Remove cmos password toshiba l650 - Computers & Internet
pagebor
  • 2785 Answers
SOURCE: Toshiba Protege 2000 Lost BIOS Password
if you are getting password in the booting of the pc then it is bios password plz check the link
http://www.tech-faq.com/reset-bios-password.shtml
if it is not then try to boot in the safe mode and change the password
Posted on Jun 26, 2008
aayushik
  • 59 Answers
SOURCE: How to reset BIOS password - Toshiba Satellite 1605 CDS
you dont have to take the battery off, just unplug the cmos connector which looks like a stereo wiring harness.
Posted on Nov 14, 2008
SOURCE: Cmos / Bios password
IF IT COMES TO A SCREEN THAT SAYS "TOSHIBA" AND AT THR BOTOM LEFT SAYS ''F2-UTIITY , F12- BOOT MENU'' CLICK F2 IMIDITLY AND USING THE RIGHT CONTROL BUTTON SCROLL TO ''SECURTY'' AND CHANCE THE PASS WORS
Posted on Apr 05, 2009
  • 5 Answers
SOURCE: need to unlock phoenix bios password for toshiba satellite a135-s4527
remove the keyboard the mobo battery is there you need to unsolder one end of it, lift the leg, and turn it on that way for it to clear.. you will have to resolder once done.. have the skills or find someone that does... and you're set..
Posted on Aug 07, 2009
SOURCE: How to remove the cmos or bios password and want
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Posted on Mar 18, 2010
Tecra 8200 password
use bios password code for reset bios password
Removing BIOS password on Toshiba Satellite Laptop - YouTube
The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS. To clear the CMOS, you must remove the battery from
Jun 18, 2014 | Toshiba Tecra 8200 PT820U-OFG8C801...
Computer will not recognize bios password.
Unfortunately, this is a security problem. I would advise you to take it to a competent Toshiba Tech and with proof of ownership get him to remove the password for you.
Feb 24, 2014 | Computers & Internet
Toshiba satelite bios password recovery
On laptops there isn't an easy way to recover passwords in the BIOS. Sometimes you can reset the password. Other times, you'll have to contact the manufacturer to get it reset.
Some laptops will allow you to reset the BIOS password by pulling the CMOS battery. The CMOS battery is typically located under one of the bottom panels for access to the memory or wireless cards. Some models have the CMOS battery connected by a small wire with a clip connector, others have the CMOS battery placed directly on the motherboard with a metal retainer clip.
Here is a link to a removable CMOS battery with wires: http://www.laptopparts101.com/wp-content/uploads/2008/12/removable-cmos-battery-560x420.jpg
Here is a link to a CMOS battery that is directly on the motherboard: http://www.laptopparts101.com/wp-content/uploads/2008/12/coin-cmos-battery-560x420.jpg
On a laptop, if you unplug the power cord, remove the laptop main battery and then remove the CMOS battery - and then wait at least 5 minutes, some models will blank out the BIOS password. Not every BIOS password can be erased by removing the CMOS battery - but if you are comfortable working on the laptop parts it is worth a try.
If removing the CMOS battery doesn't fix the BIOS password, the only option left is to contact the manufacturer for a reset. (If you took your laptop to a certified technician - they would just contact the manufacturer for the reset, and then bill the time to you!)
The number to contact Toshiba is 1-800-457-7777.
Nov 19, 2011 | Toshiba Computers & Internet
Password bios toshiba 4000cdt
If you've forgotten your BIOS password, or if someone has changed the password on your Toshiba laptop without your permission, then there are a couple things that you can do to reset the password and access your computer.
Reset the CMOS
· The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS.
To clear the CMOS, you must remove the battery from your laptop and leave it out for at least 30 minutes to an hour. The way to remove the battery from your Toshiba will largely depend on the model. A common way to remove the battery--particularly with newer models--is to release the battery lock on the bottom of the laptop, while sliding the accompanying tab over to the side. This will pop the battery out from its tray so that you can then pull it out all of the way out.
Before you remove the battery, turn off the laptop and remove the AC adapter. Otherwise, you could end up harming yourself or the laptop components. You must also ground yourself to prevent damaging the laptop with static electricity.
After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computer, ideally, should no longer ask you for a BIOS password.
It's important to keep in mind that resetting the CMOS means that all of your BIOS settings will be reset to factory default. Also, sometimes you may need to leave out the battery for much longer than an hour to reset the password
Use a Backdoor Password
· If resetting the CMOS doesn't work, then your next bet is to try using a backdoor password. A backdoor password is basically a password that manufacturers include with the BIOS so that technicians can access the computers that people send in for repair. An example of a Toshiba backdoor password is, unsurprisingly, "Toshiba." When the BIOS prompts you to enter a password, entering "Toshiba" may allow you to access your PC and clear the old BIOS password. Another option is to hold the left "Shift" key down while booting.
Dec 06, 2010 | Toshiba Satellite 4000CDT Notebook
How to reset cmos paswword
Hi Good day!!! Turn off your laptop remove cmos battery with in 1 minute place it back and then turn on your laptop.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 04, 2010 | Toshiba Computers & Internet
Hi i am an indian.sir my laptop toshiba model:satellite A130/A135 Series is asking for bios password.ples help me.
Hi.
If you dont remember the BIOS password, you may remove it by resetting the BIOS password.
Please follow the below steps to reset the BIOS password:
1) Please remove the bottom casing of the Notebook.
2) Once you have removed the below casing, you should be able to see a CMOS Battery.
3) The CMOS Battery will be of a size of a coin.
4) Once you have found the CMOS Battery, please remove and re-insert it again.
5) The CMOS Battery will have the information about the Computer Date, time, BIOS Password etc.,
6) Removing and re-inserting the CMOS Battery will reset these settings, which will also remove the BIOS password.
Please perform the above steps and let me know the results.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 02, 2010 | Toshiba Computers & Internet
I am working on a toshiba satellite l355-s7915. the owner's kid forgot her password, so I tried to remove the password with hirens active password changer, which failed. when I started up the computer, it...
Yes of course all Laptop and Desktop have CMOS battery. Screw the back cover of your laptop locate the CMOS battery and remove to clear the BIOS password. Or else you can reset the CMOS by removing the jamper.
Mar 29, 2010 | Toshiba Satellite A135-S4527 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
BIOS PASSWORD REMOVAL on a toshiba satellite L45 S7409
This link describes the bios password reset for various Toshiba models (it's at the top of the results list), hopefully this will help you take care of your problem.
I would also think that Toshiba support would be able to assist you with this should you call them.
Apr 28, 2009 | Computers & Internet
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
217 people viewed this question
David Payne
David Payne
