Question about HP Compaq nc6400 Notebook
System tries to load windows xp, then just reboots itself continuously. tried different hard drives with the same result
    Sergeant:
  • HP Expert
  • 427 Answers
Because if you change the HDD ussualy the windows doesn't automatically works. Loading the drivers and settings for another mainboard will make it CRASH. Put an empty HDD and reinstall WINDOWS. Ask for directions here
Posted on Apr 17, 2013
mailtoravi
  • 186 Answers
SOURCE: hp pavillion dv 1000 notebook
If  the Hard Drive self test utility is unable to detect the Hard Drive, the Hard Drive in your Notebook might have gone bad.
I recommend you to try removing and reseating the Hard Drive by getting the instructions from the Manual of the Notebook which can be accessed from the link below so that if there is any issue with the Connectivity, this should solve the issue:
http://h10032.www1.hp.com/ctg/Manual/c00636251.pdf
You can find the necessary instructions to remove and replace the Hard Drive in the Notebook from page numbers 120 of 258 in the manual.
Hope this helps...
Posted on Oct 15, 2008
pontelemon
  • 538 Answers
SOURCE: V2311US overheating and shutting down
Try to clean heatsink and fan. Make sure fan is spinning(common problem).
Posted on Mar 20, 2009
pontelemon
  • 538 Answers
SOURCE: I cannot load windows xp pro
Go to BIOS and disable "NATIVE SATA SUPPORT"
RyMS
  • 63 Answers
SOURCE: My HP Pavilion laptop will not boot.
Usually the message about low virtual memory is because there isn't enough RAM and it was using up all the designated space on the hard drive as Virtual memory. (Uses a part of the hard drive like RAM)
That shouldn't account for being unable to boot into any Windows options though.
The one trick with HP computers, you can try is to take the battery out, make sure the Laptop isn't plugged in with an AC adapter then press and hold the power button in for 10 seconds with no power going to the laptop. This is doing a power drain. Then put the battery back in and try to power on and boot up the computer.
When you choose safe mode, does the computer ask which operating system you want to boot into and does it give you the option to choose "Recovery Console"? Or is there an option on the screen with the safe mode options to Choose your Operating System? If not then the recovery console wasn't installed. If you can choose the recovery console, you might be able to replace the failed files that are not allowing the computer to boot into any version of Windows. Unfortunately, the computer isn't reporting which files are the problem, winlogon.exe/userinit.exe/etc.
You can get a hardrive enclosure at a computer store that allows you to put the laptop hard drive in the enclosure, then plug the enclosure into another computer with a USB cable then you can copy the sensitive data onto the other computer.
If you aren't comfortable taking the Hard Drive out yourself, you can take the laptop to a computer store, and they will take the Hard Drive and hook it up to a second computer as a Slave (Secondary Hard Drive) and copy the data over for you
Posted on Apr 13, 2009
  • 74 Answers
SOURCE: XP won't load onto hard drive.
Start the computer and press the f8 key as if to start in sage mode, but select the "Disable system reboot on error" (not sure of the exact wording on that). Then when the BSOD hits it will stay there so you can get the error number and message.
Alot of times these are memory errors so I would also suggest that you download a program called memtest 86. It is a small ISO file that will create a bootable cd to test the memory. You can get it from:
http://www.memtest86.com/download.html
Hope this helps
Posted on Apr 30, 2009
Continuously rooboot itself?
Hi.
When the laptop keeps rebooting shortly after Windows starts loading the reason is usually because the system files loaded by Windows at startup are corrupted.
Windows cannot complete booting and keeps restarting.
The fastest way to Fix the problem is by reinstalling Windows.
If Windows is installed on the same directory of the existing system performing an upgrade installation, the setup process will preserve all personal files, most installed software and settings.
Before reinstalling Windows you can try starting in safe mode (eg. on XP pressing f8 on startup). If the computer starts in safe mode, go to system restore and perform a restore to a date before the problem occurred. Unfortunately when the computer keeps re-booting ut will hardly start in safe mode. Often reinstalling Windows is the only option available.
Aug 02, 2010 | Acer Computers & Internet
My 13 year old son laptop need be reset like new
There are a couple possible solutions to your problem. If the computer will still turn on and load windows, and I assume you are using Windows XP, you can try doing a system restore. To do this, go to Start, Programs, Accessories, System Tools, and select System Restore. If system restore is enabled, you should be able to choose a date in the past when the laptop was working properly and restore the computer to that date. If you want to completely reload windows, you will need a Windows XP installation disc. Load the disc in the CD or DVD player and reboot the computer. You should see a screen asking you to press any key to boot from CD, go ahead and press Enter. You will now enter setup where you can reformat the hard drive and reload windows XP. Follow the on-screen instructions to delete any old partitions, and then create a new partition and format it using NTFS. The windows XP installation will continue after the hard drive is formatted. If, when you reboot the computer with the installation disc in the drive, you are not prompted to boot from CD, you may need to reboot and press F2 or F12 to change the boot selection to the CD or DVD drive so it will load the CD first before it tries to load your original Windows installation.
Jul 18, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
XP Keeps Rebooting at Startup
Most likely it is your hard drive. There is a boot sector on the hard drive and when xp starts it looks for that boot sector. If that boot sector is damaged xp can't find it so xp reboots again...and again...and... Try a different hard drive and see what happens.
Hank
Oct 05, 2009 | Microsoft Windows XP Professional
Assist with an Operating System start issue? PC is a Gateway GT5228
the following will re-install windows without destroying your stuff but you must follow it exactly !!!!!!!
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. To Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" height="21" alt="To setup Windows XP now and Repair Install , press ENTER." src="http://www.michaelstevenstech.com/note.gif" width="15" border="0" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
  7. good luck beergut707
Oct 09, 2008 | Computers & Internet
Windows XP professional loop
Glad to hear you have your OS disc handy... let's try this:
Insert your XP CD and when it asks if you want to boot from the CD, press any key (ENTER) to do so. When asked, press ENTER ("To setup Windows XP now") and follow these steps...
To repair a Windows XP installation using Recovery Console, press "R"
To quit Setup without installing Windows XP, press "F3".
Press Enter to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console". You Do Not want to load the Recovery Console.
Select the XP installation you want to repair from the list and press "R" to start the repair.
((Note: If Repair is not one of the options, END setup. After the reboot read Warning#2! ))
Setup will copy the necessary files to the hard drive and at some point the system will reboot. When this happens, you want to now allow the system to boot from the hard disk but leave the CD in the drive. So do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Hope that helps.
Sep 09, 2008 | Microsoft Windows XP Professional
External hard drive enclosure
I too purchased a Nexxtech Hard Disk Enclosure and my Vista-based computer keeps telling me to try a USB 2.0 setup...the USB's ARE 2.0...did you try the setup disk that came with your unit?...I tried on mine but still a no go...I may have to return it to Best Buy & try somrthing different.
May 19, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Blue screen error
When you connect the drive on another machine make sure the jumber setting are either connected correctly as a slave or if using cable select option make sure the jumpers are correct and its on the first slot for the slave.
i am saying so because if it is detected on your computer, thats is why it allow you to load XP up to where you get stuck.
If you cannot manage to get it connected as a slve on the other machine, try connecting it as a single drive on that machine and load XP on it, if it manage to load then transfer it back to your machine when it start rebooting so that it will reboot after copynig files on your original machine.
If it then cannot continue loading on your machine, we will then be certain that the problem is not with your hard drive but just a hardware conflict on your computer, Try that before we pick it fro there.
Mar 25, 2008 | Samsung (SP0822N) 80 GB Hard Drive
XP Reboots by itself on arrival of login screen
have you tried safe mode? if safe mode is still a failure, you have no choice but to reformat 1 of those drives an do a clean installation of windows xp
Mar 17, 2008 | Computers & Internet
Compaq Deskpro EN contant restarting when attempting to load XP
Last time this happened to me, I had to reformat and reinstall windows. I tried all those modes, and I even tried the windows repair. None of that worked, I just did a complete new install. All of the data will be lost, if you do this.
My advice, if you need some of the data on that hard drive, you need to hook the drive up to another computer and backup what you need.
Or buy another hard drive, install windows on the new drive. Now slave the old and backup the data.
Nov 11, 2007 | Compaq Deskpro EN PC Desktop
HP Compaq nc6400 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
