Question about Brother SX-4000 Typewriter
Daisywheel doesn't print the correct letter when typed
  • Brother Master
  • 3,594 Answers
Probably the print wheel homing pawl is broken you need atech.
DickyO
Posted on Nov 30, 2012
4 Suggested Answers
  • 3594 Answers
SOURCE: I went to put in
If you are not in KBII or a language mode the printwheel homing pawl is probably broken. You need a tech.
DickyO
Posted on Feb 16, 2011
JUSTOLDJIM
  • 478 Answers
SOURCE: not printing correct letters
check to make sure the selection lever for pitch is not in the ps position and that the keyboard selector is in kb1 position
Posted on Jun 06, 2007
  • 19 Answers
SOURCE: Wrong letters typing
it sounds like you were using a non-brother correction tape,one that was too sticky and consequently too "slow" and during the correction sequence the fingers of the daisy-wheel got entangled with the tape. Make sure that the correction tape is of a "non-sticky" nature and then take off the correction and printing tapes. That way you will see better how the daisy-wheel is fitted . I will assume that you have an instruction book to show how this is done. before fitting the daisy wheel examine the fingers to see that none are bent or crossed over each other. If this is the case it is better to buy another one. bring your typewriter to the shop if this is the case and they will possibly re-fit the wheel for you. good luck.....
Posted on Mar 21, 2008
How do I insert the daisy wheel on my Swintec 2416 DM typewriter?
Remove the ribbon, then remove the daisywheel, reinsert daisywheel, replace ribbon and it should work.
Jul 01, 2014 | Swintec Office Equipment & Supplies
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
Type printed is different to keys pressed occuring after a few words which are printed correctly
Look for bent spokes on the daisywheel, try it with the correction tape removed. Something is interfearing with the daisywheel.
DickyO
Feb 01, 2011 | Brother Office Equipment & Supplies
Letter E is malfunctioning?
If it is only the capital (E) and not the lower case (e), remove the daisywheel (print wheel) and inspect it for damage. Don't worry about the letters being out of order the machine knows what order they are. You will likely see one spoke broken off or bent to one side. If so replace the daisywheel.
If both E & e are malfunctioning, the problem is that the keyboard is malfunctioning. The keyboard is not hard to repair, but it takes well over an hour to train someone how to disassemble and put it back together again, so I cannot explain it here. Besides you will (likely) need a conductive pad to replace the pad under the E/e key.
For your sake I hope it a damaged daisywheel. Best of luck!
Ron
Jan 08, 2011 | Brother EM-430 Typewriter
WE CHANGED THE DAISY WHEEL IN OUR MACHINE & WHEN YOU TYPE IT JUMPS SPACES & TYPES THE WRONG LETTERS
First, be sure you are using a Brother compatible daisywheel. Some other manufactures' daisywheels "look" the same but the charters are in different order, so they will not function properly.
After changing the daisywheel you need to d a reset. Hold down CODE and press "Q" the carriage will do a little dance and your machine should be good to go!
Dec 23, 2010 | Brother SX-4000 Typewriter
When i install the new daisy wheel i cant get it set to type the correct letters
Dec 22, 2010 | Brother GX-6750 Typewriter
The bottom of some of the capital letters is not printing correctly.
The letters on the Daisywheel have slightly curved faces to match the curvature of the paper around the platen and the hammer will contact the letters and apply pressure to the top, bottom left and right depending on where it is adjusted. Test the machine by typing Capital MWMWMW and also /////// along with the rest of the alphabet including gggyyyqqqppp. The solution may be as simple as replacing the Daisywheel (may be worn from use). If all of the letters strike more heavily on the top than the bottom, the hammer may be adjusted closer to the paper which will apply more pressure to the bottoms of the letters. Also the face of the hammer could be worn and need replacement. If the Daisywheel is in good shape, you might try adjusteing the hammer position, but it can be tricky to get perfect.
Dec 29, 2009 | Brother GX-6750 Typewriter
Types funny symbols instead of the number I
The typewriter will print the incorrect letter, or the face of the hammer if it does not spin properly to the correct position. 1. Turn the machine offf for 15 seconds and turn ON, or Depress MODE RESET(the Q key). This will rehome the Daisywheel.I If it prints correctly for awhile then looses its' position, check for ribbon or correction tape interference with Daisywheel movement. If it does not print correctly as soon as you start typing, remove the Daisywheel and inspect the spokes to see if any are bent. Reinstall the Daisywheel and power ON. If the Daisywheel has a bent spoke or two, you can try to straighten them, howvever the cause of bent spokes is a concern. While typing, carefully watch the print hammer movement. It should always return to the same position and not move towards the paper until a letter is pressed. If it does not come to rest properly, the hammer is not in proper timing and may enter the Daisywheel while it is spinning to the character, thus causing damage to the Daisywheel or causing it to lose homing. .The hammer cams would require adjustment ore replacement. If bent spokes is a persistent problem, make sure to get the hammer problem repaired before buying a new daisywhel.
Dec 29, 2009 | Brother SX-4000 Typewriter
Brother gx-6750 is typing incorrect numbers and letters. how do i fix?
Removed and reinstall the Daisywheel. Inspect the ribbon and lift-off tape to eliminate interfering with Daisywheel spinning. Make certain the daisywheel has no bent spokes. Type slowly while carefully watching the hammer come to rest after printing. If you see the hammer moving towards the paper after a print cycle, the hammer is probably causing the Daisywheel to lose homing and will need to retimed or have the hammer cams assembly replaced.
Dec 27, 2009 | Brother GX-6750 Typewriter
Mar 19, 2008 | Brother ML-300 Typewriter
Brother SX-4000 Typewriter Logo
107 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
