Question about Brother LS-2125 Mechanical Sewing Machine
Problem with brother vx-1120 will not feed fabric
    Problem Solver:
  • 11 Answers
This is usually caused by the feed-dog ( the metal teeth in the area below the needle) being down instead of up - run your finger under there (over the teeth) if they do not stick up above the base line of the machine, they cannot feed the fabric. If this is the case, look in your manual (or and online manual for your machine) and find out how to put the feed dog up. Other than this, some machines have a plastic plate which fits over the feed dog, so that you can do free machine embroidery, if this is the case, you should be able to remove this and the fabric will feed through
Posted on Feb 09, 2013
  • 3 Answers
SOURCE: I use Brother VX 1120 Sewing Machine. It can not
go to the brother website, you can download and/or look at the manual for free
Posted on Mar 04, 2009
  • 3 Answers
SOURCE: Brother XL-6562 sewing machine is not feeding fabric through properly
Oil might help but it sounds like you don't have enough pressure on the foot. You can take the casing off where the light is and there is a screw back there that controls the tension on the pressure foot. It is not meant to be changed by anyone but a professional. I've changed the tension but it wasn't easy. If you are still interested let me know and I will try to explain.
Posted on May 21, 2009
  • 1116 Answers
SOURCE: Brother VX 1120.... Machine is not making
Remove the needle plate, bobbin case and bobbin and clean any lint that has accumulated.
Oil, if the manual indicates you should do this and where it should be done. Some do not as it has to be done by a repair tech.
Re-thread the machine with the presser foot in the up position.
Make sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the proper guides.
If the problem continues, the machine will have to be services by a sewing machine repair person. Take samples of the stitching so they can see what it happening - it could be the timing has to be reset.
Posted on Feb 20, 2010
SOURCE: Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Posted on Oct 30, 2010
Joe Onley
  • 363 Answers
SOURCE: looking for the manual on
http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=3
Select your machine from the dropdown menu, then you will have the manual :)
Joe
Posted on Aug 29, 2011
How to change a belt on model vx810
Hello again Mary
Your manual is here but nothing about changing belts!
http://www.manualslib.com/manual/219387/Brother-Vx-810.html?page=36#manual
  • Brother VX810 Sewing Machine Parts www.sewingpartsonline.com > Home > Brother Parts
    • 4.8/5
    • 68K RATINGS
    Brother VX810 Parts These parts and accessories are guaranteed to fit your Brother VX-810 Sewing Machine. View Parts. ... Motor Belt 20 7/8", Singer #130944-001
  • BROTHER SEWING MACHINE Parts ' Model VX810 - Sears ... www.searspartsdirect.com/model-number/VX810/0150/1220000.html Shop for BROTHER SEWING MACHINE repair parts for model VX810 at Sears ... manuals & diagrams for any BROTHER Mechanical Sewing Machines repair project. ...
  • Brother VX-810 sewing machine - YouTube www.youtube.com/watch?v=toFRHM3fsfo
    • BY TPERSELLIN
    • 19 SEC
    • 7.1K VIEWS
    2013-05-14 · Video embedded · Brother VX-810 sewing machine TPersellin. ... Threading a Brother DB2-B735 Industrial Sewing Machine & Sewing Various Stitch ...
  • BROTHER VX-810 USER MANUAL Pdf Download. www.manualslib.com > ... > Brother Manuals > Sewing Machine > VX-810 Brother VX-810 Sewing Machines: Users Manual. VX-810 Sewing Machine pdf manual download. Sign In. Upload. ... VX-810; User manual; Brother VX-810 User Manual.
  • BROTHER SEWING MACHINE BELT VX800 VX802 VX807 X808 ... www.ebay.co.uk > ... > Machine Parts & Attachments BROTHER SEWING MACHINE BELT VX800 VX802 VX807 X808 VX809 X810 in Crafts, Sewing & Fabric, Sewing ' eBay. Skip to main content. eBay: Shop by category. Enter ...
  • Belt Motor Brother VX807 VX808 VX809 VX810 VX847 ... - eBay www.ebay.com/itm/BELT-Motor-Brother-VX807-VX808-VX809-VX810-VX847... BELT Motor Brother VX807 VX808 VX809 VX810 VX847 VX880 VX890 VX900 VX920 VX940 + in Crafts, Sewing & Fabric, Sewing ' eBay
  • Replace Belt ' Brother support.brother.com/g/b/faqend.aspx?c=ca&lang=en&prod=mfc9970cdw... Replace the belt unit following the steps below: ... *If your Brother machine has a Touchscreen, please follow the steps under "For Touchscreen models" below.
  • Sewing Machine Parts - Brother Parts - Brother VX-810 ...
  • www.thesewingoutlet.com/brother-vx-810 Change Currency. Loading... Please wait... ... Brother Parts; Brother VX-810; Sort by: ... Brother VX-810. Sort by: ...
  • http://www.bing.com/search?q=change+a+belt+on+brother+vx810&qs=n&form=QBRE&pq=change+a+belt+on+brother+vx810&sc=0-30&sp=-1&sk=&cvid=F80CBC7C1B0340DFBBA06B46207E0E5E
    Jun 18, 2016 | Brother Sewing Machines
    Manual brother vx-1130
    Sue, I will post links below for your manual.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Brother VX 1120 User Manual
    Brother VX 1120 Sewing Machine Threading Diagram
    Manual BROTHER VX1130 Operating Instructions Service
    Brother VX 1120 Sewing Machine Troubleshooting eHow
    Mar 03, 2016 | Brother Sewing Machines
    Shuttle on a Brother VX-1120 sewing machine will not pick up the bobbin thread
    Bobbin in backwards, needle in backwards, needle damaged, needle too small for the thickness of fabric or needle not the correct needle system for the machine are my first guesses. Try a new size 12/80 needle, flat of the needle to the back of the machine, completely up in the needle clamp as a first pass at the problem.
    Feb 18, 2014 | Brother Sewing Machines
    Material wont feed through
    it's very possible that the feed dogs need to be checked, if their
    not feeding the fabric thru the machine
    Jun 10, 2012 | Singer 1120 Mechanical Sewing Machine
    Brother VX 1120 sewing machine bobbin holder missing
    you can buy one from this website.
    http://www.sewingpartsonline.com/bobbin-case-class-15-japan-made-jo1313z-j.aspx
    Jan 27, 2010 | Sewing Machines
    Nesting thread on under side of material
    Hello frank it sounds like you might have a bobbin case problem I would try changeing it out
    Jan 25, 2009 | Brother Sewing Machines
    Brother vx 1120 Feeddog trouble
    Have you tried the feed dog switch? If it hasn't been used for several years, a trip to a service man would do it the world of good, and he would be able to fix your problem too.
    Oct 24, 2008 | Sewing Machines
    Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
    Bobbin thread will not pick up nor will dog feed rise
    my Brother sewing machine model VX 1120 will not pick up the Bobbin Thread. Machine is fairly new with only several hours use. I have changed needles , tried different bobbins, cleaned the machine. Any suggestions?
    Jul 06, 2008 | Sewing Machines
    Brother LS-2125 Mechanical Sewing Machine Logo
    316 people viewed this question
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
