Question about Kitchen Ranges
Oven not heating properly themrador rdfs30qw
The oven heats but not to the set temp.Heating element does not appear to be getting hot.
  • William Dec 02, 2012
    The only reason that the solution didn't work was that after I posted the question the oven stopped heating entirely. I checked the heating element with a meter and discovered that it had failed completely and and was allowing any current to pass through.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
If the unit will heat, but the temps are off, then you may have a sensor issue. You can test this with a multi-meter.
Here is the part to order in case you find it bad.
Posted on Nov 30, 2012
ronaldo1
SOURCE: cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Posted on Feb 15, 2008
aborcass
  • 2651 Answers
SOURCE: Oven not heating up
can you see the bottom element?? if so usually , its obvious when the element goes bad, youll see the damage.TURN OFF POWER. 2 screws remove elemnet from the front 2 wires, plug in aa new one and your good
Posted on Mar 01, 2008
SOURCE: Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Posted on Jan 28, 2009
SOURCE: GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
Posted on Feb 15, 2009
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
i dont know want is wrong with it when i turn the oven on it keeps saying e2 and f3 i dont know what that mean please help me one on .... :(
Posted on Nov 28, 2009
My electrolux EOB5610 wont heat up....the fan works and the grill works but will not reach any sort of temp !!!!
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Jun 02, 2011 | Electrolux EOB5610 Ultrafan Electric...
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
The Oven turns on and sets to the proper temp. and runs like it is heating up but never gets hot.
your lookin at a heating element or thermostat id say. more likely the element.
take out oven trays, ul see a panel at back of oven, remove the screws holding it on and possibly the light cover as well. you should now see the element, sometimes u can visually see it warped and blown. if not take it out and test it using a multi meter. if it ok change the thermostat
Sep 24, 2010 | Whirlpool RBS245PDS Electric Single Oven
My oven still doesnt work after replacing heating element
it could either be a hot spot in the element where it can no longer pass all the current needed for proper operation in heating(look for a discolored spot on it,it may be whitish and dimpled from heat) or secondly,it could be the oven thermocouple located on the inside top of the oven cavity
Feb 22, 2010 | Amana AEW3530DD Electric Single Oven
I have Range GE J34CFT 1 that is not heating up correctly
You have to start with putting an oven thermometer in the oven and comparing the oven temp with the temp that you set it to
Jul 21, 2009 | GE Kitchen Ranges
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
HI, MY ELECTROLUX SINGLE FAN OVEN EBO5665 DOES NOT HEAT UP TO ANY TEMP. THE OVEN IS ON, FAN ON,AND THE TIMER DIALS ARE SET. DOESNT HEAT UP. IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME. ANY SUGGESTIONS!...
You probably have a bad ( or open ) heating element.. With the power removed.. look at the heating element and make sure it is connected properly and if after you check that it looks ok.. plug it in and try again.. if it fails to get hot..its probably bad.. Not sure what you mean when you say ' IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME' but if it tripped the switch or circuit breaker .. your heating element may be shorting out to ground.. and would need to be replaced anyway... Hope that helps.
Aug 22, 2008 | Electrolux EOB5600 Ultrafan Electric...
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    Zanussi zbf 760 (9 yrs old now)
    This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
    2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped like us on facebook please
    How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
    Sep 24, 2007 | Zanussi ZBF360 Electric Single Oven
    Kitchen Ranges Logo
    44 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
