Question about Frigidaire ATF6000ES Front Load Washer
Why does the dr light keeps binking
Why does the dr light keeps blinking or lc light blinks when I shut the door?
  • Official Brand Answer
  • 4,342 Answers
Hello Gene Frank - Typically error code DR indicates an issue with the door switch and wiring not communicating correctly or closing properly. Try resetting the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective, contact a professional to move forward accurately.
Posted on Dec 04, 2012
2 Suggested Answers
  • 6277 Answers
SOURCE: we have water not draining and a blinking "dr" 4
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 15, 2011
Modle #kv35826
Count the number of blinks occurs at one time, after switch ON the tV. These blinks are fault indications. You can get all details about this from the this site. "Electro-help".
Type in the site address, either to Google or yahoo search box, and click search.
Don't forget to type 'hyphen' in between words, as site appear as it.
Bink indications for almost all Sony TVs are the same.
May 08, 2012 | Sony Televison & Video
My O2 Atom on normal mode binks in blue colour and there is a missed call or sms blinks in orange (or red). from yesterday it blinks in green on normal mode. Can you please tell me why? Anything wrong?
The notification lights indicate:
Blinking Blue - Bluetooth On
Blinking Yellow - WiFi On
Blinking Green - GSM (Phone) On
Blinking Red - Unread message
Continuous Red - Charging
Blinking green when your GSM (phone) is on is the expected behavior.
May 02, 2011 | O2 Xda Atom Smartphone
Power light, catriage light, paper light are continues blinking
Blinking light isue is usually related to the hardware or with the cartridge.
Please perform the steps provided in the following web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00859575&cc=uk&lc=en&dlc=en&product=1128296
:) Dr Tony
Apr 17, 2010 | HP DeskJet F380 All-In-One Printer
Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Tv turns on for two seconds, shuts off, begins binking.
The problem is most likely a power supply related problem.
The TV is in protection mode right now. It's keeping the other parts inside the TV from being damaged by automatically turning itself OFF. The 9 blinks should be an error code for the problem with the power supply. I don't have the Service Manual for your TV model number to tell you what the code means and which part to replace. Every brand of TVs have a different meanings of the code.
If you have electronic experience, you can find a factory repair manual over the internet. Normally, it's called a Service Manual. It costs about less than $20.
Jul 31, 2009 | Panasonic TC-26LX70 26 in. LCD Television
After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Jun 03, 2009 | Ovens
RED LIGHT
press and hold the menu and device/input buttons both in together for 5 seconds then the led will blink a number of blinks pause then blink another number of blinks then repeat that process. Let me know thw binks you get for the two digit blink error code.
Feb 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sharp LC-37D4U, the monitor doesn't turn on
It is hard to say without first looking at it.
Jun 28, 2017 | Sharp Aquos LC-32D40U Television
Power lights keep blinking
The power light indicates a problem (usually) with an internal problem. Usually there is a pattern to the light. (for example 3 blinks then a pause, 3 blinks then a pause etc.)
A service tech can use the code to help determine the problem.
Jan 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Frigidaire ATF6000ES Front Load Washer Logo
351 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
