Question about Mitsubishi WS-65857 65" Rear Projection Television
I have a mits ws65857 with an error code which was 2,3 then I pwr cycled and it change to 2,1, is there a commom failure on this model (codes) or is it a bad flyback?
It looks like I had a few drops of coolent leak from the center crt which droped on a couple of crossconnect links, but it cleaned up. There are no visible signs of heat damage on the boards.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
The Glycol is toxic and dissolves parts and leads etc.
here are the error codes: (unplugging set clears them)
Posted on Dec 22, 2012
  • 192 Answers
SOURCE: Mitsubishi WS-55411 55 in. No Power up
Error code 12 means normal operation. On these models we have found that a switch is bad on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on set. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. You can use an ohm meter to find the bad switch.
Posted on Jul 04, 2007
ctf1800
  • 4402 Answers
SOURCE: dm board mit wd52525
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Posted on Jan 08, 2008
  • 668 Answers
SOURCE: I own a Mitsubishi HD 1080 series HD TV;
I believe it is going to be a major repair and I would hesitate to invest much money into it. I think the age of this set is older than 5 years. The VS model series were manufactures before the WS model series and they have been around for 8 years or so. Never the less, parts availability is getting tougher. If your pain thresh hold is 300.00 or 400.00
go for it. If not, check out new sets.
Hope this helps,
Sky Assoc
Posted on Oct 22, 2009
Testimonial: "Thank you very much for the advice. I agree it may more cost effective to "bite the bullet" and buy a new TV."
  • 8457 Answers
SOURCE: WS-55411 What seven capacitors need replacing? 2-3 code Problem
U check the power supply board,check all cap,and replaced it?Ur tv make buzzing noise when u turn on power?Ur flyback is dead.
Posted on Mar 17, 2010
Testimonial: "Thank you for the advice, I have ruled out your suggestions and they were very good suggestions. I will find the problem soon enough! Thank you! "
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Posted on Mar 25, 2010
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
Packard Bell MIT-RHEA-S keyboard compatibility
Depends on your country code. The letters and symbols may be in the wrong place.
Apr 23, 2014 | Packard Bell Computers & Internet
I hav a mit 65 in tv model number wd 60737 it comes on with the words welcome mit and green light blinks and then shuts off.
Does the led light flashes green continually?
Check if you can access the operational error code. The TV must be in shutdown and then press the front panel "activity" and "channel down" at the same time and hold them for 5 secs.
Led light will flash 2 digit code separated by a pause.
23 - 2 blinks pause 3 blinks
Let me know the result...
Nov 16, 2011 | Mitsubishi Televison & Video
RHEEM 50 GALLON WATER HEATER,4 BLINKS THEN 2 BLINKS ,ECO FAILURE,UNPLUGGED HEATER STARTS UP AGAIN THEN FAILURE OCCURS AGAIN.
That is a power vent failure code.
Rheem is aware of this problem and are changing systems as we speak. Call your Rheem dealer and demand the updated system.
Feb 07, 2011 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
What is the kenmore washer model # 21086 water pump failure error code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 16, 2009 | Kenmore Elite 21086
Maytag washer model # mtw6600tq0 error code f50
Two things cause the dreaded F50 code. (motor)
1. The machine control
Bravos MTW6600T
http://www.repairclinic.com/SSPartDetail.aspx?s=t-Maytag+MTW6600T+-%3d%3di1469076&PartID=1469076
2. The stator
Item 17 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136402&diagram_id=1303991#d1303991
The upper cover of the stator comes in kit form and has been known to also cause the dreaded F50 code.
http://www.appliancepartspros.com/part_details.aspx?part_id=4327312&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5136402%26diagram_id%3d1303991
All of them are some what costly repair(s) in my book but cheaper than a new machine.
I have yet to change a Stator for an F50 Code.... but have changed a lot of machine controls (most often failure) and stator cover kits (occasional failure) that corrected the problem.
Just being honest. Thanks for using FixYa!
Kelly
Jul 29, 2009 | Maytag Bravos MTW6600T Top Load Washer
Trouble Code 3255
Thanks for using Fixya!
1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32.
A code of "55" represents end of error codes. If this is all you get then no error codes are stored in the computer. This is the normal condition for a neon.
CODE Description of Trouble Code
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles
13 No change in MAP from start to run
14 MAP sensor voltage too low
15 No vehicle speed sensor signal
17 Closed loop temp not reached or engine cold too long
21 02s sensor problem (oxygen sensor), upstream or down stream
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle Position sensor out of range
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
27 Injector control circuit
31 Evap purge flow monitor failure or evap solenoid circuit
32 EGR system failure
33 A/C clutch relay circuit
34 Speed control Solenoid circuits
35 Rad Fan control relay circuit
37 Torque converter clutch solenoid CKT or park/neutral switch failure
41 Generator field not switching properly
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43 Multiple/ single cylinder misfire
44 Battery temp sensor volts out of range
46 Charging system voltage too low
51 Fuel system lean
52 Fuel system rich
53 Internal control failure
54 No Cam signal at PCM
55 End of error messages (If you get this only, no errors were found)
62 PCM failure SRI mile not stored
63 PCM Failure EEPROM write denied
64 Catalytic Converter Efficiency Failure
65 Power steering switch failure
So in your case, you are getting error 3255 right? so you are getting error 32 EGR system failure and 55 which is no other error found.
I hope you get this sorted out.
Have a great day sir.
- HotRatchet
Jul 27, 2009 | 2005 Dodge Dakota
Whirlpool oaisis dryer will pwr on, but when start pushed-clicking noise and dryer won't start. Must pwr dryer back dwn to be able to change any timer setting, but dyer still will not start. ????
Model is 110.6705 Oasis Kenmore elite. Have removed back cover and have found drive belt broke. is there a seensor to shut motor dwn if belt breaks? Will order belt replace and see if thay resolves issue. Thanks
PS
No code given.
Oct 16, 2008 | Whirlpool Dryers
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 29, 2008 | Acer Aspire 5570-2758 Notebook
Mitsubishi WS-65857 65" Rear Projection Television Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
