Question about Music
I have an ap-24 celviano that wasnt working. A technician got it to work but now everytime i turn it on it is transposed to another key plus its octave down. also some keys have no sensitivity at all while others do
3 Suggested Answers
  • 1138 Answers
SOURCE: Kurzweil Mark 10 keyboard stopped working
Try the reset procedure on page 5 ( last page ) of this pdf document:http://www.dgaudiorepair.com/PDF%20Files/HARD%20RESET%20for%20Current%20KURZWEIL%20.pdf Hope this helps. Note the first procedure says highest white key. I'd do the second procedure.
Posted on Aug 29, 2009
  • 5603 Answers
SOURCE: ok i was playnig on
What has happened is that one signal wire of the matrix that scans the keyboard has opened up. Each key has two contacts. One closes before the other and that is how they measure key velocity to control the loudness for piano sounds for example. When one contact doesn't work, often the sound is set to MAXIMUM key velocity resulting in MAX loudness. The key contacts are scanned digitally in groups of usually 8 or 12 and, for instance, every C key has a single line attached and then every group of 8 or 12 has a second line and then there are two complete sets of these to implement the velocity sensing. Your unit probably has either a break in a cable or possibly a cable connector that has failed or not seated OR worst case, the circuit board under the keys has a crack breaking one wire or circuit trace going to that section of the keys. The problem will require opening the keyboard to repair. If you are not electronically adept, besst to take this to a repair shop.
Posted on Aug 14, 2011
Connecting to garageband
Only newer models with class-compliant USB (made last 12 months) can connect to MACs - & IPADs and PCs.
Older models require drivers available only for Windows.
Mar 13, 2014 | Casio Celviano AP-220 Digital Piano...
Casio piano seems to be frozen
It is 3 years/5 years warranty depending on your country.
Call CASIO warranty or contact dealer.
Feb 16, 2014 | Casio Celviano Ap420 Ap-420 Home Digital...
My Casio AP 620 Celviano says "Loading" soon as I switch it on but is not working
Could possibly power supply problem. If you're running through a multi-board, try running directly into the outlet. Failing that, try another power outlet altogether.
The Celviano range aren't real power hoggers once going, but initialising and starting up takes a bit of omph.
Sep 09, 2013 | Casio AP-620 Celviano Digital Piano
Ok i was playnig on my celviano ap-620 and then 8 of the keys started to sound rare, very loud, it seems like it lost the key touch sensivility on those keys from the center (C) and 8 keys down i tried...
Aug 14, 2011 | Casio AP-620 AP620 Digital Cabinet Piano...
I have Casio Ctk-496 and I have MIDI-USB wire. It all works, but Transpose button doesn't transpose and casio chord doesn't work with my computer. And all is still working even if I pull out IN wire from...
Casio Chord is internal to the keyboard and doesn't come out on MIDI. Transpose is similar and while the button may send a MIDI transpose type signal out, the notes will not transpose in your computer...
Mar 30, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Keyboard seems to be stuck in key of D How do I get it back to C ?
On page 105 of your X5D manual, read up about "transpose". Setting the transpose shifts the notes plus or minus from the normal.
If you don't have a manual, you can download one for free.
Nov 13, 2010 | Korg X5d
Music Logo
61 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
