Question about AEG Lavamat 88840 Front Load Washer
Washing machine wont pass cycle on dial
THE MACHINE WILL START ITS CYCLE THEN WHEN IT GETS TO THE FIRST RINSE CYCLE IT WONT GO NO FURTHER AND THE SIGN C6 FLASHES ON THE SCREEN.I WAS WONDERIG IF THIS HAD ANY THING TO DO WITH MY RECENT MOVE, AS I DONT THINK THE BOLT FOR MOVING WAS TIGHTENED,CAN ANY ONE SORT THIS PROBLEM FOR ME , AS THE MACHINE HAS WORKED PERFECTLY UP UNTILL THE MOVE...THANKS
  • 1 more comment
  • sue riddell Jun 08, 2007
    I HAVE LOOKED IN THE MANUAL, ALL CODES EXCEPT C6, IT SAYS CALL ENGINEER FOR ANY OTHER CODES,AND YES IT DOES START THE CYCLE BUT JUST STOPS ON THE RINSE CYCLE AND THE CODE COMES ON, BUT THANKS ANYWAY....
  • sue riddell Jun 10, 2007
    thanks for trying but this didnt help
  • sue riddell Sep 11, 2008
    thanks for this tip, but where about is the air pressure thingy. if you can tell me i can have a look...thankyou again
  • 5,911 Answers
The fault your machine is displaying is related to the air pressure system. You could have a blockage in the air pressure system or the air pressure switch could have just gone bad. Could it have been damaged during your move? Or, could it just be a coincidence? I hope this helps you.
Posted on Jun 19, 2007
    Sergeant:
  • 236 Answers
Remove the back/ lid of the machine to check that the movement of the tub has not dislodged any wiring/pipes from any components. also the tub may have knocked/damaged the circuit board. that is why transit bolts are provided.
Posted on Jun 18, 2007
Gets stock in rinse cycle
Rinse cycles are usually with cold water. If it cant fill with cold water, it wont go through the rinse cycle. Make sure it fills with cold on a normal wash. You may find its filling with hot only. Alternatively, the machine may not be pumping out properly, this will cause a similar fault. Check to see the machine is draining at the end of the wash. check the pump and the filters for blockages or lint etc clogging the hoses or pump.
Feb 18, 2015 | Washing Machines
Kenmore 70 series wahing machine wont start rinse cycle
Have you tried the rinse cycle in every wash cycle selection on the dial. Some times after using one particular dial setting all the time the contacts on the switch get corroded or burnt out, if the rinse cycle works in other settings on the dial then this is most likely the problem. You can then look up on line and order a new switch for the unit usually takes about two weeks to get in and is fairly easy to replace.
Aug 26, 2012 | Whirlpool Washing Machines
Not draining after rinse cycle
replace the timer it has a bad spot inside of it in this segment of the timer and isn't passing voltage for spin,when you forward it then it gets power again,they do wear out too
May 14, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Matayg Atlantis Washing Machine gets stuck in the Rinse Cycle and will continue to rinse for hours.
This is the sign of a bad timer. It is not sensing how long it has been in the cycle. The timer is not advancing. Replace the timer.
Feb 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
AEG Lavamat 88840 Front Load Washer Logo
353 people viewed this question
Top AEG Washing Machines Experts
shaun taylor
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
