MITSUBISHI tv model #WS-55809 HOW DO I UNLOCK PARENTAL CODE?
A FRIEND GAVE ME THIS TV BECAUSE THE PARENTAL CODE IS LOCKED AT CERTAIN TIMES OF DAY. iT ONLY GETS 3 CHANNELS BECAUSE THEY HAD NO IDEA WHAT THE CODE IS TO UNLOCK IT. THEY DIDN'T GIVE ME A REMOTE EITHER. iS THERE ANY POSSIBLE WAY TO SALVAGE THIS TV?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
You would need a remote---with that if all else fails there is a way to release the parental control by doing a reset using the option menu, let me know as with the Mitsubishi remote and a 4 number code you can get to the OPTION menu and reset this set.
Posted on Dec 22, 2012
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WS 55809
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 21, 2008
welcomejee
  • 10594 Answers
SOURCE: Mitsubishi tv model WS-55809
wdweber,
Its usualy convergence problem and needs to look dry solder joints in convergence board.
Posted on Jul 20, 2008
  • 4234 Answers
SOURCE: I have Mitsubishi model WS-55809 55 in. projection
The problem is with the convergence circuit that is controlled by a couple fo convergence ICs. These are large black ICs attached to a heat sink and are marked STKxxx. Since a good whack seems to fix the problem, it suggests that the connections to the pins on these ICs has broken. This is a common failure adn is easily fixed. Please note that there are potentially dangerous high voltages present inside the set even when itis unplugged. If you can solder, resolder the pins on the ICs. That should resolve the problem. If not, then there is an internal bad connection within the ICs and they should be replaced. The parts cost is around $25-$25 per IC. There are 2 in this set.
Good luck,
Dan
Posted on Nov 04, 2009
pabloloco
  • 2335 Answers
SOURCE: Mitsubishi TV model ws-48315 v chip locked
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Posted on Apr 30, 2010
pabloloco
  • 2335 Answers
SOURCE: parental control/lock on Mitsubishi WS-55613
I can help you unlock your Mitsubishi HDTV V-Chip parental lock.
I hope that helps.
How do i get the v-chip lock code to unlock the parental lock from my Mitsubishi model code ws-55413
Bypassing the V-Chip Lock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode
hope this helps
John.
Jan 11, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Reset Mitsubishi WS-73711 VChip Password
Bypass or Reset Mitsubishi WS-73711 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 73711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
Mitsubishi WS-73711 Manual Download
Bypass Mitsubishi WS-73711 Front Lock
on May 05, 2010 | Mitsubishi WS-73711 73" Rear Projection...
Tip
Reset Mitsubishi WS-65712 VChip Password
Bypass or Reset Mitsubishi WS-65712 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65712 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Mitsubishi WS-65712 Manual Download
Bypass Mitsubishi WS-65712 Front Lock
on May 05, 2010 | Mitsubishi WS-65712 65" Rear Projection...
Mitsubishi tv
These steps are actually for a Mitsubishi Projection HDTV, but I think they may work for a Mitsubishi LCD HDTV too.
I hope that helps.
Jun 23, 2009 | Mitsubishi WD-65C8 65 in. LCD HDTV
Mitsubishi Model VS-5061
Go to the V-chip settings menu. When prompted for your password, hold "9" and "QV" buttons on the remote at the same time. You will then be prompted to enter a new password.
If you need to unlock front panel buttons that were locked under a forgotten code, hold the menu button on the front panel for 8 seconds.
As far as I know this applies to all Mitsubishi rear projection series WS, VS, and WT Tvs from 1999 to 2002 and probably newer as well.
Jul 03, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Tip
Reset Mitsubishi WS-65711 VChip Password
Bypass or Reset Mitsubishi WS-65711 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Mitsubishi WS-65711 Manual Download
Bypass Mitsubishi WS-65711 Front Lock
on May 04, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Green Gun does not come on
my tv comes on but it says your input is locked enter your 10 diget code press enter but i dont no it
Jul 16, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Tip
Reset Mitsubishi WS-65511 VChip Password
Bypass or Reset Mitsubishi WS-65511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65511 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-65511 Front Lock
Mitsubishi WS-65511 Manual Download
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Reset Mitsubishi WS-55711 VChip Password
Bypass or Reset Mitsubishi WS-55711 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 55711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-55711 Front Lock
Mitsubishi WS-55711 Manual Download
on May 03, 2010 | Mitsubishi WS-55711 55" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
