference.
Oct 22, 2010 | Dell Optiplex GX60 PC Desktop
Failure to communicate with scanner (Primefilm 1800u)
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this article can helps you to make your computer faster..
Aug 27, 2009 | Pacific Image PrimeFilm 1800u Film Scanner...
RAM QUESTION!!
Greetings my friend, regarding on your problem you will notice that if your computer/Laptop need to have additional RAM when your computer runs a program large enough to consume your RAM. You can add RAM anytime if you want to make your computer runs/loads program faster. RAM is used as a temporary storage of your running program or software so therefore if you have a large size of RAM then you can load large and lots of programs in your computer/Laptop with out experiencing log or slow in executing some of your request programs or applications. Also if your current RAM is not functioning well just like it is always restart your computer or dumping some programs and continues beep sound of your System Unit when you restart your Computer then that's the time you need to have a new RAM for your Computer/Laptop.
Jun 16, 2009 | Dell Inspiron 1521 Notebook
Coby Digital Photo Keychain DPKEY
Getting Started- VERSION DPKEY and 151SX
STEP-1
-INSTALL The Photo Viewer Software
Download & Install The Photo Viewer Software From Our Web Site:
The Driver CD files (Setup Guide, Manual and Photo Viewer Software) can be downloaded from
our web site. Click on the link below
http://www.cobyusa.com/?p=prod&prod_num_id=80&pcat_id=3001
NOTE:
Find your Photo Key Chain version and Download the Driver CD files along with all the latest
updates.
The version is listed on the back of the Photo Key Chain as 151SX, DPKEY or 151MP.
To Download & Install The Photo Viewer Software From Our
Web Site:
a) Create a folder
on your desktop before downloading the file from our website. To create
a folder on your desktop, go to your desktop and RIGHT click on your mouse. A set of
menus will appear. Select “New” and then “Folder” (you will notice a new folder will
appear on your desktop), give it a name, example DP151.
b) Click on the below link and select “Download”.
c) Click on your Photo Key Chain Version to start the Download. The version is listed on the
back of the Photo Key Chain (151SX, DPKEY or 151MP.
d)
After clicking on your version, you will prompt with a pop-up screen “Do you want to save
or open the file”. Select Save.
e) Another screen will prompt you to save the file on your computer. Save the file on your
“Desktop”, in the “DP151” folder and select “Save”.
f)
Once the download is completed, go to your desktop. Double-click on the DP151 folder.
g) To install the Photo Viewer software, Double-click on the Setup.exe file. Click NEXT on
all prompts.
h) After the installation. The Photo Viewer Software icon will appear on your desktop.
i) Done! ……Continue with “STEP- 2
STEP-2 CONNECT the Key Chain to your computer using the supplied USB cable. Upon
connecting the Key Chain to your computer, the Key Chain will prompt you to set the
device to “USB Charge or USB Update”. Select USB Update by pressing the Right
button and then the Middle button.
STEP-3 RUN the Photo Viewer Software to transfer photos to the Key Chain. Double-click on
the Photo Viewer icon located on your desktop. Once the Photo Viewer opens, it will
give you a message indicating “Upload Completed”. Click OK. (This message
indicated that the Photo Viewer Software has made connection with the Key Chain). If
you have received the “Upload Completed” Message, Skip STEP-4 and continue with
STEP-5
STEP-4 If you have NOT received the “Upload Completed” message, then you are
encountering the below error message:
Can’t Find any Photo Viewer, or
another program owns it. The
program will exit!
*Set the Photo Key Chain to USB update. SEE “STEP- 2”.
*Make sure the USB Cable is connected properly, you should hear a “clicking”
sound when the USB Cable is connected properly in the USB Port.
*The Key Chain should also appear under “MY COMPUTER” as a removable
disk. If not, switch the USB Port or replace the USB Cable.
STEP-5 LOCATE the images on your computer (See Diagram)
STEP-6 HIGHLIGHT the images files that will be transferred to the Key Chain (See
Diagram)
STEP-7 SEND the highlighted images to the Device Panel (See Diagram)
STEP-8 TRANSFER the images from the Collection panel to the Key Chain (See Diagram)
Disconnect the Key Chain from your computer. Done!
Nov 04, 2008 | Tao 1.5-inch Square Polished Silver Photo...
Boot up problems.
sometimes new RAM and old RAM develop some kind of compatibility issue due to slight variations in them.... it is something like the system gets accustomed to what it was before and refuse to adapt properly to change...
please take some experts advice....
Jan 31, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
