Question about Humidifiers
Manuel for kenmore humidifier #29988
30.3 litre, humidifier maintains humidity automatically
hardrocko
  • 1476 Answers
SOURCE: i need to get about 70% humidity in my walk in
If you do not already have one get a cheap hygrometer at Lowes or Home Depot and put it in your humidor at eye level. Then run your unit until it reads 70 percent. When the unit is balanced in other words shuts off at that humidity you are set. Use a majic marker to mark the position and you are done. Let me know how this works out.
hardrocko
Posted on Feb 10, 2010
SOURCE: Kenmore Humidifier not operating?
Turn the unit off, lift the fan assembly off the base, and push the connector together that goes to the float switch on the bottom of the fan motor. If you hold the switch in with your finger (careful not to get into the fan blades) and turn the unit on, the F indication should go away. F (as in Fill), apparently, means the base has no water. The plastic tube that sticks up out of the base floats on the water and pushes the switch. Put it back together, it should work!
Posted on Mar 02, 2010
  • 1456 Answers
SOURCE: Kenmore Humidifier 14114 - the fan suddenly
Hello
You should replace the TCO (thermal cut off) in the motor this cost about 2 dollars,this should fix the problem and your humidifier should work perfectly again
Also oil your fan motor and this should free the motor right up.some bicycle gear spray should do the trick,inadequate lubrication overheats the fan.
Posted on Jan 04, 2011
Sparky2012
  • 102 Answers
SOURCE: The humidifier says "desired humidity" when turned
I would say, either the humidity level in the room is hi or the humidifier is defective, In my house the humidity is about 42% to 45% when we use the humidifier, and can drop to 30% or less if we don't, we leave in DC area,
I hope this helps.
Posted on Jan 15, 2011
  • 102366 Answers
SOURCE: I need a manual for basic instructions for the
http://www.managemylife.com/mmh/owner_manuals/3047/KENMORE-Humidifier-L0522285
Posted on Apr 28, 2011
Why does my Honeywell HMW450 humidifier keep shutting off?
Here are a few things to check:
-make sure the heating element is clean. If there is a thick layer of scale (mineral deposit), then the unit will not turn on.
-there are magnets on the water reservoir that allow the unit to turn on. If these magnets are not lined up properly, then the unit thinks there is no tank, and thus, not turn on.
-turn the humidity up past your target point. The humidity near the unit could be a lot higher than the rest of the room, causing it to shut off prematurely.
Hope this helps!
Apr 29, 2012 | Honeywell HWM-450 4 Gallon Humidifier
I need to get about 70% humidity in my walk in humidor,so how do i adjust the kenmore humidifier
hardrocko
Feb 10, 2010 | Kenmore 14417 Humidifier
Our Aprilaire is over 14 years old. Two
If your humidifier is working properly, then the problem lies outside of the humidifier. For example how long does your furnance run when the thermostat calls for heat? If your furnace is oversized for your home, it will heat your home relatively quickly, and turn off, while your humidifier does not have a chance to work long enough for it to increase the humidity. If this is the case, you could try to set the thermostat to run the fan in manual mode instead of automatic. This will give the humidifier a chance to increase the humidity.
Hope this helps.
Jan 08, 2010 | Aprilaire Humidifiers
Aprilaire 560 will only click and flow water when turned to "test" does not work in any other settings?
Humidity must be hi enough in the house or Humidistat is not working. Do you any way to check humidity in the house?
If the Humidistat is set as Automatic, try to leave it as Manual.
Dec 03, 2009 | Aprilaire 700 Humidifier
Humidistat problems
The ability of the humidifier to maintain a given moisture content in the air is far more difficult than a heat or cooling unit to heat or cool the air.
Moisture vapor has far more energy to seek dryer air, than tempered air. So the moisture seeks and finds dryer air quickly, whether it be through stair and door ways, or through cracks and seams in walls and doors/windows, or through non vapor barrier surfaces.
The only way the unit would be able to achieve a humidity level as stated, is for the unit to be placed in a vapor-tite room that has a minimal of leakage.
You could put more humidifiers in the space, or more and larger humidifiers in the space, to try and overcome the vapor moving to other areas of the space. But unless you have a fairly vaportite space, it is unlikely the unit is under capacity, and the only way to test what capacity is needed is to take humidity measurements.
Reply back with any questions you may have.
Feb 03, 2009 | Honeywell HCM-300T Humidifier
Aprilaire 600 humidity level too low
The max the aprilaire can put out is 45% Rh. Your humidifier may wired up to run only when the heat is on. In some cases this is not enough time to maintain your humidity level your seeking. To correct this, the hum. has to hooked up the hot side of the water supply. And the humidifier has to be hooked up when the fan runs and leave the fan run constantly
Jan 12, 2009 | Aprilaire 600 Humidifier
Temp
My guess is that you are trying to bring the humidity up too high. There is a chart in the manual that suggests where to set the humidity at based on outdoor temps.
I try to keep the level at 30-35% in the winter.
Hope this helps.
Dec 02, 2007 | Kenmore 14410 Humidifier
Humidifiers Logo
52 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
