Question about HP Compaq nc6400 Notebook
Compaq NC6400 laptop boot problem
Tries to boot into Windows, then just reboots itself. Caught in a loop and won't boot to Windows. Tried it with a different HDD and still the same problem.
  • 29 Answers
Test your power I.C, if it is ok try changing your processor
Posted on Dec 11, 2012
cheap to fix
  • 404 Answers
SOURCE: hp/compaq nx7010
bad CD installation, get a new clean CD
Posted on Mar 03, 2009
  • 630 Answers
SOURCE: My Compaq Presario V3000 will not boot up. It
Get the computer back from them and re-install windows. In future try to boot in safe mode first (press F8 when it's booting)
Posted on Jun 30, 2009
  • 1810 Answers
SOURCE: formatting a Compaq nc8430 laptop
you need a compaq boot disk
ferkin compaqs are a pain in the O
try pulling the drive and inserting it into a portable enclosure than format it you will probably find there is 2 partions on the drive
usualy the first is the small 1 and it has only enough space the boot then it kicks to the second 1
if you use a portable enclosure and use the manage command you can see the partitions and you can format it as 1 huge drive rather than 2 smaller ones
Posted on Jul 07, 2009
trikha_karan
  • 66 Answers
SOURCE: Non Disk error...
Check the boot sequence in BIOS and make sure that you no usb device connected to your computer and also try to change you Sata mode in BIOS and see if that works.
Posted on Jul 28, 2009
parrotheadpc
  • 2600 Answers
SOURCE: my hp compaq nc6400 doesn't turn on. the green
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Posted on Oct 12, 2009
How do I stop my laptop from reboot loop?
Just insert a windows CD and repair your OS. Your problem will be solved while preserving all your files and folders! Good luck
Jun 14, 2013 | Acer Aspire 7520-5185 Laptop
System tries to load windows xp, then just reboots itself continuously. tried different hard drives with the same result
Because if you change the HDD ussualy the windows doesn't automatically works. Loading the drivers and settings for another mainboard will make it CRASH. Put an empty HDD and reinstall WINDOWS. Ask for directions here
Nov 30, 2012 | HP Compaq nc6400 Notebook
My nc6400 won't power up even when connected to a power adapter. How can I fix this?
Since you already tried another power cord (assuming that it was a working cord and for the exact same model). Then I would say your motherboard is dead.
Aug 17, 2012 | HP Compaq nc6400 Notebook
I have a proliant ml350 g3 rack mounted server that is in a constant reboot loop. It once gave a blue screen of death with the error message of NME Parity error, so I took out all but one RAM stick and...
Put RAM's in Identical form and check.
clear NVRAM and Check.
check the array controller
update BIOS and Array controller firmware ( disconnect HDD's from the cage before
updating the latest Firmware( download from hp.com/support and drivers )
May 27, 2011 | HP Compaq ProLiant ML350 G3 Server
Hp nx6110, stays in a boot-up loop
Hi, If you are sure that it's not overheating, then it could be the hard drive.
A boot up loop is an indication that the boot up sector on the hard drive is corrupt and broken. The hard drive tries to find this boot sector to boot up your computer but it can't. It keeps trying to find it again and again and again and keeps looping. Hank
Jul 23, 2010 | HP Compaq Motherboard
Laptop n800c my power but d xa mg boot
2 Aug 2009 ... i tried takin bat out and holdin power but nothing plzz save me ... Compaq cq 60-100 laptop · Compaq laptop adapter · Compaq laptop f1 boot error ... How to format everything off my compaq windows vista laptop · How to reload windows vista on compaq ... Manual de laptop compaq evo notebook n800c ...
en.kioskea.net/forum/affich-135447-laptop-compaq-nc6400
Dec 06, 2009 | Computers & Internet
Ati2dvag caught in a loop
These kind of problems can be caused by a number of different things, from software to dodgy ram, PSU etc etc. I'll assume you've already done a virus and adware scan-if not, do it now. If that doesn't work, let's start with the easiest to diagnose and fix-the device driver itself. Download the latest version of the Ati catalyst driver from Ati. Uninstall the existing driver(Assuming you're using Windows XP, Start>Control Panel>Add/Remove Programs, then find the Ati graphics driver on the list and remove it), remove the grapics cards entries from Device Manager(Start>Control Panel>System>Hardware>Device Manager, then click the cross next to "Display Adaptors", right click and choose "uninstall"), and reboot into safe mode (tap F8 at POST screen). Run drivercleaner in safe mode (you can download it from here): http://www.driverheavendownloads.net/ then reboot, cancel the "Found New Hardware Wizard" which pops up when you restart windows, and run the new driver installation program.
Apr 12, 2006 | Toshiba Satellite M55-S135 Notebook
HP Compaq nc6400 Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
