Question about Sony RCD-W500C 5-Disc CD Recorder
Music on CD sounds like it's vibrating
It started yesterday and, the longer it plays, the worse it seems to get.
It has happened with several CDs.
  • 962 Answers
Locate your CD reader bulb just inside the tray. Clean it good with rubbing alcohol. It still has a chance that it can be saved.Beacuse it is still reading. If it stops reading, you will have to buy a new player . Also if cleaning it does not works.
Posted on Jan 11, 2009
My Bose wave system started making a vibrating sound when a cd is played. What is the cause of this?
The cd motor has gone out of balance it is likely to be loose on the spindle keep playing it and you can damage your disks.
Sep 19, 2014 | Bose Wave Music System CD Shelf System
I can't hear any sound on my verizon wireless razzle phone. It just stopped working after i plugged in headphones what is wrong with my phone?
I had this very same thing happen to me yesterday after listening to music with my headphones. After unplugging them, the speaker would no longer work nor the speakerphone.
After trying many things without success, I was finally able to resolve this by plugging back in the headphone cable and pushing the jack around a little bit to the side until I could hear sound.
I did this while trying to place an MP3 just to make it easier. So far this has worked fine. But now I am reluctant to use the headphones any more.
I know your post was several months ago so this may or may not be helpful.
Oct 27, 2009 | Cell Phones
Intermitent vibration noises when playing cds
This is normal for a Vibration to occur when playing CDS. You should not be alarmed with the vibration unless you hear a Scratching noise.
--P3NGYJ03
Mar 03, 2009 | Acer TravelMate 4202WLMi Notebook
BlackBerry Storm 9530 will not ring
It seems like the problems starts after using an audio streaming app (Slacker)It also seems to correct after a reset(battery out and back in).
Feb 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
Acura Integra '92 loud clunking when accelerating
you can check the wheels make sure there on tight and make sure you tie rods and wheel bearings are good
Dec 30, 2008 | 1992 Acura Integra Hatchback
Bose Wave Music System - CD Says "Not Playable"
I turned mine upside down pressed play and it started working.
Turned it back over and it's working fine.
Dec 22, 2008 | Bose & Wave& Music System
2002 Ram Radio problem
It sounds like a cold soldered joint internally in the radio. My advice is to buy a nice aftermarket radio with an MP3 CD player. MP3 gives you the option to burn music from your computer. In addition, MP3 CDs will hold over 100 songs per CD.
It MIGHT be a poor connection at the power connector on the rear of the radio. You could try pulling out the radio and cleaning the connection before purchasing a new radio.
Aug 08, 2008 | 2002 Dodge Ram Maxi
Notation Technologies Play Music 1.0 No sound when playing back song.
hi this Probalm is your sound Drivers check your sound drivers
Mar 18, 2008 | Notation Technologies Play Music
Intermitent audio
I had that happen before, one problem was my car had bad shocks or i hit a pothole in the road. The second time i had the volume up so loud the bass wass thumping the floor and it skips the CD. My question is, how lowd is the thign turned up? :P Some CD players load the data into a memory and then it plays from the memory till it needs more info. It maybe that the unit is not stable or the CD is not balanced right so it cant read the info at a consistant speed. The music maybe playing faster then it can read because of the vibrations. Is the disk clean? i know this may sound dumb but it is easy to over look. If the surface of the data side is so scratched up it may have problems reading the data quickly enough. Sometimes the coating can fall of the disk if you hold it in the light you can sometimes see spots threw the disk where the foil has been chipped off. The CD player could have a focus problem also, it could be damaged in shipping or have been dropped and it cant focus properly on the data. Do you have any other disks to try? a new one? one you never play?
Apr 04, 2006 | Philips CDR785 3-Disc CD Recorder
Sony RCD-W500C 5-Disc CD Recorder Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
