Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Ice machine not harvesting
Its km-650 mah ice machine . Its only running in water fill cycle. I change float switch still no change what else should i chek.
  • Hoshizaki Master
  • 1,144 Answers
If you are sure the float swith is good and the dip switches on the board are correct, you most likely have a bad 1 minute timer on the control board. will have to replace board.
Posted on Jun 07, 2014
  • 1144 Answers
SOURCE: Hoshizaki ice machine model KM-450MAB water runs
Hoshizaki machines have a water inlet valve that can stick in the open position. This will cause the machine to do silly things. If you can turn the machine off and you can still hear water running, the valve is stuck open. It is an easy fix. Water valve only has 2 wires going to it and 2 water lines. One inlet and one outlet. Just turn off water and kill power at the breaker before doing any work.
Hope this helps and good luck.
Try Rick and Restaurant Parts and More in Ohio for a replacement valve. 1-888-814-1110
Posted on Apr 03, 2009
SOURCE: harvest cycle on ice machines
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
Posted on Nov 30, 2008
bobicehouse
  • 1524 Answers
SOURCE: KM-500MAH won't go into harvest mode
The float switch controls the harvest cycle.
Posted on Jun 07, 2009
cdarnell89
  • 16 Answers
SOURCE: running but no ice
if you are getting 5 min freeze cycles the first place to look is the Check valve this is the white triangular housing right above your pump motor it has three stainless screws take this out there is a spring and a seat clean the seat off and then stretch the spring lightly not too much replace and see if this solves the problem.
Posted on Jun 23, 2009
  • 233 Answers
SOURCE: KM-500MAH water keeps cycling thru when in ice making mode.
if this is a water cooled machine, the head pressure flow controller need to be replace/adjusted.
Posted on Jul 12, 2009
My hoshizaki ice machine KM-900mrf model beeps 3 times and stop making ice. After reset it starts, but stats beeping again after an hour.
Have a look at the side of the evaporator; there is a probe (thermistor) attached to it that tells the control board when to initiate the harvest cycle. make sure it's clean and attached properly and doesn't need replacing. If hitting the float switch initiates the harvest cycle it sounds like you have a blocked/ scaled water tube or switch housing. take off the bottom of the switch assembly (black rubber bit) and clean through to the water chamber. run a cycle of descaler before trying again.
Jul 04, 2015 | Hoshizaki Freezer Commercial Ice Machines...
I worked on a hoshizaki km-500mae when i turn it on the first cycle it makes good ice but after the first cycle it makes little pieces. why?
time the cycle. if it is only running about 5 minutes and going into harvest, look for sump loosing water. Look at where the unit drains (like a floor drain) while the unit is running to see how much, if any water is draining. does not take much to make an early harvest. also, sump may not be filling up completely but with just enough water to satisfy the float.
Feb 16, 2015 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Model KM 630 MAE
Look for a stuck float switch. unit fills with water for 1 minute, then the board "looks" at the float to "see" if there is enough water in the unit to run. If float switch is stuck down, it tells the unit there is not enough water and the unit stays in the fill cycle causing the sump to overflow and send water down the drain constantly. Compressor will not run till the board senses that there is enough water to run.
Jun 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I Have A KM-900MRH Ice Machine Hoshizaky i, recently changed the water pump, and now sims to be that ice is really thin, and is not making enough.
adjust the float (White plastic with black rubber bottom) item next to the water pump. It needs to be all the way down. Loosen the 2 screws and slide it down all the way. This is what controls the size of the ice cube. Other possibility is that there is water leaking our of the sump causing and early harvest cycle to start. Look for both.
Sep 13, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-900MAH Ice Maker it sounds like it is making ice and is freezing it but its not dropping ice any solutions?
when the machine first starts, it begins it's cycle in the harvest mode. If the float switch is stuck, it stays in the fill/ harvest mode. Compressor runs and water circulates but no ice is being made. I'd start looking there. Turn the machine on, let it run for about 3 minutes, they very lightly tap the float switch. If it starts making ice, bingo, theres your problem. Let me know if I can be of any more help.
May 12, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Apr 22, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Harvest cycle on ice machines
Jun 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Ice Machine Model KM-500MAF
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
necessary.
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Feb 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
191 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
