Question about Kenmore Refrigerators
Frost in freezer compartment for model 79575544401
Frost built up in freezer drawer
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Replace the defrost sensor and you will be good to go. Here is the part to order.
Posted on Nov 30, 2012
fridgetech
  • 473 Answers
SOURCE: frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
mikedurland
  • 481 Answers
SOURCE: bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 28, 2008
woodchuck789
  • 4059 Answers
SOURCE: Our 3 yr old LG Model LFC25760SW French door
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 26, 2009
  • 7 Answers
SOURCE: Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Posted on Oct 09, 2009
I have a Kenmore Elite model no is 59673502201 and it stop cooling in both the frig and freezer i replaced the condenser fan motor and it worked so i replaced the back and the unit will STILL NOT GET
Do you hear your evaporator fan running in the freezer drawer area?
If not, then that's the fan you should have replaced.
If your compressor is running and both the compressor fan and the evaporator fan are running, check the back wall of your freezer compartment. If it is frosted up, then you have a defrost problem.
If it's not frosting up, disassemble your freezer drawer section and remove the back panel in the freezer to look at your evaporator coil.
If it's partially frosted at the top, or bottom, but the rest of it is dry looking, then you've got a leaking sealed system.
If it's lightly frosted all over, then you have good coolant flow and you need to start looking at your thermostat and damper up in the fresh foods section.
Nov 10, 2014 | Kenmore Refrigerators
Bottom freezer drawer doesn't slide out easily, frost builds up
3M spray silicone lubricant in 24 oz cans is good down to -23 degrees and FDA approved for being around food. Works a treat.
Jun 27, 2010 | Sub-Zero 650 / O Bottom Freezer...
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
Excessive fosting in the freezer compartment
may have a bad drain line heater or a bad defrost heater, thermostat, or timer.
Oct 09, 2009 | Freezers
Sub Zero Model 550 (1992) freezer drawer doesn't seal
the drawer need to be adjusted so that it will close.. with a air leak you will have frost build up around the drawer...there are drawer closers on the back of the rails... it may be broken or just pushed the wrong way...when the freezer is cold it should make that sucking sound and be hard to open ... hope it helps
Sep 19, 2009 | Refrigerators
Freezer works and refrig. does not. what can i try?
Hi: There is an off chance your freezer is so full of food you blocked the vents. Otherwise your defrost heater or timer is bad. I tried to find the model online but you left out the first three digits. That is the source code (who built it for kenmore) It's frigidaire but I don't remember the code( I tried 256). Anyway, The defrost heater will be below the evaporator coils in the freezer. Look for access. Or get the schematics from sears.com or let me know the source code and model number again. If you don't have any back up refrigeration, take a hair dryer to the back of the freezer compartment and melt the frost that accumulated back there. This will buy you one to two weeks before it frosts up again. The freezer is supposed to be frost free; since it dosn't work the frost is blocking the airways to the fresh food compartment. That is why it's warm. I hope this helps, Jeff
Jun 07, 2009 | Kenmore 64802 Top Freezer Refrigerator
FRIDGE FREEZER BUT FRIDGE STOPPED WORKING FREEZER WORKING OK
look on the back wall of the freezer is there snow? if so you have a defrost component out (timer, limit, or heater) the fresh food compartment gets cool air from the freezer so check for blocked air pathways the build up of frost in the freezer stops air flow so you will be cold on freezer side and warm on ref side
Apr 24, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Kemore model 795.7731 bottom freezer
You are probably correct that it is the evap motor. If you are seeing frost on the back wall then there is probably some ice built up around the motor and the fan blade is hitting it.
Try defrosting the freezer and look very closely all around the seal for the freezer drawer. It is common for moisture to freeze in the self closers in the drawer rails and not let the drawer close completely on one side or the other. If this happens the small gap will allow the freezer to frost excessively.
Sorrry to be slow in responding. I have been very busy this week and have not been on line very much.
Mike
Apr 10, 2008 | Refrigerators
Not cold enough
posible defrost not happening, air is not sirculating down to bottom compartment due to frost buil up
Oct 18, 2007 | Maytag MBF2256H Bottom Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
