We tried resting it .also not sure if theres a print stored and stoping it
    Genius:
  • 1,669 Answers
Please open up the unit at all access doors and physically inspect the internal path the paper takes. Make sure everything is clear of paper or debris. Use clean, dry compressed air to blow over any suspected areas of contamination.
Posted on Jan 01, 2013
Remove print head canon mp480
THe print heads are an integral part of each cartridge. When you remove the cartridges you actually remove the print heads. You will need to open the top front panel to access the print carriage which moves left and right over the paper under it. Using cotton swabs you can apply rubbing alcohol to the places the cartridges rest upon and absorb all the dried out ink. Be sure you toss the old cartridges out before you reassemble. If you need to store any ink type printers REMOVE ALL CARTRIDGES and clean off the receivers on the print carriage!
Dec 31, 2012 | Canon Pixma MP480 All-In-One InkJet...
Print Jobs remaining in printer memory indefinitely?
Take the printer back to her house, go to the printer controls, check the printer docs on cue (to see if there are any) and assure her that everything is OK. Tell her what happened, how it happened, and assure her that it cant happen again. This should put her at ease.
Mar 29, 2010 | Brother HL-2040 Laser Printer
My lexmark x5630 has been showing paper jam but there is nothing inside the printer thats stoping it please help.
Hello. Try removing all sheets of paper from the printer. Make sure to check in the feeder by peeking inside it. Clear any foreign objects. Open the printer cover, and remove the cartridges. Clear any foreign objects around the cartridge carrier. Close the printer cover without the cartridges. Unplug the printer from the power outlet. Plug the power back after 10-15 seconds. It should power on automatically. When printer asks for the cartridges, load them back in. Close the cover down. Printer will print an alignment page. Just let it finish print the page. When there's no more error, try to make a copy or print from the computer to check. Hope this helps.
Mar 09, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Hoover 5010D drier died on me...is it thermostat ?
If it is a thermostat there is nothing wrong with jumpering the supply across to the out feed to make sure that the rest of the heating side is OK before you buy a new stat.
You only need to run the machine for a minute or so to acertain if it all works
Oct 06, 2009 | Hoover Dryers
Printer stoped printinting
Hello there,
I think the correct printer is not selected on your computer. All you need to do is to go to Start > ControlPanel > Printers & Faxes > and check if you see multiple printers over there. If you do see multiple entries then right click on your lexmark printer and then select "Set as default printer" Once this is done, you can try printing a document to see if that works! In case if it still fails to print, you can try selecting the other printers listed in the printer & faxes folder as the default one and try printing. If you are still not able to print, I would suggest you to try uninstalling the program > restart your computer and then install the software once again.
Merry Christmas
Dec 24, 2008 | Lexmark Office Equipment & Supplies
SONY VAIO K315B KEYS
turn the laptop upside down and tap lightly just to make sure the keys are not stuck and if the issue still presists ..
contact tech support HP coz there should be a issue with the keypad
Oct 30, 2008 | Computers & Internet
Copier Machine stoped to print and copy
Open the right side door and check the transfer/separation corona unit. It may be a broken corona wire, and make sure corona unit is sitting properly.
Jun 04, 2008 | Toshiba e-Studio 350 Copier
Printing 'Form information: No form stored' non stop
rchamorro,
Sometimes, resetting the printer to the factory defaults solves some of the problems. For troublehooting and to overwrite all stored parameters, send the ^default command.
Mar 14, 2008 | Zebra LP 2844 Thermal Printer
Lekmark x9350
Try first doing a thorough clean of all printheads, cartridges too, then unplug all usb and power cords after turnig off. replug all and try again. I f no better, uninstall and reinstall printer.
Aug 12, 2007 | Lexmark X9350 All-In-One InkJet Printer
53 people viewed this question
jasbo
jasbo
