Question about Ovens
How to replace fan-forced element in westinghouse 698 oven
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: smeg oven
    Sounds like you need a new oven element fitting.
    Posted on Dec 08, 2008
    • 38 Answers
    SOURCE: how to replace a fan bake oven hidden element
    Before attempting any repairs, make sure the power is turned off! If you are unsure or not confident, please call a service technician.
    The element is behind a cover that is held in place either by screws or clips. Once the cover is removed, the element will be visible. The element will be screwed in place by a number of screws on the base plate and around the element itself. After removing the screws, pull the element fron the rear of the oven. the wires should be attached to the element via lugs. The lugs need to be unattached from the element. Before removing the wiring, take note of the connections so that reinstallation can be carried out.
    Posted on Nov 22, 2009
    pride applia
    • 232 Answers
    SOURCE: St George wall oven element. which wire to connect
    green is always grounded
    Posted on Dec 24, 2009
    apart4u
    • 213 Answers
    SOURCE: My fan oven element( Neff U1452 )has been replaced
    they should last 12 months minimum there could be a problem with your fan motor here is a standard fan oven check list.
    You-Tube video "6QGurNvbI0Q" placeholder (do not delete)
    For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
    To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
    2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
    3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
    4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
    Posted on Jan 14, 2010
    I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
    I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
    Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
    Jul 31, 2011 | Ovens
    Trying to change element on westinghouse PAK806 stove with ceramic cooktop. cant figure how to lift hob.
    Hi I have a Westinghouse PAK806. The oven works fine, heat and fan, but none of the plates will turn on.
    Any ideas?
    Jul 13, 2011 | Ovens
    Fan oven not heating up
    This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
    • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped like us on facebook please
    How to Video Tutorials on Domestic Appliances
    Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
    Oven fan not working
    If you select the function on the selector switch which turns both the fan forced fan and the oven element on at the same time and the fan does not work, but the oven element does then the fan forced fan is faulty and requires replqcement.
    Feb 25, 2011 | Stoves 720EF Electric Double Oven
    Model no. SA420X oven. Have rubbed off the pictures that show the choice of cooking eg. super fan forced or fan forced, conventional etc. I need to see a picturs of the dial as it isn't in the manual
    I dont know if this helps but if you turn the dial to the different settings and leave if for 5 to 10 minutes between testing you should be able to figure out what does what. Conventional generally means no fan forced. Fan forced generally means fan with one to two elements. Super fan forced generally is fan with two to three elements. You should be able to see or feel most elements. Sometimes the one or two elements in the bottom are actually located beneath the oven floor.
    Feb 06, 2011 | Smeg Ovens
    My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
    Oven functions
    Oven light.
    Upper and lower heating elements.
    (Conventional cooking).
    Upper and lower heating elements with fan.
    (Fan assisted cooking).
    Lower heating element with fan.
    Inner grill heating element.
    (Radiant grill).
    Full grill heating element with fan.
    (Fan grill)
    Rear circular heating element with fan.
    (Fan forced cooking).
    http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
    Oct 10, 2009 | Ovens
    It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
    If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
    To replace: Turn off power!!
    -Remove side racks from oven, then remove rear panel.
    -You should now see fan blade and fan element.
    -You need to remove oven from cavity, then remove rear outer panel.
    -You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
    Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
    Aug 10, 2009 | Smeg Ovens
    Not heating in fan forced mode
    Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
    Jun 15, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
    Ovens Logo
    138 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
