Question about GE DBXR463EBWW Electric Dryer
Door will not stay latched
The little latch will not stay shut. The door keeps opening unless I put something in front of it to keep it shut
    Top Expert:
  • GE Master
  • 9,472 Answers
Here is the door strike you need to order.
Posted on Dec 01, 2012
3 Suggested Answers
  • 410 Answers
SOURCE: power to dryer unit is
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Posted on Nov 29, 2009
iwillfixforu
  • 619 Answers
SOURCE: The door doesnt stay latched closed and I dont
Push the bad one into the front panel and just let it be. Nothing for it to harm in any way and then just transfer the other one over.
Posted on Feb 13, 2010
Dryer does not shut off when door is opened
The door latch probably is defective.
Apr 22, 2017 | Dryers
Door locked and will not unlock and cant shut door
sounds like the door latch mechanism is stuck in the closed position. if you pull on the door handle and use something like a screw driver and pull the latch claws open the door should work. the latch is the part that closes around the door striker plate bolt to keep the door closed. lube the latch to help keep it from sticking again.
Sep 04, 2014 | Honda Accord Cars & Trucks
Door will not stay shut
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Nov 21, 2013 | Bosch Nexxt WTMC3321US Electric Dryer
Ice storm caused the doors to be frozen shut. When I finally got one of the rear doors open, I crawled into the front and kicked open the driver's side and passenger's doors. Now the latches are broken....
ok open the door and look at the latch now while you are looking at it pull the handle as if you were going to open the door the latch should move if it doesnt it is stuck all you have to do is take a screw driver or something and manually move the latch and free it up hope this helps and next time youre doors freeze shut try a warm water in a bucket pour on all edge of door and it should open a lot easier good luck
Dec 13, 2010 | 1992 Oldsmobile Cutlass Ciera
My Whirlpool Duet washer will not start. I keep getting a "dl" and an "f" signal. I assume it means door lock failure. I've tried unplugging and opening and shutting the door before restarting but it won't...
It is indeed a door lock failure. Replace the door lock/latch assembly (part number 8181700) to solve the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel.
Secure the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Mar 01, 2010 | Washing Machines
Doors freeze up wont shut close after opening interior light then stays on
Look at the end of the door where the latch is located. The latch may have flipped to the closed possition when the door was open.There is a U shaped piece that when the door hits the post on the door jam it flips up to hold the door shut.If you can get the passinger door open you can see what it looks like in the open position. If this is the problem just hold the door handle like you are opening the door and with a srew driver or even your finger you can push than U piece back down.To keep your door from freezing shut try putting sone silicone spray on a paper towl and wiping it on the rubber door seal.Spray a little on the door latch as well.
Dec 28, 2009 | 2001 Ford Taurus
Dryer door will not stay latched and causes dryer
ew whirlpool duet steam dryer door will not stay latched and causes dryer to stop
Dec 20, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Interior lights stay on when the switch is off and car is parked
is the door ajar light on sometimes also when driving? I had a similar problem with the light staying on. I determined that it was the passenger front door latch sticking. I opened the door, then took a screwdriver to push the latch shut on the door jamb. (Make the truck think the door is shut even though it is open). Then lubricate that jamb and pull the handle open to open the door. Keep doing this (closing with screwdriver and opening with handle) until the latch works freely. This took care of my light and door ajar problem.
Aug 12, 2009 | 1999 Ford Expedition
RR window on my 02 Lib fell and now that door won't open!
As a last resort, I might try something like that, but remember that the door is heavy and that hanging it from the latch assembly will not do good things to the latch. If you try that, I'd first open the window and tie the door off to the roof rack to keep the door weight off the latch. Likely the latch will not release by removing the hinge bolts, but it may give you more room to get the inside panel removed.
Jul 19, 2009 | 2006 Jeep Liberty
GE DBXR463EBWW Electric Dryer Logo
125 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
