Question about Dishwashers
Gsd4940zzoss ge profile performance has flashing light in drying cyle. Won't turn on
  • 330 Answers
SOURCE: defrost light flashing
check the bottom of the door, make sure it is completely closed
Posted on Jul 21, 2008
SOURCE: GE Profile Performance Dryer
GE Easy care 4 prong Installation
Grn = Ground
White = Neutral ?
Black = ____ top or bottom?
Red = ____ top or bottom?
Please advise
Posted on Aug 20, 2008
hsanfor
  • 71 Answers
SOURCE: GE Profile Performance washing machine does not turn on
Use another device to determine if the outlet you are moving to is good. If it is then try the wash machine in the previous outlet, if it does not work there a fuse may have been blown.
Posted on Jun 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: ge profile performance double oven. getting an F7
F7 is a stuck keypad/button.
Push all buttons at random several times each. This will sometimes un-stick a stuck button.
If that does not work the keypad control will have to be replaced.
Posted on Jan 16, 2010
kel1guy2002
  • 3740 Answers
SOURCE: getting F7 code on a ge profile performance oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Posted on Mar 09, 2010
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
GE Profile Prodigy DPR483GAOWW takes 2-3 cyles to dry. Have cleaned lint trap still no success
Our laundry room is in the center of the house and the dryer vent runs underneath the house and every 6 months or so we have to run a plumbing snake all the way through the vent pipe. Once it all the way through the house we then tie a rope to the end of it with a huge knot tied into it, we then snake the rope through the pipe and it pulls out all the lint that has collected inside, someone at each end of the rope (make sure it's long enough) and run it back and forth until no more lint is collected. I hope this might help you.
Mar 19, 2011 | GE Profile Prodigy DPSR513GA Dryer
Kenmore elete dishwasher flashing light clean
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Dec 06, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
